Old 09-14-2018, 08:12 AM   #1
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
JDL 4-2-1 EL header
Got an email from JDL today. Exciting stuff!
I'll be testing a slightly smaller diameter primary version of the header very soon here that I expect to make more torque. This will likely be the production version of the header. The header uses 15 degree merge collectors and will feature all stainless steel flanges. Retail price will be $1099. If there was enough interest I could see about some sort of group buy pricing.
https://www.instagram.com/p/Bl_v97Kj...on_share_sheet
https://www.instagram.com/p/BmtLZSAH...on_share_sheet
@JDLAutoDesign any more info on this?
tehShirt is offline   Reply With Quote
The Following 8 Users Say Thank You to tehShirt For This Useful Post:
fika84 (09-17-2018), J1Avs (09-18-2018), JBezugs (09-14-2018), Prodigalson (09-17-2018), smg1138 (09-15-2018), Teseo (09-22-2018), TofuJoe (09-17-2018), weederr33 (09-26-2018)
Old 09-14-2018, 08:55 AM   #2
J1Avs
Drives: 2018 BRZ tS
Woah! @JDLAutoDesign are you trying to take on the ACE350???
Interested to hear more!
J1Avs is offline   Reply With Quote
The Following User Says Thank You to J1Avs For This Useful Post:
Tristor (09-17-2018)
Old 09-14-2018, 09:55 AM   #3
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
whats the price and does it still use stock OP?
Old 09-14-2018, 04:09 PM   #4
gpvecchi
gpvecchi's Avatar
If it's cheap, it's mine.
The Following User Says Thank You to gpvecchi For This Useful Post:
chaoskaze (09-14-2018)
Old 09-14-2018, 04:41 PM   #5
Chuckls
Moutain Runner
It's available for purchase. You just need to contact JDL directly.
Chuckls is offline   Reply With Quote
Old 09-14-2018, 05:28 PM   #6
J1Avs
Drives: 2018 BRZ tS
Any idea on price?
Old 09-15-2018, 01:26 AM   #7
PulsarBeeerz
Drives: JRSC BRZ SOLD
JDL doesn't do cheap...
PulsarBeeerz is offline   Reply With Quote
Old 09-15-2018, 05:12 AM   #8
gpvecchi
gpvecchi's Avatar
But cheaper than ACE...
Old 09-15-2018, 08:30 AM   #9
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
That's not hard. Even if it's $500 more than the UEL it'll be cheaper than ACE.
On a side note, I'd like to see numbers where the car is tuned for each header. If this was on a stock tune for both the UEL would have been at a disadvantage and the difference might actually not be as large.
Old 09-15-2018, 10:34 AM   #10
Lantanafrs2
Drives: 2013 frs red
It says tuned above dyno graph
Lantanafrs2 is offline   Reply With Quote
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post:
Trust86 (09-15-2018), Yoshoobaroo (09-15-2018)
Old 09-15-2018, 11:48 AM   #11
Trust86
Drives: 2016 Halo FRS
I don’t think it will be priced that much higher over the UEL bc of the slip joint connections.
Trust86 is offline   Reply With Quote
The Following User Says Thank You to Trust86 For This Useful Post:
Old 09-15-2018, 12:17 PM   #12
gtengr
Drives: 2017 BRZ
Visually the early merge of the second collector location makes me think it would more closely compete with the Ace A150. The JDL probably needs an overpipe and the Ace includes one so that should be factored into the cost.
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
Breadman (09-17-2018)
Old 09-16-2018, 11:48 PM   #13
jflogerzi
jflogerzi's Avatar
I am excited for this. I would love to compare this with my tomie uel
2013 Series 10 FRS #553
Old 09-17-2018, 07:56 AM   #14
Breadman
Breadman's Avatar
Everyone forgets this when complaining about it burnt expensive. Price still.stung but it helps a little bit
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
