View Poll Results: Which Tire?
Hankook Ventus V12 Evo2 13 33.33%
Falken Azenis FK510 11 28.21%
General G-MAX RS 5 12.82%
Other, please post the tire and why? 10 25.64%
Voters: 39. You may not vote on this poll
Old 09-22-2018, 10:56 PM   #29
Originally Posted by Bonburner View Post
Too bad the tread pattern isn't aesthetically pleasing.
Do you seriously consider this when buying a tire? If so, why?
Leonardo (09-23-2018), Tristor (09-23-2018)
Old 09-22-2018, 11:08 PM   #30
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
its not a serious consideration, more of an observation/comment
Old 09-22-2018, 11:10 PM   #31
Oh, OK.
Old 09-23-2018, 12:01 AM   #32
Aluma007
Drives: 2017 Brz
and its not just the compound and feel, the tread width is something to consider too. The firehawk will look as stretched out as a stock primacy on an 8inch wheel. The bfgoodrich, while rated slightly lower should fill it out and look meaty according to tirerack measurements. I chose my tires with a 7.6in tread width. It's just about vertical on the sidewall.
Aluma007 is offline   Reply With Quote
Old 09-23-2018, 12:02 AM   #33
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Ah, Tirerack/Bridgestone upped the price on the Indy 500s, now I know why the other two are being considered from that test.
When I bought my set in OE size they were ~$86 each, now they're $103 each. I don't know General as a brand, but it looks like it's Conti so it should be ok, any of them will probably do just fine OP, don't think too hard about it.
ineedyourdiddly
Old 09-23-2018, 12:14 AM   #34
Ooo, nice.
Old 09-23-2018, 05:27 AM   #35
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
GT Radial SX2 is also an option. Long life, good feedback, good turn in. They are basically slightly better then the Hankooks overall. SX2 are now rated a 260tw fwiw, not the 200tw listed on most webaites.
They are under $80 online at TireCrawler for oem size
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
chaoskaze (09-23-2018), Ultramaroon (09-23-2018)
Old 09-23-2018, 08:48 AM   #36
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
Send the little extra and get the Indy 500
malubawla is offline   Reply With Quote
Old 09-23-2018, 08:52 AM   #37
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
You guys are making a good case about the Falkens vs the Firestones.
My biggest reason to look for something different than the V12s I have is the tread noise. From the tire rack review it sounds like the Falkens are the quietest of the group too.
Old 09-23-2018, 11:09 AM   #38
Vten
Drives: Too heavy
Which hankook were you talking about ? I’m coming from the 17” rs4 for my dd and going bigger with 18s 265/35 sx2s. I hope I’m making a good call.
Vten is offline   Reply With Quote
Old 09-23-2018, 11:46 AM   #39
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by why? View Post
Why not try Federal? They seem to be really popular and in that price range.
They are meh in the dry and crappy in the wet. I think they a popular more due to price vs performance. My car had them when I got it.
Old 09-23-2018, 11:54 AM   #40
Yoshoobaroo
TRACKBREAD
In this performance class the V12. The RS4 is a track day tire.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
finch1750 (09-23-2018)
Old 09-23-2018, 12:29 PM   #41
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Im running evo front and evo 2 rear same size. Hankook says they improved the tire, but...
The evo has stiffer sidewall, is stickier, has 280AA vs 320AA, is blacker, and a similar tread design. (The evo2 looks grey, but the tread design looks newer/better - not that it really matters...)
I just went square. 18x9 with 245/35. After reviews, I may try the Indy 500s, or just bite the bullet and get the tires I want.... Michelins.
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Old 09-23-2018, 12:45 PM   #42
finch1750
finch1750's Avatar
The Hankook V12 that OP mentioned. The SX2 will not be on thr same leve grip wise as the RS4. I switched from the RS3 to SX2 and it took me a track day or two to get used to thendifferent level of grip, but itll be just fine for a DD
Vten (09-23-2018)
Looking to buy Frs 20k budget nelsonzep Want-To-Buy Requests 0 05-26-2016 03:04 AM
WTB A/T BRZ/FR-S CA Budget 21k Euan Want-To-Buy Requests 4 07-20-2015 11:50 PM
If you were to pick a used "High end" Sports car what would you pick? Atropine Other Vehicles & General Automotive Discussions 133 08-02-2014 02:00 AM
$2K Budget. What Would You Do? Skippman Electronics | Audio | NAV | Infotainment 46 02-22-2013 11:23 AM
There goes my MOD'ing Budget RedRocket Scion FR-S / Toyota 86 GT86 General Forum 35 10-19-2012 08:14 AM
