#12601 | |
Famous Potatoes
Drives: '15 ultramarine
I have had boats and stored cars with success over the last 30 years with Sta-bil. |
#12602 |
Drives: GR Corolla
Wait, I'm assuming you used the marine one in the boat? For some reason that formula doesn't gel up like the automotive one????
#12603 | |
Famous Potatoes
I have used the marine stuff before, but most of the time I just use the regular sta-bil. I use it in my boat, and my golf cart at the lake. I have never had a problem. Things have always started right up. |
#12604 |
Drives: GR Corolla
I'll try to read up on it some more and try to figure out why a lot of people had gelling issues. Cuz I do want some type of FS in the tank.
#12605 |
The modern evap systems do not collect moisture so there is nothing to condense. Once the cap is on the only moisture to evaporate is what is already in the tank and that will be such a small amount it would be impossible to even measure. There is no new air being introduced to the system to allow more moisture in. Half tank will be no issue at all.
#12606 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Point of order.
What replaces the volume as fuel is used, causing the gauge go down? Perhaps it's phlogiston. I'm not up to date on these modern thingummys.
"I gotta rock." -- Charley Brown |
#12607 | |
Drives: GR Corolla
#12608 | |
Much of the concerns about storing vehicle with fuel in them come from the old open air vented system that would let moist air in and fuel would evaporate out leaving additives and such behind in much higher quantiles that they should be. The closed loop evap systems stop both these things (or at least slow them down so much they may as well be stopped) from being a problem. As long as you are not leaving the car for years you will be fine.
| The Following User Says Thank You to Tcoat For This Useful Post: | Kaotic Lazagna (08-13-2018) |
#12609 | |
In other words the fuel system sucks.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | BigFatFlip (08-14-2018), Kaotic Lazagna (08-13-2018) |
#12610 | |
Drives: GR Corolla
https://www.amsoil.com/shop/by-produ...?code=AOBBE-EA or, just gently drive the car and use up the gas again before filling up and driving hard. Thanks for the clarification and explanation of modern cars' fuel systems. |
#12611 |
Geo Tyrebighter Esq
Yeeeeaahhh ... the evap system prevents gasoline vapors or other gases from escaping the loop.
However, it does draw in ambient atmosphere when fuel is drawn from the tank. H20 comes in with it however much that it doesn't go back out even harder. There's no dry nitrogen or argon doing anything here. That'd be more like having to add blue pee to your diesel systems to keep it running. Observe that there is no venting in the spiffy diagram. That would implode the gas tank by the time you used a 1/4 of the fuel. Aircraft mfg. would be all over it if they could make it work reliably. Still have to cup the lowest point of the fuel system to check for water before flight.
#12612 | |
Drives: GR Corolla
#12613 |
Geo Tyrebighter Esq
Stop worrying? Fill up before you hard park it.
Don't over fill. Click, click, click up to the fuel neck and you'll flood the evap can. That's bad. edit: Fuel degradation results primarily from random atmospheric ions of one sort or another. If the tank is full in a closed system (inoperative) for a year or two, you should be fine. Water in the bottom of a plastic gas tank won't amount to a hill of beans. Splashing about with alcohol once back on the road will remove it along with the old gas.
| The Following 2 Users Say Thank You to bcj For This Useful Post: | BigFatFlip (08-14-2018), Ultramaroon (08-13-2018) |
#12614 | |
Hi.
Drives: 14' Asphalt
That road fought the battle and won again. It has won many times over the years, unfortunately. Tragic and chilling. Many other roads can say the same.... Guess it's the chance we take in the name of spirited driving...
14' ZN6
92' RN80 81' RN38 "Shitbox" I like Toyota's IG: undefindedt |
| *Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread | peazs | CANADA | 1397 | 06-28-2019 12:17 PM |
| NorCal (Bay Area) AutoX Thread! | BlaineWasHere | Northern California | 1398 | 02-08-2019 01:27 PM |
| Mid-Atlantic Chat Thread | clevrname | Mid-Atlantic | 5296 | 08-25-2016 01:30 PM |
| FS: Five Axis Five:AD Aero Kit w/ Rear spoiler Whiteout - NorCal Bay Area | firebert | Exterior Parts (Aero, Lighting, Etc.) | 13 | 01-08-2013 11:07 PM |
| NorCal Bay Area ecutek tuning | AsphaltLover | Southern California | 0 | 11-11-2012 12:38 AM |
