#71 |
Do you know if this unit provides guide lines for rear camera and if you can turn them off?
Stock camera already have them, so this will make a mess... |
#72 |
Just the tip
Drives: 2017 DGM BRZ
Yes you can turn off the parking guidelines on the DDX917WS and I would imagine it's the same on the DDX918WS as well. I had the exact same thought when I first started it up and had a bunch of overlapping lines.
| The Following User Says Thank You to wolffbite For This Useful Post: | gpvecchi (07-27-2018) |
#74 |
Drives: 17 BRZ
Looks like this unit has just recently received a firmware update. Has anyone tried it yet?
https://www2.jvckenwood.com/cs/ce/mm...2017l/eng.html (09.08.2018) Improved Apple CarPlay Function. Improved Android Auto Function. Improved Radio function. Improved stability of performance. |
#75 |
I just discovered that the 86 misses the Bluetooth steering wheels keys that BRZ has. Do these keys work with DDX917/18?
#76 | |
Just the tip
I see that some versions of the 86 have quite limited steering wheel controls, and they are not even buttons but just placeholders (can't press them). Now I'm curious if you would be able to swap in that part from the BRZ and gain use of these controls... |
#77 |
Yup, that’s exactly what I’m asking... I’m planning to buy the BRZ buttons, if the plug is the same they should work flawlessly...
#78 |
Just the tip
#79 | |
Drives: 2017 BRZ Limited
Which wires did you splice to hard wire it in? |
#80 |
Guys, urgent please: which bracket did you use to fit the DDX? TAS400 ones seem not correct...
#81 |
Drives: 17 BRZ
From memory off of 12v accessory power. You don't want to do it off 12v constant, as it will drain your battery. You will need to test to confirm.
I run the matching dashcam for the unit, which also required hard wiring both accessory and constant, so I just piggy backed off the wiring I did for that. |
#82 |
Drives: 17 BRZ
FYI for you guys running this head unit and car play the following thread may be of interest:
http://www.ft86club.com/forums/showthread.php?t=126106 |
#83 | |
My bad, I thought you were using the Carbon Car System wiring harness. |
#84 | |
Drives: 1949 UFO
| Kenwood DDX916WS head unit -- any installed? | willimusk | Electronics | Audio | NAV | Infotainment | 39 | 07-27-2017 10:47 AM |
| Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US | GSX-R35 | Electronics | Audio | NAV | Infotainment | 17 | 05-26-2015 03:37 PM |
| Anybody know ... what head unit this is? | chaoskaze | Electronics | Audio | NAV | Infotainment | 3 | 12-21-2014 06:44 PM |
| Soo i installed a new head unit....gaps | Sniper2606 | Electronics | Audio | NAV | Infotainment | 2 | 01-16-2014 05:12 PM |
| Toyota sized Kenwood Navigation unit | Laurie | Electronics | Audio | NAV | Infotainment | 36 | 09-26-2012 12:07 PM |
