Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-10-2018, 10:02 AM | #1 |
FR Noob
No 2nd Gear After New Parts
Hey guys. I couldn't get my car to go into second gear after I installed the Exedy OEM kit - flywheel, pressure plate, clutch, and TOB. Refilled with Motul 300 fluid. I've checked the shift lever cap and it's installed correctly.
Symptoms: 1.) Won't go into 2nd gear and felt like it's not there anymore. 2.) 1st gear felt like 3rd gear. Reverse gear works. Any help will be much appreciated and thanks!
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in |
09-10-2018, 11:23 AM | #2 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
The Following User Says Thank You to finch1750 For This Useful Post: | ermax (09-10-2018) |
09-10-2018, 11:38 AM | #3 |
FR Noob
I'll mess with the reverse lock-out again.
09-10-2018, 11:43 AM | #4 |
Drives: 2014 GT86
finch1750: reverse lock-out .. something in gearbox, or on shifter handle or anything more specific as to what exactly needs extra attention?
09-10-2018, 12:05 PM | #5 |
Let me see if I can get my buddy to chime in. I only know cuz I drove his car and 2nd would be locked out sometime and thats the reason he gave me.
The Following User Says Thank You to finch1750 For This Useful Post: | Lantanafrs2 (09-10-2018) |
09-10-2018, 12:23 PM | #6 |
Drives: '13 Ultramarine FR-S M/T
My problem stems from the reverse lockout guide that is bolted down under the shifter boot. It's basically the tab that prevents you from going into reverse until you lift the lockout on the shifter. If it's not aligned properly you will have issues with running into the "gate" when trying to shift into 2nd. When you shift into second try and make sure you go straight back and not slightly to the left. If it goes into 2nd it's the lockout tab.
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's |
09-10-2018, 12:28 PM | #7 |
Chicken bucket
Drives: '15 ultramarine
Can you get into 2nd with the lockout raised?
09-10-2018, 12:45 PM | #8 |
FR Noob
I will have to try that later.
09-10-2018, 12:49 PM | #9 |
I will leave this here:
https://demos.starbase7.net/t3Portal...73598848384294 |
The Following 3 Users Say Thank You to ermax For This Useful Post: |
09-10-2018, 12:54 PM | #10 | |
FR Noob
09-10-2018, 01:21 PM | #11 |
Nah.. give it to @finch1750. He had the answer first. I was just adding the manual page to make the job easier.
The Following User Says Thank You to ermax For This Useful Post: | finch1750 (09-10-2018) |
09-10-2018, 07:41 PM | #12 |
FR Noob
Thanks guys. She's alive!
09-10-2018, 08:07 PM | #13 |
Drives: 2013 frs red
Now that's how these forums are supposed to work. Bravo!
Similar Threads | ||||
Gear indicator (G-on) shows 2 when in 3rd gear | c8Face | BRZ First-Gen (2012+) -- General Topics | 31 | 07-07-2017 07:23 PM |
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl | jakebrz | Issues | Warranty | Recalls / TSB | 14 | 06-06-2016 06:28 PM |
Auto gear slippage on 2nd n 3rd gear | shantha | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 11-19-2015 07:26 PM |
Low Idle/Cam gear - Anyone request to inspect your old/replaced parts? | ahausheer | Issues | Warranty | Recalls / TSB | 7 | 08-26-2012 03:31 PM |
Reverse gear on the first and second gear side | randytindoggy | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 01-29-2012 01:21 PM |
