Old 08-21-2018, 10:22 AM   #19517
Roth
Roth's Avatar
Drives: 2013 Gt86
First drive with the eibach pro kit. Lowered 1". Still need to get the alignment done, but very happy by far
Roth is offline   Reply With Quote
The Following 3 Users Say Thank You to Roth For This Useful Post:
MJones_RB (08-21-2018), Tcoat (08-21-2018), ToySub1946 (08-23-2018)
Old 08-21-2018, 10:27 AM   #19518
Originally Posted by RToyo86 View Post
Had the dealer look at my tail light as water somehow got inside the lens. They took pictures to send off to Toyota for a warranty claim.
Wow this hasn't been a problem for several model years. Be interesting to see what they have to say.
Old 08-21-2018, 07:25 PM   #19519
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
They had a very similar perplexed response to the issue as well.
I Initially tried to polish it out assuming they were stuck on water spots, but to no avail.
I'll snap a photo of it later this week when I have a chance to clean the car.
Old 08-21-2018, 07:27 PM   #19520
Ashikabi
Ashikabi's Avatar
if you used a mechanical buffer you may have polished off your UV clear coat. Also, the condensation could just be from a poorly installed gasket
Old 08-21-2018, 07:55 PM   #19521
RToyo86
RToyo86's Avatar
I hit it quickly by hand with a soft ply microfiber cloth.
Old 08-21-2018, 08:10 PM   #19522
Ashikabi
Ashikabi's Avatar
That'll be fine then
The Following User Says Thank You to Ashikabi For This Useful Post:
RToyo86 (08-21-2018)
Old 08-22-2018, 10:47 PM   #19523
RToyo86
RToyo86's Avatar
I sanded the oil dip stick so I can get a more accurate reading.
Original oil change took 5.4 quarts as per the bottle reading.
The level was 3MM below the Full line, added 150ml as per the level on the asmoil bottle, then it read 3-4MM above. Sanded it and rechecked at the gas station and a separate parking lot. Still reading the same.
That is recommended as per manual, There must have been a tiny bit of oil that didn't come out during the drain process.
EDIT: got underneath this morning and corrected the levels, sitting perfectly now
Old 08-23-2018, 06:10 PM   #19524
new2subaru
Weight Weenie
Drives: 15 FR-S
Added some closed cell foam to the knee pads (For Track) Used gorilla tape lol
Ghetto but should work temporarily.
Old 08-23-2018, 10:12 PM   #19525
arxm
Drives: 2013 FR-S, 2023 BRZ
Originally Posted by Enkrow View Post
I wouldn't go grill-less. The grill protects your radiator, intercooler, etc.
i don't know about that honestly, small debris is gonna fly through anyway like rocks, salt or whatever but anything big enough that would damage the rad etc would just go straight through the grill wouldn't it? ive hit a small squirrel and that thing pushed through the grille and i had to pop it back into its clips
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 08-23-2018, 10:51 PM   #19526
Ashikabi
Ashikabi's Avatar
But it didn't go through your radiator. I agree at least some small debris will penetrate at full speed, some will bounce off the grill. Larger impacts would at least be mitigated. I dunno yet... Nothing says race car like no grill and random heat exchangers up front but if I hit a bird it would be pretty inconvenient
Old 08-24-2018, 11:37 PM   #19527
arxm
i guess you're just gonna have to keep a sacrificial oil cooler up in front of the rad/intercooler
Old 08-25-2018, 02:03 AM   #19528
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
I made my last payment on the FRS Wednesday…..but it just sunk in today that I'll have that much less of an expense every month to not have to deal with. It probably won't fully sink in for some weeks from now.
**Trying to not watch any youtube on '14-'16 Cayman info , and doing my best to continue to enjoy the FR-S
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
The Following User Says Thank You to Adam_L For This Useful Post:
stevesnj (08-26-2018)
Old 08-25-2018, 07:42 AM   #19529
Ashikabi
Ashikabi's Avatar
Spend the money on race car parts
Old 08-25-2018, 07:44 AM   #19530
Ashikabi
Ashikabi's Avatar
It's getting crowded. It was just an oil cooler but now I have a transmission cooler too. Gonna be tough to fit a turbo intercooler in a few years...
