Old 08-31-2018, 12:21 PM   #4649
Flow
Drives: DGMBRZ
If you've maintained the car well, the JRSC should be just fine for your car. There are many 100k+ mile JRSC cars running around.
Thank you. Following Anderzz' point about 'choosing my supporting mods properly', if my goal is longevity, are there any supporting mods that you would suggest?
Flow is offline   Reply With Quote
Old 08-31-2018, 05:11 PM   #4650
CSG Mike
CSG Mike's Avatar
good fluids and an oil cooler.
Old 08-31-2018, 06:11 PM   #4651
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
Engine oil cooler, catch can or AOS, one of the upgraded Recirc valves people have mentioned in this thread (I got the forge motorsports one)
Everything else from there is just proper maintenance or preferential upgrades
Sent from my XT1650 using Tapatalk
Anderzz is offline   Reply With Quote
Old 09-05-2018, 04:12 PM   #4652
amcp1
Drives: frs
Just an update at 11k miles with the c30 kit and still happy to report no issues. Debating fabbing up some heat shield for the air filter. In stop and go traffic IAT temp are in the triple digits since summer here sucks. @CSG Mike @Oscar have any thoughts on that?
amcp1 is offline   Reply With Quote
Old 09-05-2018, 11:37 PM   #4653
CSG Mike
CSG Mike's Avatar
IAT temps would be just as high NA.
If you're sitting in stop-and-go traffic, everything in the engine bay is getting hot from lack of airflow.
Old 09-07-2018, 03:59 PM   #4654
mrg666
pessimistic skeptic
mrg666's Avatar
I have replaced my MAF sensor with Denso 197-6160 which can be found for less than $100 instead of stock sensor (22680AA400). The substitute is working great, fits and looks exactly the same. If it works with my FI engine, it should work with any stock engine as well. Denso 197-6160 is more widely available since it is shared by many Toyota models including Corolla. I bought mine from Amazon for $80. FYI ...
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
pgranberg11 (09-11-2018), Teseo (09-24-2018)
Old 09-07-2018, 04:12 PM   #4655
CSG Mike
CSG Mike's Avatar
Datalog it to make sure it's reading and scaled identically!
Old 09-07-2018, 04:46 PM   #4656
mrg666
pessimistic skeptic
mrg666's Avatar
My original MAF sensor is not working properly and even cleaning is not fixing anymore. I will post a datalog with the new sensor here for your comparison. But the engine is revving smooth in the full rpm range and power is restored based on my driving.
Old 09-10-2018, 06:12 PM   #4657
Anderzz
Anderzz's Avatar
Working through my tune right now with Zach at Delicious and the car seems to be pulling timing above 6800 rpm. Any ideas of a source?
Car is at 76k miles, engine oil swapped every 3k with Amsoil 5w30.
Runs on New England 93
C38 kit
DW 700cc Injectors
DW 300 Fuel Pump
Fluidampr Harmonic Damper
HKS EL Head
TRD Catback
Upgraded last week to a Southbend Stg3 Clutch (not that I think that's relevant but trying to be thorough)
Car had plugs and coils done within the last 10k
Old 09-11-2018, 03:44 AM   #4658
sfruski
Drives: Many
What are people seeing for intake air temps on track?
Logs show I'm hitting 125-150F consistently on an 80F day.
sfruski is offline   Reply With Quote
Old 09-11-2018, 09:24 AM   #4659
amcp1
Drives: frs
I've seen 120's on a hot days, 90+. If youre seeing 150 IATs at 80s that doesnt sound right.
The Following User Says Thank You to amcp1 For This Useful Post:
CSG Mike (09-11-2018)
Old 09-11-2018, 12:48 PM   #4660
CSG Mike
CSG Mike's Avatar
30-50F over ambient, max. 150F on a 80F day, something is not right with your car.
Old 09-24-2018, 02:46 PM   #4661
S. Snake
S. Snake's Avatar
Drives: 13' Asphalt
About 10k miles into the JRSC journey.... Nothing to report but smooth running and many smiles per gallon.
S. Snake is offline   Reply With Quote
The Following 3 Users Say Thank You to S. Snake For This Useful Post:
CSG Mike (09-24-2018), funwheeldrive (09-24-2018), Tristor (09-24-2018)
Old 09-27-2018, 04:09 PM   #4662
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
How does the kit feel around town below 5k? Does it feel like a significant bump?
I'm interested in the kit primarily for the top end gains on track, but I'm still hoping its blast to drive at reasonable speeds.
Edit: Bonus question. Before you bought it, did you consider a turbo setup instead? If so, what made you go with the JRSC instead?
mistople is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
