Old 09-10-2018, 11:26 PM   #1
TheRealBFKR
Drives: '18 WRB BRZ Limited w/ PP
Down 1/3 quart on new car
Hi all,
I put on about 2.8k mile on my brand new ‘18 BRZ within the last month. Today, I noticed that my dipstick is reading about 1/3 of the way below the top hole. I am fairly certain it was right at the top hole when I checked at around 2k. Is this normal usage for a new car? Full disclosure: I do push the engine pretty hard on backroads. I have seen roughly 250F+ oil tell just from backroads driving.
I plan on doing my first autox day and HPDE weekend with it towards the end of the month. The plan is to change to 5w30 before then, even if I will realistically be under 4K miles at that point. I will then change back to 0w20 almost right after the HPDE weekend in October since winter is coming. Does that sound like a logical plan?
Thanks!
TheRealBFKR is offline   Reply With Quote
Old 09-10-2018, 11:45 PM   #2
Originally Posted by TheRealBFKR View Post
Hi all,
Thanks!
Hello TheRealBFKR and welcome to our forum -
I wouldn't worry about your car consuming 1/3 quart of oil in 2,800 miles, especially since it's new. Back in the day, we used to expect a new engine to use a little oil, till the oil rings got good and seated.
Mine uses about a half a quart between oil changes (7,000 miles).
I wouldn't think it would be necessary to change to the heavier oil for a limited autox and HPDE exposure. But, if it makes you feel better, it won't hurt anything.
It's most important to keep the oil level near the top hole on the dipstick, especially if you are pushing it.
Have a fun track experience -
Spuds (09-11-2018)
Old 09-11-2018, 12:54 AM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Hi all,
Thanks!
Buy an oil cooler.
Spuds (09-11-2018)
Old 09-11-2018, 11:49 AM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
How are you measuring oil temp?
As mentioned before:
Oil consumption is normal.
You might want to consider an oil cooler of some variety.
Old 09-11-2018, 03:05 PM   #5
TheRealBFKR
I have the Limited so there is a handy digital gauge on the dash display.
OC is on the agenda, just probably not for my first track day ever.
The Following User Says Thank You to TheRealBFKR For This Useful Post:
Spuds (09-11-2018)
Old 09-11-2018, 03:06 PM   #6
TheRealBFKR
Thanks, humfrz. I have actually been lurking on the forums for a quite a few years now. The BRZ has been a dream car of mine for quite some time. Glad to finally be a part of the 86 gang.
The Following 2 Users Say Thank You to TheRealBFKR For This Useful Post:
bcj (09-12-2018), humfrz (09-11-2018)
Old 09-11-2018, 06:07 PM   #7
finch1750
finch1750's Avatar
Any reason why not for the first day ever? Your car sees high RPM all the same and you're seeing high temps outside of the track as is.
Old 09-11-2018, 06:09 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
+1. If I was seeing 250 on the street consistantly I would cool it for track, hell, for the street.
Old 09-12-2018, 12:15 AM   #9
TheRealBFKR
I am moving soon to the Pacific Northwest, where the summers rarely get above the 80s.
I want to make sure I have an oil cooler that doesn't overcool the oil.
Right now, it seems like either the OEM Forester OC or the JR Dual Radiator/OC could be the answer.
The latter is of course, a lot pricier and could really only happen after I move at the end of the year.
Old 09-12-2018, 12:57 AM   #10
Personally, I don't feel an oil cooler is necessary for a non tracked car in the western part of the PNW.
Now, my good buddy, @Ultramaroon, down in Vancouver, WA, installed an oil cooler. Maybe he would like to comment -
Old 09-12-2018, 02:49 AM   #11
My engine is bone stock.
I monitor temps and pressures.
I run the biggest fucking oil cooler ever paired with this engine.
I have a diverter valve so I can control flow anywhere between full bypass to full cooler.
I only run 0w20.
Anywhere above 200 F the oil will not reach spec pressure.
If the engine is run steadily above 4500-5000, the oil gets hot quickly regardless of water temp. I don't know if all engines do this but this one is the first to which I've paid close attention. Based on my observations from tinkering with my system in all kinds of conditions, I can confirm the recommendations published by Setrab here.
I run a little under half my oil through the cooler with a 180F thermostat in all cases except sustained operation between 5000-redline. Then, my 72-row, series-1 just manages to keep the oil below 190F.
_____________________
tl:dr
Unless it's a dedicated track car, pick a cooler designed to dissipate around 30KBTU/hr. You won't be sorry.
Driving with 1 quart of oil? TM Other Vehicles & General Automotive Discussions 9 07-31-2014 10:16 AM
0W-20 full synthetic oil for $3.49 a quart terrypm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 04-08-2014 04:51 PM
