Old 08-25-2018, 01:16 PM   #1
gt86yasss
Drives: White 86
SC fitment with 2017 model
Found a used Edelbrock SC kit for sale on this forum, but the kit was off a first generation BRZ and I was wondering if the kit will fit on my car. Has anyone tried to install a Edelbrock SC kit from the first generation on a post-2017 model? Thanks.
gt86yasss is offline   Reply With Quote
Old 08-26-2018, 12:13 AM   #2
Mo
Drives: 2017 Toyota 86
I also drive the 17+ model 86. I was told by ft86speedfactory that the edelbrock SC kit would be compatible with our year and model. However, I’d like to know if there are more options and if anyone has supercharged their 17+ models.
Mo is offline   Reply With Quote
Old 08-26-2018, 10:05 AM   #3
J1Avs
Drives: 2018 BRZ tS
Folks have installed Cosworth, Eldebrock, Sprintex, and JSRC on 17+’s that I have seen so far. I’m personally going to go JSRC for my 18 tS next year. From what I’m told, the newer Eldebrock Kits have been retrofitted to work with the 17+, so there may be some fitment issues with an older kit.
J1Avs is offline   Reply With Quote
Old 08-26-2018, 08:56 PM   #4
gt86yasss
Drives: White 86
I was told that the 2017+ alternator could be in the way and switching to the older alternator will make it work. Wonder if someone here can share their experience.
Old 08-27-2018, 11:15 AM   #5
PhyrraM
Drives: '17 BRZ PP, old Legacy SSs and SVXs
I have had the Harrop SC on my 2017 for over a year and 23K miles. It can be installed as-is, but a slight modification (Dremel) to the blower snout gives the alternator sense wire a bit more breathing room.
PhyrraM is offline   Reply With Quote
Old 08-27-2018, 05:23 PM   #6
CSG Mike
CSG Mike's Avatar
Edelbrock and Jackson kits both fit 17+ cars.
Make sure you get a ***NEW*** kit, or you will have to modify/retrofit older kits.
PM me to order.
2017 at model k00d definition file kdyg123456 Software Tuning 9 10-13-2018 10:24 PM
2017 Track mode on older model Bobster Engine, Exhaust, Transmission 17 12-03-2017 10:34 PM
My 86 Model 2017 cholaquepita Electronics | Audio | NAV | Infotainment 3 07-18-2017 10:01 AM
Manual Trans gearing for 2017 model ? ToySub1946 Engine, Exhaust, Transmission 13 04-03-2017 03:41 PM
2017 Model Year Improvements FiReStorm2013 Scion FR-S / Toyota 86 GT86 General Forum 353 03-11-2016 03:07 PM
