Old 07-16-2018, 12:32 PM   #519
DarkSideFRS
Drives: 2013 pearl white FR-S
i just flashed the stage 1 v4.03 tune and have driven it for abt 70 miles now... one thing i noticed is that there seems to be unburned gasoline smell during cold starts.. is that normal now that the cold start function is gone?
DarkSideFRS is offline   Reply With Quote
The Following User Says Thank You to DarkSideFRS For This Useful Post:
mgarcia707 (09-17-2018)
Old 08-03-2018, 12:01 AM   #520
Madara
Drives: 2014 Asphalt FRS
So does the cold start delete still idle higher than a stock tune?
Madara is offline   Reply With Quote
Old 08-03-2018, 12:48 AM   #521
steve99
Drives: FT86
Should idle lower than stock stock is 1800 think oft v4 about 1200
Madara (08-03-2018)
Old 08-03-2018, 01:24 AM   #522
Madara
Ah I see. Wouldn't this affect/damage the cats since it's not heating up to operating temp as soon as possible? Also when winter comes along wouldn't this be a bigger problem? Sorry for the questions.. I'm still on v3 tunes and Im debating if I should go v4 lol..
Old 08-03-2018, 01:33 AM   #523
churchx
churchx's Avatar
Drives: 2014 GT86
It won't "damage" cats. They just won't be heated quicker to working temps (reason why primary cat is that close to cylinders and why cold starts in tune exist) and thus emissions, if measured right after cold start, tests will be worse. If that matters to you, where you live, it's up to you. I'm not familiar with emissions testing in cali to advise something.
Madara (08-03-2018)
Old 08-03-2018, 09:00 PM   #524
Madara
Tried to download V4 but im getting this error..."Error 404 - Page not found!" on the website.
This is the link im trying to open
http://www.openflashtablet.com/downl..._USDM_ONLY.zip
-EDIT-
Figured it out D:..geez the website looks so different from before
Old 09-15-2018, 06:32 PM   #525
alf
alf's Avatar
Download page indeed takes you to 404.
I think OFP wants you to buy it now (for $0) and sign a few liability forms
http://www.openflashtablet.com/shop/...-us-6mt-v4-03/
alf is offline   Reply With Quote
Old 09-17-2018, 01:53 AM   #526
jacjac3
jacjac3's Avatar
Drives: WRB BRZ
Flashed my 2013 BRZ manual with v4.03.
https://support.openflashtablet.com/...4-us-6mt-v4-03
After 200miles, I'm getting consistent idle dip when the AC is on. I had the deal apply the TSB for this fix awhile ago when it became available and it seemed to fix the problem. After flashing to stage 1, the problem is back....any ideas?
jacjac3 is offline   Reply With Quote
Old 09-17-2018, 09:17 AM   #527
ermax
ermax's Avatar
My 2013 has always had the dips. It's totally random, some days it's hot as crap and it does it and other days it's hot as crap and doesn't do it. I can't find any consistency to it. I've flashed mine to the CAL that the TSB requires and it was better but still dips from time to time. I'm currently running OTS 4.03 on E85 and it isn't dipping anymore than it did on OEM firmware on 93. It's really annoying but I've just gotten used to it not. Kind of sad this car can't idle.
Old 09-17-2018, 09:51 AM   #528
tomm.brz
Drives: brz 2017 hksv2
mostly.of.the dip is when AC goes on and it catches cells of 35% or more of PI
try to zero 0.2 and 0.3 engine load column in the three PI/DI ratio tables
Old 09-17-2018, 04:28 PM   #529
jacjac3
jacjac3's Avatar
Drives: WRB BRZ
I’m not sure if this will help but I’m planning to downgrade from v4.03 OTS to the older v2.
Old 09-17-2018, 11:48 PM   #530
jacjac3
jacjac3's Avatar
Drives: WRB BRZ
Just flashed the brz back to stock. The idle dip is gone. I'll have to try out v2.076
Old 09-18-2018, 02:31 AM   #531
jacjac3
jacjac3's Avatar
Drives: WRB BRZ
A couple weird things I noticed while I was flashing it back to stock
I got the 4.03 firmware from the site
Stg-1-v4.03-LC-FSS-ZA1JB01C.bin
My cars orig Cal code is ZA1JB01C
After flashing to v4.03 it changed to ZA1A01G
Is this normal? Wasn't there a safety mechanism to stop flashing the wrong .bin?
Old 09-18-2018, 02:47 AM   #532
tomm.brz
v4.03 pre restyling are all a01g hacked, like k00c is k00g actually
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 07:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 04:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 02:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
