Old 08-13-2018, 09:05 PM   #1
Jcas
Jcas's Avatar
Drives: 2013 Limited Subaru BRZ
Smart to install new coilovers and wheels at the same time?
So, I recently got new coils and wheels and i was wondering if it's a good idea to just install them at the same time or do one at a time and get an alignment each time. I know it sounds like a dumb question i'm just unsure. Thank you in advance!
Jcas is offline   Reply With Quote
Old 08-13-2018, 09:09 PM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
get it all on and get aligned. Done.
Mr.ac (08-13-2018), Spuds (08-14-2018)
Old 08-13-2018, 09:37 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
You don't need an alignment for wheels, so it's up to you what order you want to do it in.
Old 08-13-2018, 09:42 PM   #4
new2subaru
Weight Weenie
Drives: 15 FR-S
I prefer to one mod at a time so you can feel the difference/no difference each one makes.
As stated, wheels don't need an alignment.
Old 08-14-2018, 12:02 AM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Get your wheels put on, then install your coils, now get an alignment. You are done!
There is a good DIY on how to install coils in the DIY sectuon.
I LIKE TIRES!
Old 08-14-2018, 12:17 AM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You don't get an alignment with just new wheels unless you want to adjust them for fitment in some way, but it's easier to put the new wheels on when you install the new coils to save time. Align afterwards
Old 08-14-2018, 01:01 AM   #7
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
For me, I did this path, Coilovers, alignment, wheels. Since I was putting on 18X9.5 +38 with 255 35 R18, I needed coilovers installed first. These wheels would rub on stock suspension. So I couldn't put wheels first.
I would get the alignment after wheels, because once you install the coilovers and then put the wheels on, you may want to run more negative camber to tuck the wheels more.
I regret getting an alignment before the wheels because I want to run more negative camber after I put in my new wheels.
You also might want to consider some LCAs for the rear, you don't need anything fancy, but it'll be best for tire life to reduce the camber in the rear and have 0 toe. I have SPC LCA with toe kit and I minimize the camber in the rear (-1.1) and with the toe kit, I aligned it to pretty close to 0 toe. I have 0.08 total toe in for stability purposes.
N1rve
The Following 2 Users Say Thank You to N1rve For This Useful Post:
FRSBRZGT86FAN (08-14-2018), new2subaru (08-14-2018)
Old 08-14-2018, 08:54 AM   #8
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
How exactly does someone install coilovers with the wheels on?
The Following User Says Thank You to Spuds For This Useful Post:
Leonardo (08-14-2018)
Old 08-14-2018, 11:00 AM   #9
Yoshoobaroo
TRACKBREAD
Easy, just drop the subframes!
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Spuds (08-14-2018)
Old 08-15-2018, 03:21 AM   #10
Enkrow
Enkrow's Avatar
I'd install them at the same time, then get an alignment. I don't see a reason to create more work for yourself.
Enkrow is offline   Reply With Quote
Old 08-15-2018, 11:25 PM   #11
86MLR
86MLR's Avatar
Tyres will give more grip/quicker laps than coils
With that chuck both on while the car is on stands, then get an alignment
Profit
Old 08-16-2018, 09:34 AM   #12
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
You're better off doing everything at once to save yourself time and effort. I hate jacking my car up, getting stands and then taking all my wheels and tires off so I would get it done in one go.
Trueweltall is offline   Reply With Quote
First time Rocket bunny kit fitment/install vincelive123 Cosmetic Modification (Interior/Exterior/Lighting) 10 09-16-2016 05:25 PM
First time Springs Install... Help please VakaGT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 11-28-2014 08:58 PM
Install time trd sway bars? Frs32907 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-28-2014 12:11 PM
Parrot Asteroid Smart Review & Install mit_peid Electronics | Audio | NAV | Infotainment 62 06-19-2014 12:15 AM
