Old 08-22-2018, 12:09 PM   #29
UNCC_BRZ
UNCC_BRZ's Avatar
Drives: 2013 WRB BRZ Limited
I am hearing a similar noise to this, it is only when the engine is cold, and gets worst up to about 3000 rpm, then goes away. And it is completely absent when the engine is fully warm. I replaced the belt <5000 miles ago, so I really doubt that its that. The TOB and clutch was replaced about the same time.
2013 WRB BRZ
Gruppe-S headers|| Borla Cat back||OFT Stage 2+
UNCC_BRZ is offline   Reply With Quote
Old 08-22-2018, 10:38 PM   #30
Diegov
Drives: 12 328i f30 FBO, 135i n54 FBO, PI,
Originally Posted by highway7 View Post
Doesn't sound like HPFP.
Can be TOB, does noise change with clutch in/out?
You can try removing belt and turning each accessory or idler by hand and listening for a squeak
Im going to tell her to do that as well.
Diegov is offline   Reply With Quote
Old 08-22-2018, 10:46 PM   #31
Diegov
I think for hers like its a cold start as well sometimes when its warm it does it need to make sure again since it isn't my car lol.
Old 08-22-2018, 11:25 PM   #32
If it's consistently during cold start, then most likely the belt is slipping at the alternator pulley. Load on the alternator is greatest when it's dumping current back to the battery right after starting the engine.
You might also be able to get it to squeak by turning on all the lights and cranking the cabin fan on high as it idles.
Diegov (08-25-2018)
Old 08-25-2018, 06:06 PM   #33
Diegov
So found the problem it was pulley that had some play in it we took it off and it was just no bueno but we cleaned it a tad bit and put it back on and made no noise like at all. She got the pulley though just waiting on it to come in the mail lol.
Old 08-25-2018, 06:20 PM   #34
Fuck yeah.
Diegov (08-25-2018)
Old 08-25-2018, 06:21 PM   #35
I recommend keeping it to short trips until you replace it.
Could frag at any moment.
Diegov (08-25-2018)
Old 08-25-2018, 09:25 PM   #36
Diegov
Fuck yeah.
Im dead lol but yeah the pulley should come in this tuesday ill keep you guys updated. Thanks again guys much appreciated for the help.
The Following User Says Thank You to Diegov For This Useful Post:
Ultramaroon (08-26-2018)
Old 08-30-2018, 08:52 PM   #37
Diegov
Ok so update I thought we found the problem she ended up buying both idler pulleys and lightweight alternator pulley and water pump one as well and still does it. Any ideas guys.
Idle Noises (*Not Chirping*) tyynichols Issues | Warranty | Recalls / TSB 16 03-09-2018 09:37 AM
Engine idle chirping (cricket) noise poll. Hanzo Issues | Warranty | Recalls / TSB 5031 05-18-2017 10:41 AM
Engine idle chirping (cricket) noise poll. Hanzo BRZ First-Gen (2012+) — General Topics 229 02-16-2016 02:21 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Anyone worried about chirping/idle/taillight condensation issues? JDM-dono AUSTRALIA 31 07-21-2012 02:12 AM
