Old 08-02-2018, 03:27 PM   #449
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Originally Posted by celek View Post
I didn't bother to read everything, I just had this pop up at 60k miles on a hot day with some spirited driving.
Reset it and it has not come back.
My assumption and information from a friend is that since Cyl 1 is on the front corner by the Header its getting cooked and over heated.
Change it and wrap it. I can confirm, it will come on again and when it comes on you lose performance power
Dr. BRZ is offline   Reply With Quote
The Following User Says Thank You to Dr. BRZ For This Useful Post:
celek (08-07-2018)
Old 08-07-2018, 12:34 PM   #450
celek
Resident Gear Head
celek's Avatar
Came back only at High RPMs, duty cycle is dying but if I keep it below 6000 its fine.
I did take a laser thermometer to each coil pack after a NON spirited drive home.
#1 195 degrees
#2 140 degrees
#3 165 degrees
#4 160 degrees
#1 definitely gets cooked by the header location.
celek is offline   Reply With Quote
The Following 2 Users Say Thank You to celek For This Useful Post:
Bonburner (08-07-2018), Lonewolf (08-11-2018)
Old 08-09-2018, 01:55 AM   #451
ZZT86
ZZT86's Avatar
Drives: BR86
^^ interesting those COP temperature readings, yet for me it was #2 that recently threw a DTC/CEL on track but noticed no loss of power/performance ! To further confuse the issue my 1/2013 car runs E85 OFT/OFH which is TC1 ceramic coated in & out, engine is stock apart from oem oil cooler, track day air ambient temps was 18C/65F, oil & engine temps were normal hot !
How old were the spark plugs when these coilpacks were replaced I wonder? Could it be as simple as a contact issue between a spark plug>coilpack or connection issue on a plug or main engine wire harness connector which needs cleaning & or/contact grease ?
Are people experiencing DTC's with all nannies on or off and is the ECU to blame? Perhaps not as all cylinders would complain. Is it really a result of accumulated repeated beatings and/or excursions to &/or sustained redline use ? Has anyone tried Okada Plasma Direct plugs ?
Garbage Subaru parts ! My old gen7 celicaGTS copped plenty in it's 13 year life, many excursions to the rev limiter = 8500rpm & I never got a DTC :/
ZZT86 is offline   Reply With Quote
Old 08-11-2018, 02:13 PM   #452
Lonewolf
Lonewolf's Avatar
Drives: Moped
#1 195 degrees
#2 140 degrees
#3 165 degrees
#4 160 degrees
Now that is eye-opening. Thank you for the info!
Old 08-14-2018, 02:44 PM   #453
celek
Resident Gear Head
celek's Avatar
My plugs are at 55k miles a change is coming up at 60k the recommended interval.
My car is a 2012 production year which is prone to this issue. It is the first time it reared its ugly head though.
The Following User Says Thank You to celek For This Useful Post:
ZZT86 (08-14-2018)
Old 10-15-2018, 03:23 PM   #454
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Just got this CEL P0351 after a long time since I've last seen it. Interestingly my MPG had a huge decrease of ~30 to ~20. It's also time to swap out the spark plugs .. I'm hoping the coil &/or spark plugs crapped out causing the huge loss in mpg (and performance).
Old 10-15-2018, 04:06 PM   #455
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
The mpg loss could be nothing too terrible, but when I let my coil go too far bad it took a DI with it. Then I started to notice the horrible mpg.
MCTeeJ is offline   Reply With Quote
The Following User Says Thank You to MCTeeJ For This Useful Post:
Bonburner (10-15-2018)
Old 10-15-2018, 04:10 PM   #456
CSG Mike
CSG Mike's Avatar
You essentially lose 1/4 of your engine, and it becomes unbalanced. Sounds "normal" under the circumstances.
Old 10-15-2018, 04:21 PM   #457
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I hope my injector didn't get killed off due to my laziness ~
The Following User Says Thank You to Bonburner For This Useful Post:
MCTeeJ (10-15-2018)
Old 10-15-2018, 04:23 PM   #458
MCTeeJ
MCTeeJ's Avatar
I've heard its on the rarer side of things but if you don't have any misfires going into the throttle in the mid range I'd say you're safe. Just change that damn coil lol
Old 11-05-2018, 12:44 PM   #459
kinchu007
Drives: Ghost BRZ
Do you guys know if there is a Toyota TSB that is equivalent to Subaru TSB # 07-120-17 (dated 7/7/17) ? -Thanks
kinchu007 is offline   Reply With Quote
Old 12-07-2018, 02:57 PM   #460
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
I just got P0352 today as well. Everyone else has issues with 1 and 3 but for me it is #2.
First time it ever came up. I was WOT making a light, something I have done many times in the last 5 years of ownership and it came up. Car is running fine though.
Something is amiss here.
I too have Flex tune, 3" OPFP and UEL headers.
I figure as long as you smile while driving the car, you're doing it right.
SillySaxon is offline   Reply With Quote
Old 12-09-2018, 05:04 PM   #461
Dr. BRZ
Dr. BRZ's Avatar
As you’ve read the post, you know what to do. Don’t be lazy.
MCTeeJ (12-09-2018)
Old 12-09-2018, 06:39 PM   #462
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I never bothered updating as to what happened to my car.
I swapped the ignition coil #1 and all 4 spark plugs. Running back to normal MPG
MCTeeJ (12-09-2018)
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 06:29 PM
