Old 03-24-2011, 07:24 PM   #43
Exage
GL 86!
Exage's Avatar
Drives: Maybe FR-S... maybe not
Like a rocker arm that can change it's ratio on the fly, sort of?
What bother's me is that this has been out for a few years in Europe, but why not in North America?
Hit the nail on the head.
Here is a promo vid for BMW Valvetronic, according to wiki it was introduced in 2001 on the 316ti in Europe of course:
Here is a promo vid for Fiat Multi-Air, which people seem to rave about. They go from DOHC to SOHC and put that fancy electronically controlled hydraulic apparatus:
I think they started in Europe simply because their emission laws are taxed (CO2 charge) as well as strict. (Short Version)
Exage is offline   Reply With Quote
Old 03-24-2011, 08:47 PM   #44
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
At one point in time, Honda was running 8 VPC on the old NR750! That thing sounded so sweet!
Old 03-24-2011, 08:58 PM   #45
Dimman
Kuruma Otaku
Dimman's Avatar
Looks like a V8 that got its pistons squashed together. 2 rods per piston???
Because titanium.
Old 03-24-2011, 09:10 PM   #46
RRnold
2 wheel member
RRnold's Avatar
It's a V4 setup that used an oval piston. The NR750 were like 45K back in the early 90's. The Yamaha R7 was 30K back in 99. Extremely rare bikes of that era.
Old 03-25-2011, 01:42 PM   #47
aliphian
Dreamer
aliphian's Avatar
Drives: Nutless Grocery Getter
The reason that the NR750 nightmare (a cool nightmare though) was ever pursued was because Honda was unwilling to go 2 stroke. They finally decided that 2 stroke was the way to go and the BEASTLY NSR500 was the final result.
It is rumored that the NSR500 seat has 2 grapefruit sized cutouts near the tank. This was done to accommodate the massive balls that were necessary in order to ride it.
"Reality is merely an illusion, albeit a very persistent one."
aliphian is offline   Reply With Quote
Old 03-25-2011, 04:02 PM   #48
xantonin
Mr. Detail
xantonin's Avatar
Drives: 2003 Celica GT-S
2-stroke is powerful. You are literally making twice the power than a 4 stroke.
It's just too bad it's not clean enough to use in other applications.... I'd like to see a 2 stroke diesel-something. Bike, car, anything.
rar
xantonin is offline   Reply With Quote
Old 03-25-2011, 05:43 PM   #49
Exage
GL 86!
Exage's Avatar
How about a ship? Check out the specs on this bad boy:
http://www.emma-maersk.com/engine/Wa...er_RTA96-C.htm
Old 03-25-2011, 06:13 PM   #50
serialk11r
Drives: '06 AM V8V Coupe
I do wonder if they're planning on bringing in fuel injected 2 strokes with valves and maybe like, an electric motor/generator + turbocharger for scavenging, and of course separate lubrication. If stuff like the Lotus Omnivore (has variable compression!) or Ecomotors (not so sure about this for cars, since I read somewhere that relying on the piston to cover and uncover ports is very bad on the rings and is therefore too unreliable for automobiles) eventually becomes mainstream...exciting
Old 03-25-2011, 08:20 PM   #51
xantonin
Mr. Detail
xantonin's Avatar
Yeah!! That thing is awesome
rar
Old 03-25-2011, 09:37 PM   #52
RRnold
2 wheel member
RRnold's Avatar
That's what made GP fun to watch when I was a kid. Highsides were plenty!
Randy Mamola!!
[u2b]90Woms8gb6o[/u2b]
2 strokes are fun to ride, sound awesome but you have to know what you getting into; having the correct gas:oil, not fouling out the plugs, improper jetting; checking the reed valves etc.
Old 03-26-2011, 08:17 PM   #53
Exage
GL 86!
Exage's Avatar
Back to more relevant thread topic... It would be interesting if Toyota/Subaru do a turbocharged version of the FT's engine with a variable geometry turbocharger rather than just a twin scroll.
But I must point out that if they start putting to many technological things on the engine it not only is more expensive but also harder to tune and modify for average joe without breaking the bank.
Old 03-26-2011, 09:48 PM   #54
Archer256
Archer256's Avatar
Drives: TSX
arent boxer engines are hard to mod anyway? if they throw turbo in they could be doing us a favor
Archer256 is offline   Reply With Quote
Old 03-26-2011, 09:59 PM   #55
70NYD
70NYD's Avatar
Drives: RX8 S1
Vgt is the way to go but. It's not that expensive
70NYD is offline   Reply With Quote
Old 03-27-2011, 02:33 AM   #56
Exage
GL 86!
Exage's Avatar
Subaru Forester FB Engine
I personally don't have any experience with a boxer engine but I can hazard some guesses.
Bolt on modifications I think would be relatively easy. Consider the air intake manifold (and plumbing) being on top of the engine, exhaust on the bottom both of which I believe could be easily accessible leading to relatively easy installation of cold air intake, throttle body, intake manifold, header and exhaust components (cat-back and the like).
I think problems start to occur when you want to say swap camshafts, valve springs, spark plugs, (direct injectors,) and work on the head with the valve cover removed (valve lash) because of the limited space between the heads and the sides of the engine bay. I'm not saying that it's not possible, I think that it would however take a lot more time and swearing compared to a strait or small angle V engine.
This is with the engine still bolted on the car of course!
Perhaps Ichi or someone with boxer experience could shed some light for us?
Joke Thread VenomRush Off-Topic Lounge [WARNING: NO POLITICS] 27 07-09-2011 12:44 AM
The Music Thread aliphian Off-Topic Lounge [WARNING: NO POLITICS] 13 03-28-2011 11:35 AM
engine swap thread aspera Engine Swaps 231 03-15-2011 05:10 PM
FT-86 to debut new GPS-track day technology for use on track and GT5! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 17 01-30-2010 11:30 AM
