Old 08-04-2018, 12:31 AM   #4663
Turbo
Drives: FR-S Turbo
Hi Mike-
Hoping you can help with some alignment settings plus front AND rear ride-height recommendations for an FR-S track car. Car details:
250WHP turbo'd
HKS Hipermax IV SP coilovers w/adjustable camber plates
stock sways
255/40R17 Hankook RS4
I can add rear toe arms if necessary.
I'm especially curious about ride height (I've read that going too low affects the roll center & causes bumpsteer) and whether there should be any 'rake' front-to-back.
Thanks in advance for any help you can offer.
Turbo is offline   Reply With Quote
Old 08-05-2018, 02:37 AM   #4664
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
NA car with bolt ons.
Which would have a greater effect on underhood temps: coating the header or adding hood vents?
Old 08-05-2018, 01:33 PM   #4665
juliog
juliog's Avatar
Drives: 86
Underhood temps is a fuzzy term, what are you trying to achieve?
juliog is offline   Reply With Quote
Old 08-05-2018, 01:40 PM   #4666
juliog
juliog's Avatar
Drives: 86
Originally Posted by LittleChuuChuu View Post
Hi Mike, when I’m doing high speed sweeps, such as turn 2 at THill East I can feel some vibration in the rear but when I accelerate more it goes away. Could it be my suspension maxing out since I have a gutted rear, apr gt200 wing and only lowering springs? I originally thought it was my tires but talking with someone this weekend he mentioned it could be suspension.
Hard to say. Does it happen on both left and right turns?
Old 08-05-2018, 01:57 PM   #4667
finch1750
finch1750's Avatar
Longevity. I dont have a specific area I'm hoping to improve but just knowing how hot the car gets. Or if its just a waste to bother with it if oil/coolant temps are fine
Old 08-06-2018, 02:42 PM   #4668
CSG Mike
CSG Mike's Avatar
That's unfortunately too vague to even guess at anything.
Got an Ecutek/AIM datalog?
CSG Mike is online now   Reply With Quote
Old 08-19-2018, 12:52 AM   #4669
shadow_772
Drives: 2014 BRZ Limited
@CSG Mike, I have my first track day coming up. I will be running 17 x 8 +35 wheels and 225 hankook RS4 tires. I'll likely run EBC yellowstuff pads (they will be swapped down the road).
Factory alignment right now, though I do have a couple decent shops in my area.
I'm considering camber bolts for the first couple track days then graduating to LCA's, coils and the works as I progress and see the need.
Any thoughts? I'm also thinking about going stock and seeing exactly what it needs from there, but if I can eliminate some tire wear than I suppose an alignment (with camber bolts) is the way to go.
shadow_772 is offline   Reply With Quote
Old 08-20-2018, 06:00 PM   #4670
CSG Mike
CSG Mike's Avatar
Don't waste your time with yellowstuff. Get front camber bolts before your first day, or you will wear your tires on the outside shoulder excessively.
Old 08-20-2018, 06:41 PM   #4671
tony_r
tony_r's Avatar
Drives: '15 STX
On stock brakes, DS2500 pads. First time on the track with the car rotors got to glowing red. Minor fade. Brakes still work fine.
Will ducting alone be a solution? I know the AP kit is an option for better heat dissipation but I'm not interested in the buy-in for the kit.
tony_r is offline   Reply With Quote
Old 08-20-2018, 08:31 PM   #4672
FirstWinter
Drives: Car
Upgrade pads and fluid. OEM calipers are sufficient for track use. Ducting works but you will go through rotors faster.
FirstWinter is offline   Reply With Quote
Old 08-20-2018, 09:03 PM   #4673
tony_r
tony_r's Avatar
Drives: '15 STX
Will do, maybe DS3000 then. Fluid is already ATE so good there. Really just concerned since I've never had glowing red rotors
Old 08-20-2018, 11:31 PM   #4674
CSG Mike
CSG Mike's Avatar
DS2500 are not track pads. They can briefly tolerate low track temps, but will wear excessively quickly.
It sounds like time for some serious track pads.
A proper BBK will save you a TON of money in the long run.
https://www.facebook.com/groups/86cu...5961516620395/
Old 08-21-2018, 02:35 AM   #4675
tony_r
tony_r's Avatar
Drives: '15 STX
Yeah thats off the table since I'm not serious about the track day thing. If I was, yeah for sure a BBK and all that. I might do one day a year plus a time trial event, but my focus is STX on the cheap still. If I can get by with a pad change on stock brakes and maybe ducting, I will do that. If you're saying a BBK is the only way, well I guess I gotta stop the track days lol.
But thank you for the recommendation. If I get more serious about it I'll definitely consider the BBK.
Old 08-21-2018, 01:30 PM   #4676
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
You can get away with just a pad change, I know quite a few guys will casually track with just a pad swap for track pads without a BBK. A BBK is definitely not necessary if you only track once a year.
Horrid_Funk is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
