Old 09-18-2018, 10:04 AM   #533
fang_gt86
FR Noob
fang_gt86's Avatar
Installed V4 Stg2+ yesterday and drove about 50miles. Besides the slight "dead pedal" feel, car felt smoother than old tunes. Will be switching to E85 once I empty this 93 tank.
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
The Following User Says Thank You to fang_gt86 For This Useful Post:
D_Thissen (10-11-2018)
Old 09-18-2018, 01:18 PM   #534
n0thing
Drives: Subaru BRZ
When using apps like Torque/HLT/Racechrono via Bluetooth dongle, is the oil temperature reading ok? Previously I was using an A01G based rom (like this v4) on my B01C car, and the oil temperature doesn't read.
n0thing is offline   Reply With Quote
Old 09-18-2018, 05:37 PM   #535
steve99
Drives: FT86
Ive run the A01G/A02G roms for years the oil temp pid works fine on torque app, only weird thing ive noticed is the V2.1 blutooth ELM327 adapters wont read oil temp but the V1.5 ones do.
Old 09-19-2018, 12:41 AM   #536
fang_gt86
FR Noob
fang_gt86's Avatar
After 100miles + and my '13 FRS just doesn't feel right with V4 (Stg 2+). Throttle felt sluggish and hard to drive below 2.5k rpm. I install JDL ultra quiet FP, flashed it back with old stage 2 UEL tune, and let it idle for 15mins. Took it for normal driving to highway and damn, it felt so good! No sluggish throttle and it just sounded much better. I think V4 Stg 2+ isn't for me.
Original Mods:
Tune: OFT - OTS STG-2 UEL, 93Oct
1) Tomie UEL header
2) Invidia OP
3) OEM FP
4) ARK Grip Cat-back
5) K&N filter
6) Perrin Inlet
Old 09-19-2018, 03:52 AM   #537
Mr_Eyo
Drives: 2017 Toyota 86
I hate the v4 throttle response too. Where can I find a v2 rom for a USDM 2017 AT?
Mr_Eyo is offline   Reply With Quote
Old 09-19-2018, 08:44 AM   #538
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Are the torque request tables different between V2 and V4? If so using the V2 values might fix the throttle response?
Old 09-19-2018, 08:54 AM   #539
tomm.brz
Drives: brz 2017 hksv2
try it. copy the 5 DBW tables from v2 to your v4
Old 09-19-2018, 09:39 AM   #540
Yoshoobaroo
TRACKBREAD
If nobody else does I'll compare them when I get home tonight.
Old 09-19-2018, 07:13 PM   #541
Yoshoobaroo
TRACKBREAD
Just cross checked the DBW tables and they are identical between the 2 tunes. Maybe it's a placebo effect due to the V4 maps being smoother?
Old 09-20-2018, 01:28 AM   #542
Teseo
Drives: frs
V4 is smooth like silk, v2 tend to be like racecar. For daily driver v4 is more desirable plus heel-toe is a breeze to do it because rpms dont drop too quickly. Maybe is a placebo effect
Old 09-20-2018, 02:20 AM   #543
fang_gt86
FR Noob
fang_gt86's Avatar
To me, V4 throttle is only smooth above 3k. I've tried holding it below 2.5k and my car stutter like it's going to die.
The Following 2 Users Say Thank You to fang_gt86 For This Useful Post:
kevaughan (10-16-2018), Tloi (10-08-2018)
Old 11-04-2018, 03:50 PM   #544
tomm.brz
I noticed V4 K00G tunes has no table for gear thresholds in romraider definitions provided by Shiv
Guy with EU my17 car i tuned with OFT now has reduced final drive and no longer display correct gear (mostly the 5th not showing up)
Are there updated definitions?
Old 11-04-2018, 10:06 PM   #545
Mr_Eyo
Weird. The def for MY17 USDM AT has it...
Old 11-05-2018, 05:25 AM   #546
tomm.brz
Yep, just saw it
but my17 USDM MT (k00c) also doesnt have them
funny thing is that k00g/k00c defs have them defined in the .xml but they don t seem to work as they do not appear in Romraider
but i dont understand, US cars have shorter final driver but for v4 they use k00g as base
how shiv changed them for US cars if they do not open in romraider?
@steve99 :P
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 07:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 04:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 02:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
