Old 08-24-2018, 12:53 AM   #15
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
That's absurd. Who has light in their garage?
Old 08-24-2018, 01:18 AM   #16
The light reflected off of that beer machine is more likely coming from a window just out of view.
I remain skeptical.
Impureclient (08-24-2018)
Old 08-24-2018, 01:21 AM   #17
Captain Snooze
Drives: Red Herring
I remain skeptical.
When roses are about to bloom new flowers it is imperative that they have good exposure to sun. If you are growing roses in your garage you need a bud light.
Spuds (08-24-2018)
Old 08-24-2018, 01:30 AM   #18
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I am Spuds and I approve this thread.
ajcarson11 (08-27-2018), CSG Mike (08-24-2018)
Old 08-24-2018, 01:37 AM   #19
Ah. I was unaware that I could grow roses in my garage. Now I may never leave.
Old 08-24-2018, 02:30 AM   #20
CSG Mike
CSG Mike's Avatar
@Captain Snooze well played sir, well played.
Captain Snooze (08-24-2018)
Old 08-24-2018, 04:20 AM   #21
churchx
churchx's Avatar
Drives: 2014 GT86
BTW, not sure if it's worth to use as "indicator" .. parking brake light can light up on dash when brake fluid level is low (normal fluid level with new pads -> wear to 2/3rds down -> brake fluid drops to min or below level -> indicator lights up, first from time to time, then, if nothing is done (like adding some brake fuel till normal level to compensate pads material thickness wear), is lit all the time).
Old 08-24-2018, 04:26 AM   #22
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Originally Posted by ermax View Post
If you’re curious how much pad is left then just look at the pads.
I just swapped my stop tech street pads back to stockies mostly because of break dust. Just here to confirm the difference was due to design and not wear. First time with this stuff. Thanks guys.
Spacemane969 is offline   Reply With Quote
Old 08-24-2018, 04:32 AM   #23
Spacemane969
Good to know thanks! Mine has been flashing, I stupidly assumed the light was indicative of ABS activating. Should I just go for a full flush at this point?
Old 08-24-2018, 05:02 AM   #24
churchx
churchx's Avatar
Drives: 2014 GT86
I just topped up till max level in tank again, which shut off parking brake light, and drove pads (almost) till end of them (of course, one will need to remove some excess fluid, after one changes pads to new ones, of full thickness).
But still, i wouldn't "rely" on this indicator to tell pad wear. Better check their state/wear properly (alongside other things/systems of car/their state & wear to inspect) at very least prior trackday. It's helpful if you keep some notes (eg. installed pads of type # at ##.##.#### date, drove # hours/days at # track).
And alongside extra tires, some oil bottle, drinks, basic toolset, air pressure gauge & pump, take to the track also hydraulic jack, needed wrenches, extra pad set, fluid bottle, if you wear down current ones too fast (or find out if you will be able to get them changed on site, if needed). Brake subsystem is about the most important in any car. Especially if it is abused at track loads.
As all pads are compromise of sort, so many change to track pads prior track day, and to street ones - after, to have best for purpose every time, instead of dealing of shortcomings of universal/hybrid pads. Pad change is good chance to inspect their state too (and to add extra notes during change on how much pads material in mm you wear down of specific pads on specific tracks on specific tires or car setup and for how long). Also you can note what fluid and when you flushed. And if/after what you boiled it up .
Tcoat (08-24-2018)
Old 08-24-2018, 12:41 PM   #25
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Is the pedal squishy? How many miles?
Old 08-26-2018, 07:46 PM   #26
Spacemane969
Feels a tad bit, like 50 of the travel is air sometimes but I think I'm just used to the twitchiness of the street pads I tried. 85k miles
Old 08-27-2018, 12:13 AM   #27
finch1750
finch1750's Avatar
When was the last time you bled them? If its been more then 30k miles I would start there
Old 08-27-2018, 01:18 AM   #28
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
What if, and this may sound crazy but, what if you left your eyes open and looked at the pad as you removed and felt it? Then there would be no risk of someone swapping the pad with a cheap replica as you judged its remaining service life.
Darn you caught on to the brake pad bandits again!
E-Brake issue "clunking noise" when pulling the e-brake while rolling. Kinzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 06-20-2018 10:14 PM
I drive fast because the car feel "slow" fang_gt86 Scion FR-S / Toyota 86 GT86 General Forum 65 05-04-2015 01:06 PM
Switching back to 17" Wheels from 18" for acceleration feel? bobsacamenoh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-30-2014 07:35 PM
Driving "feel" fduboss302 BRZ First-Gen (2012+) — General Topics 29 04-11-2014 02:52 PM
Why does every 86 owner feel entitled to a "review"? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 22 07-11-2013 12:23 PM
