Old 07-27-2018, 09:07 PM   #29
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
Originally Posted by JeremyR View Post
are you able to remove the pioneer logo from the front??
I don't believe you can; I will confirm on Sunday when I do the install.
JBezugs is offline   Reply With Quote
Old 07-29-2018, 07:14 PM   #30
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
Originally Posted by JBezugs View Post
I’m a bonehead, I had the connector flipped. Did you use the small connector they left for the maestro unit for the AWSC-1?
The volume controls on the pioneer unit look to be touch sensitive.
https://metradealer.com/files/aswc/ASWC-1_INST_959.pdf
That's the instructions I used to wire the ASWC-1 into the harness. I can pop my radio out and take pictures if it helps.
And that's kind of a bummer about the captive volume control. Hopefully it's responsive!
tehShirt is offline   Reply With Quote
Old 07-29-2018, 09:41 PM   #31
JBezugs
Good Job Subaru!
JBezugs's Avatar
Headunit install is “complete” for now. There are quite a few plugs that the harness/head unit doesn’t seem to use, which is interesting.
I have two issues:
The Axxess AWSC-1 isn’t detecting my car. It is detecting my headunit, but it thinks the wires are disconnected from my car. I may have flipped the pins. I will have to rewire this later this week.
The backup camera isn’t working. The reverse trigger is working on the headunit, however I get no image from the backup camera on the headunit. I had it plugged into the wrong input initially on the headunit so I swapped it to the proper “RC” input on the Pioneer. It still doesn’t work. I ran out of patience currently as I have a very early day tomorrow, so I will have to deal with it later in the week. Anyone have any tips?
The Following User Says Thank You to JBezugs For This Useful Post:
JeremyR (07-30-2018)
Old 07-29-2018, 09:56 PM   #32
tehShirt
tehShirt's Avatar
You can select your car and radio by plugging the ASWC into the computer and using the Metra software. I ended up doing the manual programming after this, as I wanted different function for certain buttons.
For the camera issue, you may need to go to the settings for the camera and toggle between the battery/ground options for the picture to display.
Old 07-29-2018, 10:00 PM   #33
Vanilla Bear
Drives: 2017 CWP BRZ
If I had to take a guess it would be that the headunit is sending 12v to the camera and the camera only takes 6v. My Kenwood unit had this happen and I just used a voltage dropper attached at the camera end to make sure the camera only got 6v. Works great now. This one specifically https://www.qualitymobilevideo.com/ax-cam6v.html. Hope that helps!
Vanilla Bear is offline   Reply With Quote
Old 07-30-2018, 04:53 AM   #34
Juzzotec
Juzzotec's Avatar
Drives: Toyota 86 GTS
Sorry for the late reply, have had this installed since release Pioneer ZL5150BT
Half the price of the Kenwood 200mm unit but just as good in every way.
Juzzotec is offline   Reply With Quote
The Following 3 Users Say Thank You to Juzzotec For This Useful Post:
djezlee (07-30-2018), JeremyR (07-30-2018), tehShirt (07-30-2018)
Old 07-30-2018, 09:54 AM   #35
JBezugs
Good Job Subaru!
JBezugs's Avatar
So, as a follow up:
For the AWSC-1, I'll attempt to program it manually using the Metra software and see if it works.
As for the backup camera, it may be down to me not grounding the video ground cable, as it was mentioned to only ground as required. I'll give that a shot tonight and update you guys.
Otherwise, the headunit has been a joy to use. Super responsive, and although the volume controls look to be capacitive, they are actually hard buttons, which is nice!
I'm going to Auto-EQ and TA tonight as well (I have the EQ mic from the DEH-80PRS in my old car, I had quite the system in there!).
I'll keep everyone in the loop!
The Following 3 Users Say Thank You to JBezugs For This Useful Post:
JeremyR (07-30-2018), Racecomp Engineering (07-30-2018), wparsons (07-30-2018)
Old 07-30-2018, 10:09 AM   #36
mabviper
Drives: WRB BRZ
Woo that's good to hear. Do you use RaceChrono Android app? Do you know if it works in Android auto mode?
Sent from my Nexus 6P using Tapatalk
mabviper is offline   Reply With Quote
Old 07-30-2018, 11:42 AM   #37
tehShirt
tehShirt's Avatar
@JBezugs check the camera polarity settings before you change physical wiring. My camera did not display properly until I changed the setting to "Battery"
The Following User Says Thank You to tehShirt For This Useful Post:
JBezugs (07-30-2018)
Old 07-30-2018, 11:50 AM   #38
JBezugs
Good Job Subaru!
JBezugs's Avatar
I flipped between the two settings; neither battery nor ground seems to have worked for me. Hopefully the video ground fixed the issue.
Old 07-30-2018, 12:13 PM   #39
tehShirt
tehShirt's Avatar
Interesting. I don't think I had to ground my camera, but I could be remembering incorrectly. Hopefully you get it working. The radio looks really nice, wish I had seen this one back in May.
Old 07-30-2018, 12:47 PM   #40
Have you verified the backup camera is enabled on the headunit? I ask because when I installed the Pioneer in our Suburban I ended up doing a lot of troubleshooting only to have the fine folks at Crutchfield tell me that the cameras are turned off by default and you have to go in and enable them. Sure enough, that was my problem. Exact same symptoms.
Old 07-30-2018, 02:16 PM   #41
JBezugs
Good Job Subaru!
JBezugs's Avatar
It has been enabled, currently when I shift into reverse the reverse camera screen comes up (which means the reverse trigger is working), however I have a black image where my camera should appear.
Old 07-30-2018, 02:33 PM   #42
fitcious
How’s the speed and responsiveness of the overall system? There’s a Sony one out there for like $400 with all the functionality except CD/DVD that I’m interested in
fitcious is offline   Reply With Quote
Looking for suggestions on what carplay compatible head unit to get. wparsons Electronics | Audio | NAV | Infotainment 8 03-02-2018 08:09 AM
Android head unit drz400dude Electronics | Audio | NAV | Infotainment 6 12-20-2016 12:47 AM
200mm android head unit with android lollipop rsingh Electronics | Audio | NAV | Infotainment 3 05-23-2016 08:48 PM
New 200mm head unit from Pioneer AVIC-F7302 Clot Electronics | Audio | NAV | Infotainment 8 09-16-2014 11:39 AM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
