Old 09-10-2018, 04:15 PM   #1
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Ignition Retard in gear
I have a problem with my ignition retarding in gear. I only happens rolling, in gear, specifically noticeable with the clutch in while coasting and blipping the throttle. Not moving or not in gear its not there. Its like the transient Ignition Retard map but only in gear and moving. It can't be though because that map doesn't have numbers in this area to bring the ignition timing down this much. I am getting about a -20 difference between out of gear and in gear. Some times ignition is past TDC. Only have I have found is the minimum Ignition timing map but that is more of a band aid. Something has not be requesting the timing retardation.
Toyota John is offline   Reply With Quote
Old 09-10-2018, 05:32 PM   #2
tomm.brz
Drives: brz 2017 hksv2
There is a table called in ecutek " Ignition timing compensation while clutch down"
in romraider i dont remember how it s called, it s in the ignition timing - compensation folder, and has "MAP (Clutch)" in the name
it 's because of that map
i reduced quite a bit the retard in every cells of that table but the last 2 (large throttle blips that cause the manifold pressure to go over 0.8bar)
Toyota John (09-10-2018)
Old 09-10-2018, 08:17 PM   #3
Toyota John
Calle Atun
I either didn't see it or they defined it this summer. I hadn't updated all summer and just updated this afternoon. That has to be it. Thanks.
Old 09-11-2018, 02:32 AM   #4
tomm.brz
Do you have ecutek?
yes they defined this summer actually, together with ignition compensation per cylinder
Old 09-14-2018, 02:05 PM   #5
Toyota John
Calle Atun
Originally Posted by tomm.brz View Post
Do you have ecutek?
Yes ecutek. I just noticed it after my update.
Setting it to zero does cause tip in knock with quick throttle inputs but only with the clutch pushed in. I am not sure why or what is causing the the tip in knock. This table must exist because knock is being cause by something else that isn't present normally. Only seems to be active when the clutch is pushed in, the transmission is in gear and rolling. Could there be some compensation table that reduces injector pulses width during gear changes to reduce emissions? Or is the D4S switching it PI for this? Have you tried logging to see what the change is? I will try on my way home.
Old 09-14-2018, 07:49 PM   #6
tomm.brz
Dunno, but dont zero it... just reduce them keeping the last 2 at about 11 / 19
the rev matching with clutch down improves a lot
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 06:28 PM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
My car seems slow ... do these car retard for bad gas? rskdsk Scion FR-S / Toyota 86 GT86 General Forum 46 09-24-2013 01:34 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
