Old 09-19-2018, 01:19 PM   #4719
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Originally Posted by TrqlessWonder View Post
You are also describing sort of the situation that makes me choose to do the pedal dance instead of just the 5-second method. Inside rear up>diff says wtf>brakes unloaded wheel>moves all that to the outside>outside wheel spins and slides >bind up relieved>inside rear back down and snatches hard. either a spine-wrenching wiggle, or a snap spin.
Embarrassingly I feel as tho this entire situation could have been due to no preparation. I never filled the tires up from what I was running on the track. Meaning they were all way to low for an autocross event. Which could lead to what you are describing above. I also didn't do the pedal dance like I usually do at autocross bc my OFT had some sort of error. So yep. I am an idiot.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 09-19-2018, 04:51 PM   #4720
TrqlessWonder
Drives: 2014 FR-S
I suppose it could be that stuff, too. just out of curiosity, where would track day pressure have put the tires cold/hot?
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 09-20-2018, 06:19 PM   #4721
Turbo
Drives: FR-S Turbo
Could I ask for help reading my tire temps/pressure data?
I'm relatively new to tracking, but I've driven this particular track 4 times now, logging over 400 miles on it at speed.
I would characterize my car as having corner entry understeer, although now that I think about it, I remember it being more pronounced in left turns. If you watch video of me on track, it does appear that my steering input is leading turn-in by a good bit. At least to me. Mid-corner I would say understeer-to-neutral, and pretty neutral at exit (unless I get on it hard).
Questions:
1) are my hot pressures to high in the later runs? How about my tire temps? I'm running and was told they like to be at 35psi hot and I'm way passed that up front - but the inside-to-outside temp measurements seem to say they're not overfilled?
2) any tips to reduce the corner entry understeer? I think because of this feeling there are a few corners I turn into too slow (as the car doesn't feel like it's reacting). I think I start on a tighter line than I could otherwise take if it would turn-in faster.
3) I wouldn't mind a bit MORE looseness in the back. There is a rather tight S bend on the front straightaway and I could definitely take a better line there if the rear end came around a bit more. Anything I can do to make that happen?
4) the rear temps seem to say I'm running too much camber, but I'm not running that much. Thoughts?
Car details & setup:
- 2013 FR-S. 250.8 RWHP boosted;
- HKS Hipermax SP coilovers ~26mm drop;
- Camber -3.0 LF & RF with 0 toe; -1.6 LR & -2.6 RR with 1/32 total toe-in;
- 255/40R17 RS4 tires on 720 Form 9" wheels;
Data notes:
- temps listed in order of measurement. All presented as outside/middle/inside;
- "shock" is Ft/Rr HKS 'click' setting with 30 being full hard;
- any changes to tire pressures listed after temp data with a ---> in front;
- data from my first 5 sessions of the day. Approx 72 deg F that day;
- obviously session one is just tires coming up to temp;
- track data from racechrono;
- A former national FF champion runs 1 min 3 seconds in his Radical SR3 w/Hayabusa. My best is 1:15.82
Run 1/
1:18 fastest lap
shock: 23/18
LF 125/123/129 34.1 psi
RF 123/117/110 34.3 psi
RR 115/126/134 33.1 psi
LR 110/123/127 32.3 psi
15 min brk
Run 2/
1:17.29 fastest / 1:16.43 optimal
shock: 23/18
LF 139/141/143 37.1 psi
RF 121/126/135 36.7 psi
RR 124/135/144 33.6 psi
LR 129/140/144 33.9 psi
15 min brk
Run 3/
1:17.09 fastest / 1:15.70 optimal
shock: 25/20
LF 147/153/152 38.3 psi
RF 140/132/124 37.5 psi
RR 127/143/147 35.4 psi
LR 136/143/145 34.6 psi
--> increased RF tire pressure by 0.8 hot psi
--> decreased RR tire pressure 0.7 hot psi
15 min brk
Run 4/
1:16.07 fastest / 1:14.98 optimal
shock: 25/20
LF 156/159/155 39.5 psi
RF 129/134/151 39.2 psi
RR 128/145/153 34.9 psi
LR 137/148/151 34.8 psi
15 min brk
Run 5/
1:15.82 fastest / 1:14.30 optimal
shock: 25/21
LF 154/156/160 39.6 psi
RF 130/140/151 39.2 psi
RR 124/139/142 34.7 psi
LR 132/139/140 34.7 psi
I have video o Run #5 if that's of value.
Turbo is offline   Reply With Quote
Old 09-20-2018, 07:40 PM   #4722
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I assume all your temps are 'outside middle inside'?
Add half a degree more camber in the front.
I'd assume left to right balance discrepancy is because of your rear camber difference, RR has more cornering grip than LR, left hand turns have more rear grip than right hand turns.
ineedyourdiddly
Old 09-24-2018, 01:34 PM   #4723
treedodger
treedodger's Avatar
Drives: 2022 GR86 (was 2013 BRZ)
I'll let others more wise than I answer the setup questions.
For corner entry understeer, especially in slower 2nd gear corners, I've have great luck addressing it with trail-braking per Randy Pobst and Scott Mansell:
https://www.scca.com/articles/200106...t-on-understee
and
https://driver61.com/uni/trail-braking/
2022 GR86 / 2013 BRZ
86drivechallenge.com/
treedodger is offline   Reply With Quote
Old 09-24-2018, 03:25 PM   #4724
CSG Mike
CSG Mike's Avatar
@Turbo is your entry understeer a result of input or car setup?
