#8205 | |
Drives: UK GT86
.: Stealth 86 :.
#8206 |
Drives: 2017 toyota 86
Curious if anyone is running this kit with stock pulley, a ace header and 91-93octane and hitting 240+whp? I’m pretty much as full blown NA besides engine work as possible. But end goal is to hit 240whp on as low of boost as possible on pump gas. Seems like most dynos I’ve seen ppl are about 225-235whp at 7-8psi but stock header or some other random non ace header which gives a good 10whp over almost any other header.
#8207 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Is anyone running this kit with the AFE Takeda/Greddy Momentum intake?
Noticed in this video that these guys have the intake pipe going into a Greddy intake. I'm guessing it just takes a bit of work with a custom hose and clamp. I wonder if this would actually be beneficial or if it would lose power, given the unit is designed for the stock intake. ![]() [ame="https://www.youtube.com/watch?v=j3fmN8sRaAo"]https://www.youtube.com/watch?v=j3fmN8sRaAo[/ame] |
#8208 |
Drives: Scion FRS
I have a 72.5 mm pulley for sale
#8209 |
Drives: '13 Subaru BRZ Crystal Black Silica
Hey guys, so I installed my kit and everythings buttoned up. I went for a low cruise down my street and my brakes don't work. When i press it, it feels like a lot of pressure is there. I also checked the supercharger, it looks like its leaking oil from the dip stip. then i found out, from the previous owner, that its stripped and metal shavings were falling into the supercharger.
What should i do guys? |
#8210 |
Drives: 2013 Subaru Brz
#8211 |
Drives: 2015 Firestorm 08/05/15
Setgo, you can pull the nose drive off. Send it to Jon Bond Performance. He can square it away. Go to his website. If you call them they are in Iowa, he is great but a busy guy. Try calling him early in the am, best bet is to like him on face book, then use messaging. His customer service is top shelf. He will answer any message after hours as late as 1100 pm he has answered me before. Saturday, Sunday.
#8212 | |
| The Following User Says Thank You to Setgo For This Useful Post: | sroby (09-19-2018) |
#8213 |
Drives: 2013 WRB BRZ
Sprintex 210 Intercooled Datalog
Hey all I'm getting my kit etuned by Openflash. I have done my first WOT pull and the log is below. Can anyone with this kit and with experience reading logs let me know if you see anything wrong.
First thing I catch is that Boost maxes out at 5.23 PSI. This is the 75mm pulley that is supposed to give you about 8-9 PSI of boost. Also got a check engine code P219A, no other codes. LTFT is high negative at idle, around -20%. https://datazap.me/u/brzf/log-153762...data=1-9-11-13 |
#8214 |
Drives: 2013 Scion FRS
You're making good boost. Stock map sensor only goes up that high, and there have been problems with aftermarket map sensors and airflow. It would be realistic to expect a MAF tune using the stock map sensor.
Don't have time to get into your fuel trims right now but perhaps someone else will jump in.
ScreamingElectron - SnakeShit |
#8215 | ||
Drives: UK GT86
.: Stealth 86 :.
#8216 | |
[ame]https://www.youtube.com/watch?v=EvTvR2ep2-U[/ame] |
#8217 |
Looks pretty good. What is layman's terms for the error code? Too lazy to Google. We might as well get that resolved here while we're at it.
#8218 | |
The common problems seem to be: -Engine vacuum leak (large) -Defective oxygen sensor/s Burnt, chafed, broken, or disconnected wiring and/or connectors -Engine exhaust leaks -A faulty mass air flow or manifold air pressure sensor -Bad fuel pump or clogged fuel filter Checked the vaccum leaks . Others I have not as everything was working perfect prior to the sc install and I wouldn know how to test the O2 sensor besides buygin a new one. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
