Old 09-10-2018, 09:51 AM   #3473
Scala
Drives: 2018 BRZ tS
Originally Posted by bslate3 View Post
They only made 500 of these in America, so it doesn’t meet the 1000 minimum units to be SCCA legal. I know, stupid rule.
Not sure I follow. Not legal in which SCCA Class?
Thanks.
Scala is offline   Reply With Quote
Old 09-10-2018, 10:35 AM   #3474
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
Thanks.
Correct, the modifications over the stock/base car would all count the same as if they were non-OEM parts installed by you, so you'd have to remove stuff like the wing and different springs would automatically put you in STX.
14stu is offline   Reply With Quote
The Following User Says Thank You to 14stu For This Useful Post:
Scala (09-10-2018)
Old 09-10-2018, 10:45 AM   #3475
Scala
Drives: 2018 BRZ tS
Thank you. I guess I'll have to see how competitive it can be in STX and how much it'll cost to get it there.
Old 09-10-2018, 02:46 PM   #3476
CoolHandMoss
Drives: 2013 FRS
Originally Posted by Simmons View Post
Its added stiffness depending on what holes it's set on..... I can match the bar I had on it..... Or go either direction.
It is not available yet, Brian and I are testing them right now. If you are at nationals, come by and take a look at it.
Eric Simmons
Any news on it yet? I'm curious how it's working out/possibly interested in one once they're available. My driving style likes front roll stiffness.
CoolHandMoss is offline   Reply With Quote
Old 09-10-2018, 04:57 PM   #3477
86prime
Drives: 18 BRZ tS
The package itself is illegal for STX until someone writes a letter and it is added. The limited run of only 500 units may mean that the ts BRZ will never be classed.
So if the ts never gets classed, is it then not allowed to compete?
86prime is offline   Reply With Quote
Old 09-10-2018, 05:06 PM   #3478
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
The sway bar is awesome.....I did a lot of testing during the Evo School test and tune. Then made some adjustments for the wet runs on day 1.
Day 2, the car was loose and I should have made a change after my 1st run.....instead I stiffened one side of the bar after my 2nd run and it was really good for my 3rd run( I coned away 4th place)
I was able to make the bar adjustments between runs even with being a 2 driver car.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following 2 Users Say Thank You to Simmons For This Useful Post:
DocWalt (09-11-2018), strat61caster (09-10-2018)
Old 09-10-2018, 05:08 PM   #3479
14stu
14stu's Avatar
They won't have a street class, but there are NOC (not otherwise classed) categories for all the other classing tiers.
Old 09-10-2018, 05:18 PM   #3480
86prime
Drives: 18 BRZ tS
Just read September Fastrack... tS is in C-Street at least
https://www.scca.com/pages/fastrack-news
The Following User Says Thank You to 86prime For This Useful Post:
Old 09-10-2018, 05:43 PM   #3481
86prime
Drives: 18 BRZ tS
Just answering my own question... NOC is not eligible for Nationals
Old 09-10-2018, 11:05 PM   #3482
nico_rsx
Drives: BRZ 2017 Pure Red, MT
I installed a prototype Karcepts front sway bar tonight......This thing is built very good.
I can't wait to try it this weekend.
Simmons
How many stiffness adjustments is there on it?
nico_rsx is offline   Reply With Quote
Old 09-11-2018, 05:15 PM   #3483
Simmons
Simmons's Avatar
4 holes....plus you can just do 1 hole instead of both sides.
Simmons
The Following User Says Thank You to Simmons For This Useful Post:
nico_rsx (09-11-2018)
Old 09-12-2018, 08:06 AM   #3484
steverife
Drives: 2016 Scion FRS
Brian also pieced together a rear bar (ND arms maybe?) and said we can expect a production version at some point.
Beautiful pieces and if you've ever dealt with one of these style bars along with a stock designed bar that might tend to bind, it is a must have...
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
Simmons (09-12-2018)
Old 09-15-2018, 06:34 PM   #3485
dvalue
Drives: 15 BRZ
What's everyone at for ride height? Or is it really even worth taking it into consideration for these cars?
Delta/CENLA Region SCCA - DS
dvalue is offline   Reply With Quote
Old 09-15-2018, 06:42 PM   #3486
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I think it matters to some extent, but you don't have to be super low for STX. During Autocross season I set my ride height to 13" from hub center to fender. That's somewhere in the neighborhood of 1.5" to 1.75" lower than stock.
smg1138 is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
