Drives: 2015 Firestorm FRS
Are 2017 BRZ headlights can fit to 2015 FRS? Thanks
As title. Thanks guys
#2 |
Drives: Whiteout FRS
Short answer: Yes
Long answer: Yes. They are the same size as all current headlights. BRZ headlights then to have a plastic tab that you can remove to make it look cleaner after the swap. To get it working properly (electrical-wise) you will need to do some re-pinning of the wires on either the engine harness side or the headlight harness side. You may need new connectors to make it work as well. Splicing may be needed to get the signals to work. |
#3 | |
Thanks.
Looks like alot of work to do. Quote:
| 2017 86 Headlights to 2014 FR-S OEM HID Headlights | Jollibee86 | Electronics | Audio | NAV | Infotainment | 3 | 01-03-2020 07:28 PM |
| Are 2017 BRZ headlights can fit to 215 FRS? Thanks | carlovestela | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 08-29-2018 10:55 PM |
| 2017-18 Brz headlights | shaynek | Want-To-Buy Requests | 0 | 07-31-2018 07:19 PM |
| 2017+ Headlights on FR-S | Jeff86 | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-25-2018 01:21 AM |
| changing from 2015 jdm gt86 headlights to frs headlights | 420zn6 | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 12-16-2016 04:18 PM |
