Old 07-31-2018, 06:40 PM   #1
GrayFox_27
Drives: 2017 Toyota 86
Do Seibon Spoilers cover up holes on the trunk?
I’m looking into replacing the OEM Spoiler on my 2017 86 with a Seibon Spoiler; and since I’m having no luck in finding someone willing to swap Trunk Lids, I’d figure this would be the best route.
Does anyone know if the C-Style or SN-Style Spoliers from Seibon cover up the holes left behind from removing the OEM Spoiler?
GrayFox_27 is offline   Reply With Quote
Old 07-31-2018, 06:52 PM   #2
NeedsBoostt
NeedsBoostt's Avatar
Drives: '19 WRX STi; Ex. '17 BRZ owner
I owned the c-style lip and it covered the two holes for 2017 trunk but not the deep 3rd one. So should for others, its been awhile since I ran it though...
NeedsBoostt is offline   Reply With Quote
Old 07-31-2018, 06:57 PM   #3
GrayFox_27
Can you explain it to me a bit, which 3rd one? What did you do to cover it up?
Old 07-31-2018, 07:05 PM   #4
NeedsBoostt
the 2017 brz trunk has 3 holes on each side (for the low mount wing); you have a normal 86 which will have just two holes on each side. The spoiler should cover it if I recall correctly. My bad I did not pay attention to what year car you drove
The Following User Says Thank You to NeedsBoostt For This Useful Post:
GrayFox_27 (07-31-2018)
Old 07-31-2018, 07:09 PM   #5
GrayFox_27
Ah okay I didn’t know the BRZ had the 3, I thought it was just 2 like the others. Thanks a lot, you just helped me out a ton.
Spoilers that cover the BRZ Limited spoiler holes B-R-Z Cosmetic Modification (Interior/Exterior/Lighting) 19 10-25-2019 06:30 PM
Which spoilers cover the holes on a 2017 BRZ? ILLSMOQ Cosmetic Modification (Interior/Exterior/Lighting) 1 02-06-2017 03:55 PM
Spoilers that cover 2017 limited factory holes? Chayce808 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-05-2016 11:28 PM
Changing Spoiler Without Replacing Trunk. Cover or Plug Holes? ajcarson11 Cosmetic Modification (Interior/Exterior/Lighting) 2 09-25-2015 07:12 PM
Would a 5AD trunk lip cover up all the holes left by a BRZ Limited wing? tracerit Cosmetic Modification (Interior/Exterior/Lighting) 14 06-13-2013 07:27 PM
