Old 09-01-2018, 12:08 PM   #15
RallySport
Drives: FRS
Originally Posted by guybo View Post
We've all heard of butt dyno for engine changes, now we have boob dyno for for suspension changes? AND VIDEO or I ain't buyin' it!
Never before has something so subjective been so quantifiable.
RallySport is offline   Reply With Quote
The Following 2 Users Say Thank You to RallySport For This Useful Post:
new2subaru (09-01-2018), Tcoat (09-01-2018)
Old 09-01-2018, 06:21 PM   #16
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
This thread has been derailed to be about boobs .. haha .. I guess what thread technically wouldn't if it has the chance ..
Also my girl is a bit shy and we should keep our eyes on the road right? :P
but I'll probably swap out the shock and struts to the newer set if my current one goes bad
Old 09-01-2018, 10:23 PM   #17
I am amazed at the number of people that have drove with the different suspensions under such controlled conditions that they can tell the difference. The changes are minuscule between all the models yet appear to have massive changes when measured on the titcur scale.
Old 09-01-2018, 11:29 PM   #18
Especially since nobody has mentioned the size of the instruments used or shown any video data -
Tcoat (09-01-2018)
Old 09-09-2018, 10:46 PM   #19
FRS13_
FRS13_'s Avatar
Drives: 2013 Scion FRS 6-speed
Originally Posted by Decep View Post
Big time.. 2018 86 springs/sachs dampers on my 2013 frs made it so compliant on nasty pavement. added the slightly fatter rear sway bar too.
Hi I'm trying to confirm if the 2018 86 oem shocks and springs will fit the 2013 frs? Help plz
FRS13_ is offline   Reply With Quote
Old 09-09-2018, 10:59 PM   #20
Vital
Drives: 2015 BRZ
Yes, it will go for it. People have done MY17 shock + springs on 2013-2016 models.
The Following User Says Thank You to Vital For This Useful Post:
FRS13_ (09-10-2018)
Old 09-10-2018, 01:12 AM   #21
Decep
Drives: 2013 FR-S Series 10
Yes. The ride is much more compliant. The OEMs also add a fatter rear sway bar ( a whole whopping +1mm) to counteract the slight increase in body roll in the corners too.
The Following User Says Thank You to Decep For This Useful Post:
FRS13_ (09-10-2018)
Old 09-10-2018, 07:39 AM   #22
Racecomp Engineering
Shocks were the same between FRS and BRZ, springs were different.
Fairly noticeable step up in ride quality with the 2017+ shocks. The 2013s were a little rough especially, and I think 2015-2016 are OKAY.
Originally Posted by new2subaru View Post
Funny you say that because when I switched to RCE yellows my wife said her boobs jiggled less. Got the thumbs up
I'm....sorry?
With our springs, certain roads do feel better/smoother while some types of roads will feel a little bit worse. With 2017+ shocks again it's a little better.
- Andrew
new2subaru (09-10-2018), pumice (09-22-2018)
Old 09-10-2018, 08:15 AM   #23
FRS13_
FRS13_'s Avatar
I'm....sorry?
- Andrew
Thanks guys!
Sent from my SM-G892A using Tapatalk
Old 09-10-2018, 02:41 PM   #24
Decep
Thanks guys!
If you haven't already make sure you check classifieds because people often want to get rid of their stock equipment and you can get good deals.
Old 09-10-2018, 02:48 PM   #25
FRS13_
FRS13_'s Avatar
Yea I been checking those daily, haven't had much luck I'm about to just buy them new. My left rear shock just started leaking, not bad for 94000 miles.
Wheel Question on Stock Shocks FewTooManyBeers Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-25-2018 02:04 AM
OEM shocks going out? brazy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 02-09-2018 11:07 AM
WTB: Shocks ThucP Canada Classifieds 0 08-08-2017 08:47 PM
On lowering springs for and stock shocks, time for new shocks... Basket Case Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-16-2015 08:31 AM
What shocks _F-R-S_ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-31-2012 02:18 PM
