Old 08-12-2018, 01:05 AM   #29
Originally Posted by new2subaru View Post
Debbie Downer, eh...
Thanks for the heads up, Ultra. This is the first I've heard of these issues except #3 and heard that it was fixed.
If I was in the market, I would install one without hesitation and would just keep an eye on those areas.
new2subaru (08-12-2018)
Old 08-12-2018, 03:52 AM   #30
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by weederr33 View Post
I think the '17+ FA20 looks pretty cool with the new manifold. If we are going purely off aesthetics.
Yes the new intake manifold looks nice. How does it cope with the dirt?
Old 08-12-2018, 09:30 AM   #31
mrg666
pessimistic skeptic
mrg666's Avatar
I think Vortech nailed it
I agree Vortech looks very OEM. I also like how JRSC looks. Not as much plastic covers and black coating but the simplicity is genius. Adding the supercharger opened space in the engine bay! I have replaced the crank pulley without removing the compressor and air filter, for example.
The Following User Says Thank You to mrg666 For This Useful Post:
Old 08-12-2018, 09:38 AM   #32
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
It loves dirt but since it's red, it doesn't show it unless it's really dirty.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
nikitopo (08-12-2018)
Old 08-12-2018, 11:08 AM   #33
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
The Following 2 Users Say Thank You to bcj For This Useful Post:
humfrz (08-12-2018), Ultramaroon (08-12-2018)
Old 08-12-2018, 01:55 PM   #34
WOW! I'd almost forgot about that OHV horizontally-opposed, six-cylinder engine.
Old 08-12-2018, 02:21 PM   #35
mkodama
86 Challenge
Drives: 2017 BRZ
I was reading lately about the difficulty to minimize the height of the engine and the different components. The target was to place the engine as lower and back to the driver as possible. Normally, on a mass produced engine the specification accuracy of a component can be in the range of 0.1mm. So, a component of 10mm is OK to be 10.1mm. This was changed on the particular engine to something like 10.00001mm. Additionally, the minimum spacing between parts was changed to just 2mm. So, it wasn't that easy to achieve the following:
Source: https://car.watch.impress.co.jp/docs/news/1026907.html
The accuracy comment is false, but I’ll attribute it to a poor translation from Japanese. 0.001mm is 1 micron, and 1 micron is what vapor discharge coatings are measured in. 0.1 micron are the units that roughness of a cylinder bore might be measured in.
The number with all the zeroes is probably a joke about the designers’ passion and attention to detail.
mkodama is offline   Reply With Quote
Old 08-12-2018, 02:24 PM   #36
mkodama
86 Challenge
Drives: 2017 BRZ
Originally Posted by steel86gt View Post
only wished they would have used a picture from the current manual transmission MY17+ with the red manifold however....
I seriously wish they would have.
Old 08-12-2018, 03:27 PM   #37
Atmo
Drives: TBA
Atmo is offline   Reply With Quote
Old 08-12-2018, 03:42 PM   #38
Atmo
Drives: TBA
Old 08-12-2018, 03:47 PM   #39
Atmo
Drives: TBA
Old 08-12-2018, 04:48 PM   #40
new2subaru
Weight Weenie
Drives: 15 FR-S
There are some nagging flaws in execution that I find extremely annoying.
1. The filter mount is supposed to also act as the divider between the clean and dirty sides of the airbox. Unfortunately, the seal quickly falls apart allowing LOTS of dirty air through. The first time I saw one, I was shocked to see the condition of the leading edge of the compressor blades.
2. The bellows/boot that joins the airbox to the compressor is unbelievably lame. The business side of the hose clamp included with the kit interferes with the folded pattern of the boot. Actually scrubs against it.
3. The pipe just upstream of the throttle body rubs against the alternator bracket.
On the other hand, I agree that they nailed it both aesthetically, and I hope with their wet sump planetary gearbox. I don't know how well they hold up long term but I want the design to be as stout as it looks. Gorgeous.
Fixed!
The Following User Says Thank You to new2subaru For This Useful Post:
Old 08-12-2018, 04:50 PM   #41
new2subaru
Weight Weenie
Drives: 15 FR-S
Agreed. IF I end up going SC it'll be a toss up between the Vortech and Jackson.
Old 08-12-2018, 05:10 PM   #42
mrg666
pessimistic skeptic
mrg666's Avatar
Good luck! Let me know if I can help with your JRSC questions.
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 09:36 PM
MVP Track Time 2014 Road Atlanta Track Dates Feffman Southeast 2 03-27-2014 06:51 AM
Drivers, start your engines (PIR track days starting March) torqdork Northwest 31 03-13-2014 03:27 PM
MVP Track Time 2013 Road Atlanta Track Dates Feffman Southeast 7 11-05-2013 11:36 AM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
