Old 09-03-2018, 10:27 AM   #29
meadowz06
THE CORVETTE KING!
meadowz06's Avatar
Drives: 2013 FR-S, and 2016 FR-S!
I can't wait to see this thing run. Good luck.
2013 Scion FR-S.
2005 Corvette.
meadowz06 is offline   Reply With Quote
Old 09-03-2018, 11:53 AM   #30
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by gtpvette View Post
Quick question regarding the cross member. Nothing there that would melt if I did some welding on it in place is there??? Need a couple of brackets on the front.
My motor mounts are welded to the crossmember and it was done in place.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
gtpvette (09-03-2018)
Old 09-03-2018, 04:28 PM   #31
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
There is nothing heat sensitive there, and I do plan to welding up plates and a few angles to support the load to one of the holes on the front of the cross member.
Example here from Element Tuning:
spitsnaugle is offline   Reply With Quote
The Following 2 Users Say Thank You to spitsnaugle For This Useful Post:
gtpvette (09-03-2018), Sportsguy83 (09-03-2018)
Old 09-03-2018, 04:40 PM   #32
gtpvette
Drives: 2015 FRS - FFR GTM
Thank you gentlemen!
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following User Says Thank You to gtpvette For This Useful Post:
Old 09-04-2018, 10:38 AM   #33
spitsnaugle
Updated my post #6 (linked) by installing the Mishimoto Radiator.
Also checked where the shifter is lining up, its just behind the OEM location, but pretty close:
To note, this is on the third hole of the CX racing mount. I could move forward one hole but I may lose clearance for the sway bar, will check.
The Following 4 Users Say Thank You to spitsnaugle For This Useful Post:
DustinS (09-04-2018), Merc (09-05-2018), Sportsguy83 (09-04-2018), Zer0 (09-05-2018)
Old 09-05-2018, 10:53 AM   #34
VR4EVER
Drives: 2013 LS3 FRS, 3000GT VR4, MKV Supra
You have any updates on what you had to dent in the trans tunnel and how much? You put the trans in with the engine mounted, or pull it all out, put trans on, and put it all back in?
I guess pulling the engine out for you just means lifting the body up lol.
VR4EVER is offline   Reply With Quote
Old 09-05-2018, 11:00 AM   #35
spitsnaugle
I haven't dropped the body all the way onto the engine yet. Been occupied with other areas...
I'm tracking each wire thats unnecessary, marking it, testing it, and will be removing it now that I'm running a LS harness.
The Following User Says Thank You to spitsnaugle For This Useful Post:
VR4EVER (09-05-2018)
Old 09-05-2018, 04:35 PM   #36
VR4EVER
Glad you're doing this so you can tell me exactly what I need to not do
Old 09-11-2018, 11:43 AM   #37
spitsnaugle
been busy sorting through this mess:
If budget allows, going Motec to avoid this would be recommended. I have a Motec PNP LS Kit I'll be listing for sale here shortly.
Update: WiringSpecialties now makes a PNP harness. Get it.
Old 09-12-2018, 05:30 PM   #38
spitsnaugle
Finally lowered the car all the way down onto the engine via the lift.
Spots of interference around the Trans:
UPDATE: I ended up cutting several casting tabs off of the transmission - most notably around the reverse switch and top-sides of bellhousing. Doing that only required some very minor hammering in the tunnel then. Get a ford t56 reverse switch to save room, delete CAGS with a block off for additional room.
Merc (09-17-2018), MRS-Colin (09-13-2018), Sportsguy83 (09-17-2018), Zer0 (09-12-2018)
Old 09-13-2018, 11:46 PM   #39
spitsnaugle
Some more test fitting.
It appears there is practically zero clearance at the reverse switch wiring connector (passenger side).. Found a potential solution of using a Ford T56 reverse switch as it comes out and does a 90* turn immediately. Its: Motorcraft SW5857 Backup Light Switch
It looks like the reverse lockout will clear, but it scratched my trans tunnel so maybe not, I just ordered a spring loaded reverse lockout delete, frees space and no wiring or solenoid is needed there.
Also was hitting this shield for the fuel lines. Created my own bracket and wrapped lines:
Old 09-16-2018, 08:34 PM   #40
spitsnaugle
Got the ford reverse switch in, saves some good space:
Here it is installed, with the surround tabs on the trans trimmed, you can see the tight clearance:
Here is the space with the Reverse solenoid, and CAGs removed:
Here I have the clutch line flipped forward to access. I would recommend installing remote speed bleeder, theres not enough room to access the bleeder.
The Following 3 Users Say Thank You to spitsnaugle For This Useful Post:
glorydays (12-18-2018), Sportsguy83 (09-17-2018), Zer0 (09-17-2018)
Old 09-17-2018, 10:32 AM   #41
spitsnaugle
I designed up a clutch master cylinder recess- It puts the master cylinder roughly 3/4" behind the firewall, freeing space for the valve covers, fixes the shorter distance of the Tilton pushrod.
I've 3D printed a test peice, and hope to have a CNC'd prototype in my hands in a week.
DustinS (09-17-2018), Sportsguy83 (09-17-2018), Zer0 (09-17-2018)
Old 09-17-2018, 10:44 AM   #42
MRS-Colin
Drives: 2001 Impreza 2.5 RS
I designed up a clutch master cylinder recess- working with Nathan (VR4EVER) to have it machined up. It puts the master cylinder roughly 3/4" behind the firewall, freeing space for the valve covers, fixes the shorter distance of the Tilton pushrod.
Awesome! I forgot to mention that I have a 3D printer so if you need parts you can just toss me the file and I'll print it for you. No need to pay the price at Proto
Colin Beck
MRS-Colin is offline   Reply With Quote
The Following 4 Users Say Thank You to MRS-Colin For This Useful Post:
DustinS (09-17-2018), spitsnaugle (09-17-2018), Sportsguy83 (09-17-2018), Zer0 (09-17-2018)
cx racing, ls swap, ls2, pure automotive
2017 BRZ VORSHLAG/PURE AUTOMOTIVE LS SWAP ILLSMOQ Engine Swaps 172 11-24-2022 08:01 PM
LS2 swap by KAB Customs with Pure Automotive Motec Sportsguy83 Engine Swaps 254 10-17-2018 01:45 PM
Pure Automotive's MoTeC Plug and Play V8 Swap Thread Pure Automotive Engine Swaps 51 11-25-2017 12:10 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 05:21 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 02:03 AM
