#71 |
I'm loving it every time I get in it.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following 11 Users Say Thank You to stevesnj For This Useful Post: | funwheeldrive (07-25-2018), HachiRokuX (07-28-2018), J1Avs (07-25-2018), mrg666 (08-10-2019), new2subaru (07-24-2018), PetrolioBenzina (07-25-2018), sato (07-25-2018), spike021 (07-24-2018), Swabodda (07-26-2018), trvth (07-25-2018), weederr33 (07-26-2018) |
#72 | |
Instagram: @spike.grc
#73 |
Weight Weenie
Drives: 15 FR-S
#74 |
TRACKBREAD
(Muffled Krieger Voice) ME TOO!
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | Overdrive (07-25-2018) |
#75 |
Drives: FR-S 10 Series
If this thing had a different spoiler, extra 40hp, blue ribbon metallic (or whatever you call that red Mazda uses on the new Miata) & light up badges then I'd learn to live with the catfish mouthed front bumper and trade in my 10 series.
(I threw in the light up badges to see if anybody noticed) |
| The Following User Says Thank You to dnieves For This Useful Post: | SC10N (09-28-2018) |
#76 |
Drives: '15 BRZ RA
I know all these videos and this is exactly my point. They are comparing a high-spec mx5 rf with brembos, bilsteins and stickier tires with a base 86 having the prius tires. Price difference is also 5k higher for the mx5. If they were comparing similar spec'd cars, then we could have a discussion. Otherwise, it is an apples to oranges comparison.
| The Following User Says Thank You to nikitopo For This Useful Post: | ermax (07-25-2018) |
#77 | |
TRACKBREAD
2019 Toyota 86 TRD Edition
Yes it seems like the Miata will always be given the advantage by the press since it's their default darling. Equivalent spec of each car and same tires will give the BRZ the advantage, but nobody has tested that yet. The press wants to perpetuate the '86 needs moar pwr OMG' narrative, because it gets them clicks and comments. Not sure about any of this now with the Miata power bump though. Last edited by Yoshoobaroo; 07-25-2018 at 09:54 AM. |
#78 |
Drives: TBA
Wasn't sure if the TRD pics were an illusion so went to tirerack.com to compare Michelin PS4 diameter + 18" wheels to stock.
Sure enough, the TRD SE is ¾" higher than a stock 86 on 17's. Are they trying to sell TRD lowering springs? Sad that TRD may well have upset one of the main features of the 86, a low CG. The TRD lowering springs, like the TRD sway bars, are available as a port or dealer installed option with full warranty, but I wonder if they tested the spring compatibility with the Sachs dampers? |
#79 |
ಠ_ಠ
Drives: 860 SansOverspray
#81 |
Drives: Toyota 86
Ha Same. It doesn't look like Toyota will be offering the Brembo Brakes as a add on for the 86 GT models. I am a Toyota owner, but I think I will be going with the Subaru BRZ Limited with Performance Package over the TRD model to save a few thousand.
| The Following User Says Thank You to motomaster132003 For This Useful Post: | Adam_L (08-13-2018) |
#82 |
Drives: 2023 Toyota GR86 Trueno Blue
Are they gonna do the Scion thing where they have to run your VIN number to see if you got the special edition 86; for you to get the special parts?
#83 |
Drives: 2018 BRZ tS (CBS), AE86 GT-S, MA70
I just noticed the press release for the 2019 models included this:
"Available All-New Exterior (Neptune) and Interior (Red/Black) Colors" I'm curious about Neptune... |
| The Following User Says Thank You to yurikaze For This Useful Post: | SuperTom (07-27-2018) |
#84 |
Drives: 1993 Caterham HPC Evo
| Johl's Toyota 86 Blackline Edition | johl | Member's Car Journals | 88 | 07-09-2019 02:07 PM |
| 2019 Toyota 86 TRD Edition | interna | CANADA | 8 | 07-08-2018 10:02 PM |
| 2017 Toyota 86, 860 Edition Under 1K miles | thatweirddude25 | Cars for Sale/Trade | 0 | 05-08-2018 03:43 PM |
| Toyota 86 GTS MY15 Edition | M4V3R1CK | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 07-15-2014 11:39 PM |
