#29 |
It can. It's a raw reading, and is useless in the real world, without interpolation.
#30 |
Drives: 2015 BRZ
Can one of you EEs explain to me why Torque calls these channels PIDs? Does it stand for something other than Proportional Integral Derivative? I keep seeing people use PID for things other than feedback loops and I'm not sure where it's coming from.
Jake |
#31 |
Drives: 2013 Scion FRS
Sorry if this is a thread jack but this is the only active thread on AIM that I see on the forum. Just installed my MXS and when I connect the USB cable to my Surface 3 nothing happens in Race Studio 3 - says no device detected. Is there something special I need to do?
*EDIT* Manually installed the USB drivers from the AIM folder and re-connected all plugs - it now works! Anyone find a way to display the following: - Display AFR as a calculation of LAMBDA? - Use a warning light when a DTC has triggered? - Display boost as a differential between barometric pressure and MAP?
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
#32 | |
Drives: 2015 BRZ
DTCs would require more CAN integration, and that's something that's going to have to come directly from Aim. Lots of people have been asking for it, so I'm sure it's on their radar. I imagine it's a tough nut to crack, so it's going to take a while to make sure it's complete and something they can sell as a product. |
#33 | |
Drives: FR-S Turbo
Are you saying that the readings fed over the OBD2 Canbus for oil temp, water temp and intake air temp are not accurate and need to have a "correcting factor" applied to them? If so, how is the correcting factor determined? |
#34 | |||
Drives: 2022 GR86
Sorry to necro an old thread, but it's one of the top results when searchig for the fuel level PID for our cars, and now that I found more data I realized the thread is misleading.
It very much looks like 0x2129 is interpolated. In fact, having looked at my data over a few track sessions, I haven't found any issues with that data. Basically the fuel level is just constant when I'm parked, drops fairly linearly over time when I'm on the track, and stays constant after as I come back to the paddock and do my cool down. Having that evidence, I feel like the 0x2129 can be very much trusted at the track. I wouldn't rely on it being precise up to +-1 liter, so don't try using it to estimate how many miles you have till the next gas station... but it looks more than good enough to estimate the average fuel burndown rate. Here's how the data looks like. Yellow — standard PID, green — 0x2129, cyan line — lat G's. ![]() ![]()
| The Following 2 Users Say Thank You to timurrrr For This Useful Post: | DocWalt (05-30-2023), RedReplicant (05-23-2023) |
#35 |
Drives: None
Well, that is a nice find, it gives me some hope that I can run a Haltech IC7 and have a working fuel level.
The stock cluster has some kind of formula involving the level sensor and amount of fuel injected to derive a displayed value, if fuel injected amount is not supplied then the car will be bone dry at an apparent 1/3rd tank on the cluster. This applies to Gen 1, I know nothing about Gen 2.
| The Following User Says Thank You to RedReplicant For This Useful Post: | autoracer86 (05-24-2023) |
#36 | |
Drives: MR2, Sliver BRZ
Always looking to tinker with something..
| The Following User Says Thank You to geraldjust For This Useful Post: | RedReplicant (05-26-2023) |