Old 09-24-2018, 04:00 PM   #4725
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Questions:
Data notes:
Run 1/
1:18 fastest lap
shock: 23/18
15 min brk
Run 2/
shock: 23/18
15 min brk
Run 3/
shock: 25/20
15 min brk
Run 4/
shock: 25/20
15 min brk
Run 5/
shock: 25/21
Tire pressure: Don’t overthink it: You ideally want your tire pressure to be constant all the way across. If the middle is too hot, then take air out. If the outers are (equally) hot, take a little air out. If the outside is hot, more (negative) camber. If the inside is hot, less negative camber.
Your temps seem to vary a lot, but on the last three sessions, your insides are way hotter than outsides (except LF). That means you need less (negative) camber because the tire isn’t rolling over to the outside enough. That would also explain why you’re having understeer- you don’t have a flat tire turning in.
Also, your lack of toe out is likely causing understeer. You need some toe out or the two front tires will have the same radii, and obviously, the inner one needs a shorter one. You can also try softening the front if anything is adjustable. If it’s too stiff, you may not be getting weight on the front on the brakes.
Keep in mind, the car will turn on harder on the brakes and push wide on the gas. When you’re on the brakes turning, it will almost feel like the back is swinging around. If you’re getting on the gas too early, it will push you wide, especially with a LSD. I’m really shocked these cars have LSD. You may just be getting greedy with gas. With LSD, I find myself turning in a little sharper and going wider on exit. LSD just wants to straighten the car out and force the front wheels straight. It's a strange feeling when you go back and forth from open and closed diffs.
I don’t have an 86 yet, but -2.6 is a lot of camber for street tires. Race cars on slicks run about that. I run -1.5 on my C7 with 315s up front and semi-slicks and it’s about right. On slicks, about 2.2 is right. Again, I’m not familiar with the platform, but -2.6 sounds like a lot for a soft street tire and a light car with stiff suspension, and your tire temps seem to reflect it.
GrandSport is offline   Reply With Quote
Old 09-24-2018, 04:06 PM   #4726
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Vehicles already have this from the get go. It's called ackerman. It's the difference in steering angle between the leading/tailing wheel. The 86/BRZ has a good amount of ackerman from the start. Adding toe out is just going to increase that ackerman even more.
I know because those of us that have drifted them have added angle mods, which increase steering angle and decrease ackerman to obtain a more parallel steering effect.
Old 09-24-2018, 04:27 PM   #4727
GrandSport
GrandSport's Avatar
Fair enough; I'm very surprised you don't need some toe though.
Old 09-24-2018, 05:30 PM   #4728
Turbo
Drives: FR-S Turbo
I'm fairly new to this, so I would say I really don't know. But after saying that, the gears in my head are turning.
Would video help assess this? This video is of my 2 fastest laps (1:15.82 & 1:15.9) from that day, both occurring during run #5. I would also welcome constructive criticism and tips to pick up time:
[ame="https://www.youtube.com/watch?v=2nV5IEIKHJ4"]Grand Bend Technical Layout - YouTube[/ame]
The RaceChrono laps times during that day said I was very consistent in each session, which is a plus. Watching my driving, though, I do believe I need to get smoother, and be more aggressive on the brakes.
Top speed on the back straight was 172km/hr or about 108MPH.
For reference, a former National Formula Ford champion laps this same configuration in a Hayabusa-powered Radical SR3 in 1min 3 seconds.
Old 09-24-2018, 05:36 PM   #4729
GrandSport
GrandSport's Avatar
where are you feeling understeer? Can you give us a time?
Old 09-24-2018, 05:43 PM   #4730
strat61caster
It isn't enough camber, your Corvette double wishbone suspension needs much less static camber than the MacPherson Strut suspension on the 86. I've run -4 and seen/heard others with more for street tires.
ineedyourdiddly
Old 09-24-2018, 05:47 PM   #4731
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
Would video help assess this? This video is of my 2 fastest laps from that day, both occurring during run #5. I would also welcome constructive criticism and tips to pick up time:
The RaceChrono laps times during that day said I was very consistent in each session, which is a plus. Watching my driving, though, I do believe I need to get smoother. Top speed on the back straightaway was 172km/hr or about 108MPH.
I didn't see any terminal understeer, looked like you hit the tire limits on a couple of the sweepers but nothing that makes it seem like you need to start changing your setup.
Terminal understeer has a specific sound and feel associated with it and it's easy to hit, simply enter a corner too fast and turn the wheel too much. This formula will make any car, regardless of setup, to understeer.
Here's a good example of terminal understeer, I got a point by in a corner from a car that I expected to either clear the corner before I got to it, or not give the point by. I adjusted my line by cutting inside of the car while maintaining my entry speed (which was too fast for the new line):
[ame]https://www.youtube.com/watch?v=8oznTngj124&t=411s[/ame]
14stu is offline   Reply With Quote
Old 09-24-2018, 06:00 PM   #4732
GrandSport
GrandSport's Avatar
ya, I saw a hint of oversteer if anything coming out of some turns.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
