Old 08-31-2018, 10:09 AM   #1
gtpvette
Drives: 2015 FRS - FFR GTM
Choices On Front Lower Control Arms
I'm looking at installing some aftermarket front lower control arms to provide room for a sway bar in front of the cross member. Doing this as I swapping motors and no room behind cross member. I need some room between frame rail and LCA to get a sway bar arm up and back to reach the link.
That said, I looked at everything I can find but wanted to ask the brain trust here their thoughts.
OK,, first everything I've found,
Megan - Price point is good,,, worry about adjusting
SPL - Nice put pricy
Buddy Club - wont work,, not enough room
Cusco - Wont work not enough room
Racer-X Nice,, a bit pricy but 10% off this weekend.
Also saw Godspeed (no where to buy but ebay) and Hardrace (look like rebranded Megan to me), but have pretty much ruled them out already.
OK for my questions,,,
Anyone know of any other brands I may have missed????
Second,, I remain a bit concerned about how adjustments happen on a few of these. I really don't want to have to unbolt the LCA from the chassis to adjust it (camber/caster) then re-bolt to the chassis. It looks like the Racer-X should adjust on chassis. The Megan and SPL I cant tell for sure if the rear attachment needs to come off for adjustments.
Anyone have thoughts on this??
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 08-31-2018, 10:33 AM   #2
norcalpb
norcalpb's Avatar
Racer-X is good people, give them a shot.
The Following User Says Thank You to norcalpb For This Useful Post:
gtpvette (08-31-2018)
Old 08-31-2018, 12:30 PM   #3
FirstWinter
Drives: Car
SPL. CounterSpace Garage can get them for you.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
Old 08-31-2018, 12:49 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Don't forget about Max Parts.
https://store.partsshopmax.com/shop/...g/ZNC6SAK.html
https://store.partsshopmax.com/shop/...ilinkSteering/
via Imgflip Meme Generator
I LIKE TIRES!
Old 08-31-2018, 03:14 PM   #5
KnightRyderx2
Drives: 2014 FR-S
There is also Wise Fab, a lot of drift guys use them. They have complete suspension kits on there web site but Im not sure if they sell it by the piece. They probably do since people need replacement parts.
KnightRyderx2 is offline   Reply With Quote
The Following User Says Thank You to KnightRyderx2 For This Useful Post:
Old 08-31-2018, 11:08 PM   #6
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
The SPL Parts unit adjusts on car and is what I chose to get - they’re expensive, but they’re essentially automotive porn and are truly works of art. They have tons of adjustability and top notch materials and are what I believe to be the absolute ‘best’ on the market. Of the others on your list, my second choice would definitely be the Racer X units - they’re known to be an excellent company with very good support.
Like @FirstWinter suggested, I’d call @CounterSpace Garage and tell them about your unique situation and see what they recommend - I use them as my go-to source for everything and they’ve really been great to work with.
RJasonKlein is offline   Reply With Quote
The Following User Says Thank You to RJasonKlein For This Useful Post:
gtpvette (09-01-2018)
Old 09-01-2018, 12:57 PM   #7
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
I also went with the SPL for the adjustability and known quality and support. At this point I think my car has all their FT86 bits.
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
gtpvette (09-02-2018)
Old 09-02-2018, 01:27 PM   #8
gtpvette
Thanks for all the thoughts. In the end came down to Racer-X and SPL. Just ordered the Racer-X parts as they are about $150 less with the Labor Day discount and the regular ball joint may cut down on noise and vibration a bit. SPL looks to be a super nice part though.
As a sidebar, The MAX and Wisefab didn't look like they'd give the room needed. Thanks for the info though hadn't seen them in my searches. Megan lost as the control arm needs to be removed to adjust camber.
Let's just hope it'll do the trick for a sway bar.
WTB: Front Lower Control Arms sw20kosh Want-To-Buy Requests 9 08-02-2015 03:24 PM
WTB: Front Lower Control Arms creamsoda Canada Classifieds 1 12-30-2014 03:43 PM
WTB Front Lower Control Arms dizzario Want-To-Buy Requests 0 07-24-2014 08:53 PM
Front lower control arms, which set would you want? Jeff@Racer X Fab Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 12-16-2013 06:05 AM
FRONT lower control arms. J-W Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 10-31-2013 09:24 AM
