Drives: 2016 subaru brz insta@black.xira
dash cluster question?
so i had an issue of a fuse blowing out and ended taking it to the dealership and they ended up find a wire grounding out but at the time i had put a higher fuse amp and end up shorting my dash, i have decline repair at the dealer to replace the dash cluster.i took it apart try see any burnt or and indication i can find to replace what needs to be done have it working but didnt see anything unusual so i have found a dash cluster on ebay looks just alike the one i have will that dash cluster work or there a part number i need look for or they all the same i have a 2016 subaru brz.
#2 |
Did some research that if u get a used dash cluster you would have to get it program or clone to the other one
#3 |
Look in the member classified section.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#4 | |
Drives: FT86
If you have a push button start car the dash clusters are swap and go. If you have a key start you will need dealer to re sync security before car will start again |
| The Following 3 Users Say Thank You to steve99 For This Useful Post: |
#5 |
Yes I have push start button . And the car starts without the dash cluster . And I gave it to the dealer so they can program the cluster and 2 process of programming the car .
#6 | |
Drives: FT86
You don't need dealer if your car is push button start, just plug in new cluster and your good to go no resync or programming required. |
| The Following User Says Thank You to steve99 For This Useful Post: | dynomite619 (09-04-2018) |
#7 |
I plug in the new one and it does the same thing as the old one ? Like the gauges don’t turn on it displays nothing . Why is that
#8 |
So I came to a conclusion what it was due to the high input of fuse . I burnt a lead line on the fuse box /main body at this moment I’m doing repairs to the leads and install a jumper .I’m upset knowing what the dealer ship did who knows what the heck the fix they said they fix a wire touching metal And move it too the side . If this is the problem to everything I may need have talk to them wanna know what they repair exactly. they did not fix my problem and wanted me buy a new dash etc ...
#9 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
...and now you want to pin electrical issues on the dealership? Dude, what the fuck. Source for anyone unfamiliar with this saga: http://www.ft86club.com/forums/showthread.php?t=129702
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#10 |
Drives: 2013 Firestorm FR-S
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#11 |
I Know you probalby already learned this but you never us a larger fuse to troubleshoot.
You should use a paper clip. That way the entire wire smokes and is easy to find.
| The Following 2 Users Say Thank You to Grady For This Useful Post: | dynomite619 (09-06-2018), Stang70Fastback (09-04-2018) |
#12 | |
| Instrument cluster lighting question | demariners | DIY (Do-It-Yourself) Guides | 4 | 07-26-2017 05:07 PM |
| CF dash and hood cluster | Lorico | Canada Classifieds | 4 | 05-15-2017 09:38 PM |
| WTB - RHD Dash / Cluster trim - UK | Futaba | Want-To-Buy Requests | 0 | 12-23-2015 12:05 AM |
| Question BRZ Cluster | exam2300 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-06-2015 02:16 PM |
| surprised at how much MORE i like the frs dash cluster | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 12-07-2012 09:09 PM |
