| Software Tuning Discuss all software tuning topics. |
#15 | |
Drives: FT86
no you don't have to change VIN its just a reference, not used for security sync. The vin is in different chip in ecu , imobilier doent care in vin different Car will start and run fine with different vin. just do the 30 minute (at least 30) loop 4-13 with ignition FULL on not accessory. CEL light should flash entire time |
#16 |
Drives: 2015 Scion FR-S
Bought an ECU off eBay. Noticed it is an "HE" vs an "HY" unit and my FR-S is the 6 speed automatic (Seller didn't say what car except 2013-2015 FR-S). Swapped the units with the battery disconnected. Now the car starter won't engage??? Was wondering if the unit was from a manual car and it was looking for a clutch disengagement signal. Anyone know about this and how to correct it (swapped the original back in and it starts fine)?
#17 |
Did you follow Steve's procedure?
#18 |
Was Steve's procedure just turning the ignition to on for 30 minutes without starting it? All the lights came on but wouldn't engage the starter.
Sent from my SM-G955U using Tapatalk |
#19 |
No. Read again. Did the CEL flash for that 30 minutes? You have to jumper a couple leads before turning on the ignition.
#20 |
"just do the 30 minute (at least 30) loop 4-13 with ignition FULL on not accessory. CEL light should flash entire time"
So......short pins 4 & 13 then turn on the ignition without starting and watch for CEL light to flash for at least 30 minutes? Is there a pinout of the ECU is this covered in another thread? Thanks for the info and patience! |
#21 | |
| Tags |
| ecu, flash |
| BRZ locked me out while running | Brooklyn | Issues | Warranty | Recalls / TSB | 16 | 12-15-2017 08:32 AM |
| Have to replace entire assembly to replace fuel filter? | tobkin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 08-04-2017 02:26 PM |
| Threads locked | Wonderbar | Site Announcements / Questions / Issues | 4 | 02-11-2016 10:42 AM |
| To replace rims or not replace? | unlimited86 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 23 | 09-21-2015 12:12 PM |
| car locked me out | grodenglaive | Issues | Warranty | Recalls / TSB | 29 | 02-22-2013 08:24 PM |
