View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 07-12-2012, 11:08 PM   #295
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by excited86 View Post
which one are you using?
Valvoline 2 stroke RACING oil.
Here in Oz it's got a pic of a racing motorcycle on the front.
Spec - jaso FC
api TC
iso GD
sierra is offline   Reply With Quote
Old 07-12-2012, 11:09 PM   #296
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
I'm using the Lucas Oil variety because it's low-ash and smokeless. It's used in racing snowmobiles and the like.
Link: Lucas Oil 2-Cycle Oil
I did get away with using 50ml (less than 2oz) of this as a fuel additive. That's nearly 1:1000 ratio to fuel.
cobrabyte is offline   Reply With Quote
Old 07-12-2012, 11:10 PM   #297
sierra
Originally Posted by Thunderchicken View Post
Something came to mind when I ethanol popped up and maybe the HPFP is causing the ethanol to draw in moisture in to the HPFP as it compresses the fuel and washing the lubrication from the fueling system. It may mean the use of a fuel stabilizer to keep the moister down and all parts well lubricated. It will only get worse when they up the ethanol to 15%.
If that was the case then the 2T wouldn't work.
Old 07-12-2012, 11:14 PM   #298
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
how about toyota/subaru changing the hpfp to fix this issue..?
imravenit is offline   Reply With Quote
Old 07-12-2012, 11:25 PM   #299
sierra
As I mentioned, I only guessed at the 1:500 ratio. Don't forget it has other benefits if you intend keeping the car for a long time.
The Lucas oil sounds alright. Not sure what the air cooled spec means?
I couldn't find the Valvoline racing oil we have here but the outboard version sounds ok.
Premium base stocks are blended with a modern ashless detergent additive package to provide fortification for maximum performance in outboard engines.
http://www.valvoline.com/products/co...-engine-oil/16
Old 07-12-2012, 11:31 PM   #300
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
like i mentioned cant royota/subaru just replace the hpfp?
Old 07-12-2012, 11:34 PM   #301
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
That would prove expensive for all the vehicles shipped to the US by Toyota and Subaru.
My guess is that they are going to look for more of a precise, less costly fix first. I'm okay with that as long as it gets fixed.
Chewie4299 is offline   Reply With Quote
Old 07-12-2012, 11:37 PM   #302
Razz
Razz's Avatar
Drives: Fast
Correct synthetic or snowmobile oil.
Otherwise just get the pre-mix oil that Rotory heads use
http://shop.pettitracing.com/fluids/...e/c-10262.aspx
Razz is offline   Reply With Quote
The Following User Says Thank You to Razz For This Useful Post:
cobrabyte (07-12-2012)
Old 07-12-2012, 11:39 PM   #303
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
i think it should be really address now.. And they should act fast before they sell more of these cars with this problem.. im thinking toyota will find a solution and hopefully we can just get it fix as part of the warranty..
Old 07-12-2012, 11:41 PM   #304
sierra
You can bet they are modifying the fuel systems for the future imports and will almost certainly be replacing the offending parts.
What else can they do?
Old 07-12-2012, 11:44 PM   #305
Thunderchicken
Drives: 2008 STi
I don't follow your logic on that one. 2T would act as fuel stabilizer because the oil won't allow the ethanol to attract water particles basically what SeaFoam does.
Thunderchicken is offline   Reply With Quote
Old 07-12-2012, 11:50 PM   #306
cobrabyte
cobrabyte's Avatar
Thanks for the link. The Pettit stuff may be a better way to go since it's been proven in gasoline engines for quite some time.
I did the math and it looks like it'll only cost $0.65ish per fill-up if you purchase the 1 gallon container.
It's a hassle and I gotta believe the guys at Toyota are going to address this with a warranty recall but, in the mean time...
Old 07-13-2012, 12:07 AM   #307
sierra
Hi TC,
You said "Something came to mind when ethanol popped up and maybe the HPFP is causing the ethanol to draw in moisture in to the HPFP as it compresses the fuel and washing the lubrication from the fueling system. It may mean the use of a fuel stabilizer to keep the moister down and all parts well lubricated. It will only get worse when they up the ethanol to 15%."
I pointed out the same process would then wash the extra 2T lubrication from the fuelling system as was the case with the lubrication in the fuel in the first place.
Unless the extra lubrication is enough to overwhelm that process?
Old 07-13-2012, 12:22 AM   #308
Thunderchicken
Drives: 2008 STi
Hi TC,
That would be incorrect because the oils surround the ethanol molecules and prevent the ethanol the ability to attract H2O molecules. The oil in the fuel plus the 2T oil would lubricate the HPFP and stop the excess rubbing of the internal parts.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
