Old 09-08-2018, 02:08 PM   #1
russsak
Drives: Subaru BRz limited 2013
Serpentine belt issue / So Cal LAX Airport
I noticed that although the serpentine belt is still moving, one of the rolls sometimes spins and sometimes does not. It is also making some noise. I'm thinking I may need to get the belt tension adjusted. Thoughts?
Also, any recommendations for a mechanic by LAX airport?
russsak is offline   Reply With Quote
Old 09-08-2018, 02:14 PM   #2
Welcome to our forum -
Which "roller" is not turning?
If it's the one attached to the AC compressor, it will only "look" like it's turning when the compressor clutch engages it.
The belt tension is automatically adjusted by the belt tensioner pulley (if it's working right).
Old 09-08-2018, 02:39 PM   #3
russsak
Thanks! Its the one next to the left of the oil filter and behind the air intake. I will try to attach a pic.
Old 09-08-2018, 02:40 PM   #4
russsak
Its partially covered by the plastic housing
Old 09-08-2018, 02:57 PM   #5
What I think you are referring to is the pulley for the A/C compressor.
The pulley goes around any time the engine is running, however, the "clutch" just locks up when the compressor is told to run.
Sometimes the belt will squeak at that point, especially when the compressor just comes on.
I suggest you start the car, turn OFF the A/C, look at that unit, see if the "clutch" (the inner part of the pulley) is turning - it should NOT be.
Now turn on the A/C on high and look at the pulley, the inner part (the clutch) should be turning.
Come back.
FRSBRZGT86FAN (09-08-2018)
Old 09-08-2018, 03:03 PM   #6
John27
Drives: scion fr-s
ac clutch
that the ac clutch it only turns when the ac is on
John27 is offline   Reply With Quote
Old 09-08-2018, 03:35 PM   #7
Grady
Grady's Avatar
#1 Welcome to the Fourm!
#2 Clean your engine and bay.
#3 Replace belt.
#4 Drive it like you stole it! (On the track)
Old 09-08-2018, 09:27 PM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
#3 Replace belt.
That's not the fix for this
I think you might actually be referring to the ac clutch which only engages when the A/C or defroster is on, on almost all cars, otherwise if you look past it you'll notice that it's out pulley is still spinning. Once you "call" for a/c the electromagnetic clutch is power and it grabs that inner pulling and it should spin
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
humfrz (09-08-2018)
Old 09-08-2018, 09:58 PM   #9
Grady
Grady's Avatar
There is nothing broken to fix, however the noise could be a squeaky belt. A new belt will fix that.
Old 09-09-2018, 10:31 AM   #10
extrashaky
Drives: 2014 BRZ Limited
Describe the noise.
Old 09-09-2018, 10:34 AM   #11
extrashaky
I understood his post to mean the pulley is making some noise when it "stops," not that the belt was squealing. The compressor does make noises when the clutch engages and disengages. So there's still no evidence at all at this point that the belt needs to be replaced, tightened or messed with at all.
The Following 3 Users Say Thank You to extrashaky For This Useful Post:
humfrz (09-09-2018), Tcoat (09-09-2018), Ultramaroon (09-09-2018)
Old 09-09-2018, 02:48 PM   #12
Originally Posted by extrashaky View Post
Describe the noise.
OK, OP you're up -
Old 09-09-2018, 05:11 PM   #13
FRSBRZGT86FAN
Belts not squeaking as we know of, either a pulley or tensioner or the compressor drive itself is what seems to be squeaking right now
belt, mechanic, serpentine, tensioner
Serpentine Belt SlyCayer Engine, Exhaust, Transmission 3 04-13-2015 02:40 PM
SOS. Monterey area. Belt tensioner/belt The Racers Line Northern California 11 04-06-2015 02:33 PM
Seat Belt Issue, Help! hAnGie Scion FR-S / Toyota 86 GT86 General Forum 26 04-10-2014 08:40 AM
Serpentine Belt Changeout Guide FRS BRZ Binbear4 DIY (Do-It-Yourself) Guides 0 11-17-2013 06:35 PM
