Old 08-07-2018, 11:26 PM   #1
localhost
Drives: Edelbrock SC 2015 FR-S 6MT
Car seems to be pulling timing with OFT v4.03 Stg1
Hello folks,
I've flashed the OFT v4.03 ROM onto my car about a month ago and been daily driving it since. I've only recently started to datalog because the butt-dyno said things felt a little off.
I checked my IAM today and it was pegged at 0.56 the whole time. I'm seeing knock correction come on at certain times too, plus my LTFT varies between -6.5% and -3.9%. I tried the second gear run from ~2000 rpm to about 7000rpm at ~30% throttle hoping I could get the IAM up a little, but saw no chance. I also saw knock correction kick on around 3000rpm during that run. I did see IAM at around 0.76 last night, but I can't be 100% sure. Even after a restart of the car, the IAM stays at 0.56 - which is expected behaviour from reading other threads.
I'm using Shell 91 in Canada. The car definitely feels slower and less responsive than stock to me. Any idea what might be wrong? I feel like it might be a case of a batch of bad fuel, but I'll have to wait until I empty this tank to verify that. Car is stock except for a high flow air filter.
Here are two datalogs that might help:
https://datazap.me/u/rb28dett/low-iam-1?log=0&data=1-13
https://datazap.me/u/rb28dett/low-iam-2?log=0&data=1-10
Many thanks in advance for any help I might try re-flashing the stage 1 tune again and seeing if anything changes.
EDIT: Something a little odd to me as well. My car is a MY15 MT FRS with a calibration ID of ZA1JD00C, but on the OFT website there's no matching tune. The only file for JD00C is for a MY14 (not 15) which is what I've flashed. I'm not sure if that is what is causing the issues. Also I've never been able to get FFS to work (it just bounces off the full rev limiter) even though LC works.
Screen shot of my Openflash Manager included as an attachment.
I flashed the ROM with FW version 1.51, but the OFT just updated itself to 1.53. I'm not sure what the changes are between them and if I should re-flash.
localhost is offline   Reply With Quote
Old 08-08-2018, 02:04 AM   #2
steve99
Drives: FT86
Yes with 91 fuel on v4 tunes the iam is unlikely to ever be 1 and you will always have some knock
I could modify tune for you to run better on 91
Message me if your interested
Old 08-08-2018, 10:05 PM   #3
Pixeld303
Drives: Sorta stock
Just a quick note. You didn't blur out the S/N on the top
Pixeld303 is offline   Reply With Quote
Old 08-08-2018, 10:26 PM   #4
localhost
Thanks, fixed
Old 08-10-2018, 01:01 AM   #5
vin08
275/1000
Drives: 2016 RS2 auto
yeah. seem like the my car is not as responsive with the 4.0 stage 2 plus update. I am thinking switching back to the older Stage 2OFH v1.0.
Steve,
Is there a 4.0 stage for the openflash headers I can download?
vin08 is offline   Reply With Quote
Old 08-10-2018, 02:08 PM   #6
DarkSideFRS
Drives: 2013 pearl white FR-S
i would love a 91 specific tune!
DarkSideFRS is offline   Reply With Quote
Old 08-10-2018, 03:38 PM   #7
[jack]Best username ever.[/jack]
Old 08-10-2018, 06:11 PM   #8
localhost
If that was meant for me, thanks
Old 08-14-2018, 10:25 PM   #9
mizzta21
mizzta21's Avatar
Drives: 2014 whiteout, scion fr-s
I am also curious, I’ll pm you
mizzta21 is offline   Reply With Quote
Old 08-15-2018, 09:27 AM   #10
iFunner
iFunner's Avatar
Drives: 2016 Toyota 86
Is it always better to run 93+ on Stage 1 on 4.03 to reduce knock?
iFunner is offline   Reply With Quote
Old 08-15-2018, 11:14 AM   #11
localhost
I'm also a little curious as to what kind of power loss there is between running 93+ and just 91 on these tunes. Especially if the car is pulling 30% of the timing at 91.
Old 08-15-2018, 11:48 AM   #12
tomm.brz
Drives: brz 2017 hksv2
am at 0.7 doesnt mean 30% of the timings is pulled
it s 30% of The ignition advance map (Knock correction A)
we are talking of maximum 3 degrees of timing so dont Know,something less than 10-12cv probably
Old 08-15-2018, 12:23 PM   #13
localhost
Ahh thanks for the clarification. That makes perfect sense
Old 08-22-2018, 10:51 PM   #14
jRuN
I noticed the same thing. The tune says it's for a MY14 and my car is a MY15. I have the same calibration ID as you too
Hello folks,
Sent from my Pixel XL using Tapatalk
jRuN is offline   Reply With Quote
iam, ignition advance, oft, slow
Installed STG1 OFT , whats next? FR-Sky Software Tuning 3 06-27-2016 02:58 AM
WTB: innovate stg1 supercharger jflogerzi Want-To-Buy Requests 0 11-24-2014 10:35 PM
Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! Visconti Forced Induction 67 04-03-2013 03:56 PM
Stock BRZ/FRS vs Visconti STG1 e85 ! Visconti Engine, Exhaust, Transmission 46 02-11-2013 11:48 PM
Perrin STG1 tune Celica00 Engine, Exhaust, Transmission 125 10-19-2012 11:59 PM
