Old 09-16-2018, 05:29 AM   #8205
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Gustavo2nd View Post
Do you guys track with this kit? I'm currently looking up how to fix the heat soak issue i really want this kit for the sound no other sc comes close
There's no reason for you to not track with it, just expect some power loss when the IATs climb. They do seem to hit equilibrium at around 80-90C depending on circumstances. It may be beneficial to try and increase and improve coolant flow through the cooler setup, no one seems to have really given that a go. Or speak to @sam69 as he probably did the main work on this.
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-16-2018, 11:37 AM   #8206
86TOYO2k17
Drives: 2017 toyota 86
Curious if anyone is running this kit with stock pulley, a ace header and 91-93octane and hitting 240+whp? I’m pretty much as full blown NA besides engine work as possible. But end goal is to hit 240whp on as low of boost as possible on pump gas. Seems like most dynos I’ve seen ppl are about 225-235whp at 7-8psi but stock header or some other random non ace header which gives a good 10whp over almost any other header.
Old 09-17-2018, 08:22 PM   #8207
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Is anyone running this kit with the AFE Takeda/Greddy Momentum intake?
Noticed in this video that these guys have the intake pipe going into a Greddy intake. I'm guessing it just takes a bit of work with a custom hose and clamp. I wonder if this would actually be beneficial or if it would lose power, given the unit is designed for the stock intake.
[ame="https://www.youtube.com/watch?v=j3fmN8sRaAo"]https://www.youtube.com/watch?v=j3fmN8sRaAo[/ame]
Wise is offline   Reply With Quote
Old 09-18-2018, 11:32 AM   #8208
Hill
Drives: Scion FRS
I have a 72.5 mm pulley for sale
Hill is offline   Reply With Quote
Old 09-18-2018, 02:29 PM   #8209
Setgo
Setgo's Avatar
Drives: '13 Subaru BRZ Crystal Black Silica
Hey guys, so I installed my kit and everythings buttoned up. I went for a low cruise down my street and my brakes don't work. When i press it, it feels like a lot of pressure is there. I also checked the supercharger, it looks like its leaking oil from the dip stip. then i found out, from the previous owner, that its stripped and metal shavings were falling into the supercharger.
What should i do guys?
Setgo is offline   Reply With Quote
Old 09-18-2018, 02:47 PM   #8210
SleeBrzz
SleeBrzz's Avatar
Drives: 2013 Subaru Brz
Sent you a PM.
SleeBrzz is offline   Reply With Quote
Old 09-18-2018, 10:34 PM   #8211
sroby
Drives: 2015 Firestorm 08/05/15
Setgo, you can pull the nose drive off. Send it to Jon Bond Performance. He can square it away. Go to his website. If you call them they are in Iowa, he is great but a busy guy. Try calling him early in the am, best bet is to like him on face book, then use messaging. His customer service is top shelf. He will answer any message after hours as late as 1100 pm he has answered me before. Saturday, Sunday.
sroby is offline   Reply With Quote
Old 09-18-2018, 11:30 PM   #8212
Setgo
Setgo's Avatar
Awesome. I gave him a call and I'm going to be submitting a request for servicing form. Thanks!
Old 09-27-2018, 10:50 PM   #8213
BRZ_F
BRZ_F's Avatar
Drives: 2013 WRB BRZ
Sprintex 210 Intercooled Datalog
Hey all I'm getting my kit etuned by Openflash. I have done my first WOT pull and the log is below. Can anyone with this kit and with experience reading logs let me know if you see anything wrong.
First thing I catch is that Boost maxes out at 5.23 PSI. This is the 75mm pulley that is supposed to give you about 8-9 PSI of boost. Also got a check engine code P219A, no other codes. LTFT is high negative at idle, around -20%.
https://datazap.me/u/brzf/log-153762...data=1-9-11-13
BRZ_F is offline   Reply With Quote
Old 09-29-2018, 07:46 AM   #8214
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
You're making good boost. Stock map sensor only goes up that high, and there have been problems with aftermarket map sensors and airflow. It would be realistic to expect a MAF tune using the stock map sensor.
Don't have time to get into your fuel trims right now but perhaps someone else will jump in.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 10-02-2018, 12:39 PM   #8215
Kodename47
Kodename47's Avatar
Drives: UK GT86
Did you fit the brake booster vac line correctly? Sounds like you might have got the check valve the wrong way round.
Just sounds like the MAF needs correctly scaling, hence the high trims.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-02-2018, 01:38 PM   #8216
BRZ_F
BRZ_F's Avatar
Yeah that's what I've been told so I scaled it using the VGI tool. My idle LTFT is pretty good now but I am still getting a code P219A (no other codes). I see my STFT fuel trims vary quite a bit when I'm driving. The video below shows how the STFT vary when I step on the gas at idle then they settle back down. Already checked for leaks using smoke test and all is good. The car drives just like it did before I installed the kit as well. Any thoughts?
[ame]https://www.youtube.com/watch?v=EvTvR2ep2-U[/ame]
Old 10-08-2018, 05:33 PM   #8217
riboyster
riboyster's Avatar
Looks pretty good. What is layman's terms for the error code? Too lazy to Google. We might as well get that resolved here while we're at it.
Old 10-10-2018, 03:00 PM   #8218
BRZ_F
BRZ_F's Avatar
It's Air/Fuel Ratio Imbalance in Bank 1. So the engine computer is noticing an incorrect ratio or a widly varying ratio. And I think it has to do with the fuel trims varying so much.
The common problems seem to be:
-Engine vacuum leak (large)
-Defective oxygen sensor/s Burnt, chafed, broken, or disconnected wiring and/or connectors
-Engine exhaust leaks
-A faulty mass air flow or manifold air pressure sensor
-Bad fuel pump or clogged fuel filter
Checked the vaccum leaks . Others I have not as everything was working perfect prior to the sc install and I wouldn know how to test the O2 sensor besides buygin a new one.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
