Old 09-20-2018, 02:06 PM   #48539
p1l0t
p1l0t's Avatar
You would think that changing the light bulbs would be easy. But nooooo.
Jack up front end
Remove tires
Remove fender liners
Remove headlight covers, which conveniently just kind of fall off because the mounting tabs are broken
Unclip bulb retaining clip, which is practically impossible since they put the clips in facing down
R&R bulb
Re-clip, which is harder than getting it unclipped
then you try to adjust the beams because one it pointing straight at the ground, the other at the moon, but you run out of adjustment before they are even close, and one of the adjustment screws on your high beam comes out of the housing.
Now you can't drive your car because you have no light covers, and a high beam that is just flopping around, so you just want to put the tires back on so you can get it in the garage while you figure out how to repair the light covers and high beam adjuster. Then your jack fails and you can't get your tires back on, so you take your scissor jack out of your twin to jack each side up.
Get car in the garage. Simple light bulb change complete.
You must be the guy with the Lotus.
p1l0t is offline
Old 09-20-2018, 02:14 PM   #48540
Next year at the kickoff, we all need to follow clipdat to the restroom.
I have already reserved the first two weeks of June for vacation so I can go back. Will add this to the list of things to do.
Tcoat is offline
Sapphireho (09-20-2018)
Old 09-20-2018, 02:22 PM   #48541
When you do, just lean over towards him, look down and whisper "nice d*ck"!
humfrz is offline
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Sapphireho (09-20-2018), Spuds (09-20-2018), Ultramaroon (09-20-2018)
Old 09-20-2018, 02:25 PM   #48542
Tcoat is offline
Old 09-20-2018, 02:31 PM   #48543
Ultramaroon is offline
Spuds (09-20-2018), Tcoat (09-20-2018)
Old 09-20-2018, 02:34 PM   #48544
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
A duck d1ck deck.
Got it all covered in one.
Triforce!!!
bcj is offline
Old 09-20-2018, 02:42 PM   #48545
Tcoat is offline
Old 09-20-2018, 04:13 PM   #48546
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
" is that a grower? "
Sapphireho is offline
humfrz (09-20-2018)
Old 09-20-2018, 04:15 PM   #48547
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Right now I'm the guy with a big British paperweight in my garage waiting for parts.
Old 09-20-2018, 05:15 PM   #48548
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Debating on white or wood moulding for the basement. white will make my life easier and simple... but stain/finish light wood will look nice.
ichitaka05 is offline
Old 09-20-2018, 06:21 PM   #48549
White with the green Will give a better contrast.
Tcoat is offline
Dadhawk (09-20-2018), ichitaka05 (09-20-2018), Ultramaroon (09-20-2018)
Old 09-20-2018, 06:54 PM   #48550
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I use the stalls at the kickoff because the urinals don't have partitions.
Originally Posted by humfrz
I'm old and lazy
Clipdat is offline
Old 09-20-2018, 06:54 PM   #48551
Are you out of duck tape and baling wire -
humfrz is offline
Old 09-20-2018, 06:59 PM   #48552
Oh no doubt four of us could squeeze into a stall.
Tcoat is offline
Sapphireho (09-20-2018), Ultramaroon (09-20-2018)
