Old 08-26-2018, 07:45 PM   #169
phrosty
Originally Posted by Tristor View Post
I'm about to attempt this as part of my installation of an ATF cooler
Which cooler?
phrosty is offline   Reply With Quote
Old 08-26-2018, 07:55 PM   #170
Tristor
Tristor's Avatar
Originally Posted by phrosty View Post
Which cooler?
The Stark Performance cooler. It's a Setrab core that mounts in the fog light well. I've already got the cooler mounted, I'm currently working on routing lines, but I'm not entirely sure what the correct path to follow is. Anyway, once I get it all routed and installed, then I have Redline D6 ATF to go in
I added a DIY guide for how to do the AFT fluid change to the DIY forum from the experience.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
Busybee (10-25-2022)
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
Mt transmission fluid swap bdanisi Engine, Exhaust, Transmission 8 02-08-2013 02:09 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
