Old 09-10-2018, 01:14 AM   #1
jojosbrz
Drives: 2017 PP BRZ HKS supercharged
Finding wheels to clear brembos
Build is a 17 brz with performance package, factory brembos all 4 four wheels, lowered 1 inch on feal 441 coilovers, and hks supercharged.
Looking for wheel recommendations 18x9.5 square setup that will clear the brembos. Is this even possible? I think the only ones I have seen are te37s but those are out of my price range. Looking to spend around 1500$.
So far I have looked at enkei TS9 and TM7. After asking fitment industries, their rep said spec 18x9.5 +45 offset will not clear the brembos in the front, I would have to run 18x8.5. I do not want to run staggered.
Curios if there are even many other wheels that will fit my desired specs. I have had trouble finding alot of information on brembo wheel clearance on the forums.
Please send pictures of any builds you know with similar specs, and links to the wheels.
Thanks in advance, Joseph
jojosbrz is offline   Reply With Quote
Old 09-10-2018, 01:32 AM   #2
86MLR
86MLR's Avatar
My 17x8 +43 Enkei RPF-1's clear, bigger shouldn't have a issue.
Just contact your local suppliers, they should have a big range of brands in different styles.
Old 09-10-2018, 11:18 AM   #3
BRZ383
Drives: 2018 BRZTs,
I think the volk 57cr will clear in that size you are looking for, I would contact ft86speed factory.
BRZ383 is offline   Reply With Quote
Old 09-10-2018, 11:55 AM   #4
.Kyle
Drives: it's grey
use google but clarify your search terms. this was one of the top results by seraching "ft86club brz performance package brembo wheel"
https://www.ft86club.com/forums/showthread.php?t=122138
.Kyle is offline   Reply With Quote
Old 09-10-2018, 03:17 PM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Work Emotion Kiwami 18 X 9.5 I have Wilwood 6 Piston FR and 4 Piston Rear and there is tons of space between the caliper and rotor. A good 1 inch at least!
N1rve
Old 09-10-2018, 06:54 PM   #6
.Kyle
Drives: it's grey
Wilwood are a far thinner caliper than a Brembo. Correlating their fitment to another caliper doesn't work.
Old 09-10-2018, 08:20 PM   #7
jojosbrz
dont like the look of rpf 1s, also a very common wheel so no for me
Old 09-10-2018, 08:20 PM   #8
jojosbrz
volk is outside of my price range lol
Old 09-10-2018, 08:22 PM   #9
jojosbrz
already looked at this forum. not very helpful and not much information, theres two wheels listed with the specs i want, neither of which i am interested in.
Old 09-10-2018, 08:22 PM   #10
jojosbrz
not trying to spend over 2000 on wheels
Old 09-10-2018, 08:44 PM   #11
CSG Mike
CSG Mike's Avatar
I can help. PM me.
Old 09-10-2018, 11:47 PM   #12
N1rve
N1rve's Avatar
Check out ESR SR08?
https://esrwheels.com/products/sr08?variant=24487907395
N1rve
Old 09-11-2018, 07:49 AM   #13
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
Apex ARC-8 17x9 +42 fits over Brembos. ~17lbs, no hub rings required.
tehShirt is offline   Reply With Quote
Old 09-11-2018, 12:26 PM   #14
.Kyle
Drives: it's grey
Go to the wheel manufacturer's site and look at the fitment table then. While the PP is still pretty new and not referenced on the table you can use 2004 STi for similar application (5x100 and similar caliper dimension - the STi caliper is about 2.5mm closer to the spokes for some reason. May be due the fact that it is slightly different internally with tapered bores.)
Also, what are you looking for? The topic of this thread is very broad but you then reply "not looking to spend that much" and "I don't like that style". What price, specs, and spoke design do you seek. With that people can better help you.
bbk, brembo, brembo big brake kit, brembo brake
Do BRZ/FRS/GT86 wheels fit over rear Brembos? Elliotw Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-13-2018 04:30 PM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 08:31 AM
Will stock wheels clear Wilwood BBK? Brody602 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 10:32 AM
Are the stock wheels clear-coated? Tromatic Northwest 2 07-29-2013 09:47 AM
Are the stock wheels clear-coated? Tromatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-17-2013 11:09 PM
