Old 02-21-2017, 12:27 PM   #57
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
2013 rocker spitting issue has been discussed many many times. Subaru has addressed this with revised part numbers. If i recall 2014+ got slightly longer valves and revised rockers so pins stopped popping.
Not much to discuss here or bicker about.
@celek is motor god, im sure he can shed more light.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 02-21-2017, 12:31 PM   #58
celek
Resident Gear Head
celek's Avatar
It was actually in 2013 it was revised but 2014 models, and I bet that 2014+ models spit rockers too
They also went away from 2 separate rocker part numbers between intake and exhaust
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
GsxrMe (02-21-2017)
Old 07-26-2018, 05:52 PM   #59
NL86
Drives: 2017 Toyota 86 (Base)
I know this is an old thread but id like to say i got a 2017 86 with 6k miles on it and the same thing happend while at idle, car was bone stock with no mods at all, i was almost done a cross country drive when it happend. Had a month long battle with toyota to clarify if it was under warranty because they told me it was from "engine neglect" because i had driven 4k miles in the last 5 days before it happend.
Sent from my SM-G950W using Tapatalk
NL86 is offline   Reply With Quote
The Following 2 Users Say Thank You to NL86 For This Useful Post:
Pat (07-26-2018), Ultramaroon (07-26-2018)
Old 07-26-2018, 06:30 PM   #60
ermax
ermax's Avatar
There was another thread that is currently active where this happened to someone 2 days out of warranty and Toyota was trying to claim he over revved. He pushed them for weeks and they finally concluded that it wasn't an overrev and said they would fix it.
Seems like Toyota finds anything they can to reject claims. So the 86 has weekly mileage quota now? Give me a break.
Good luck!
Old 07-26-2018, 07:02 PM   #61
NL86
Thanks, its been 6 weeks and it finally got done it was a fight though
Good luck!
Old 07-26-2018, 09:53 PM   #62
Thanks, its been 6 weeks and it finally got done it was a fight though.
Do you know if the pin walked out, or was it something else?
Old 07-26-2018, 10:03 PM   #63
NL86
The only thing the service guy told me was that the valve floated, i asked for exactly what happend but he wasnt exactly sure
Old 07-26-2018, 11:09 PM   #64
Funny how that works. Thanks for trying to get the info from them.
Old 07-27-2018, 01:11 PM   #65
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Not many service guys really know anything about cars.
Muaddib is offline   Reply With Quote
The Following 2 Users Say Thank You to Muaddib For This Useful Post:
ermax (07-27-2018), Ultramaroon (07-27-2018)
Old 07-27-2018, 01:31 PM   #66
Impureclient
Drives: 2015 FR-S
It doesn't take much knowledge to fix cars as it's mostly just take off part and put it back in, it's the diagnosing part that takes skill.
I grew tired of fixing things on my work van recently and took it to a shop to find an issue. $2500 and many parts later they finally
figured it out. Of course they broke some parts on the way there that were good when I started and also lost a trans. dust cover but
it's running now so I can't complain, right?
Old 07-27-2018, 02:15 PM   #67
ermax
ermax's Avatar
Both take knowledge but whatever. I think what is happening with the 86 is Toyota sells so few of them that they aren't familiar with the common failures and make assumptions based on what would normally cause a rocker to fail which would be an over rev which would float valves. They jump on the first excuse they can to deny a claim rather than dig through TSBs or call corporate to see if there is and history of failed rockers. My understanding is the newer cars have new pivots (with smaller oil hole) and longer valves which changes the angle of the rocker but the design of the pin on the rocker (which is apparently what fails) hasn't changed.
The Following User Says Thank You to ermax For This Useful Post:
Old 07-27-2018, 03:14 PM   #68
Right! Now you have your problem fixed, you have several new parts and you didn't have to buy a new van - so, YES, be a
Impureclient (07-27-2018)
Hole in valve cover burdickjp Issues | Warranty | Recalls / TSB 25 11-29-2016 10:37 PM
Here's my luck… rocker arm put a hole in the valve cover -eXpo- Issues | Warranty | Recalls / TSB 10 09-24-2015 12:58 AM
WTB Frs Passenger Exhaust Hole Cover OMGArisman Want-To-Buy Requests 0 07-20-2015 01:16 AM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 09:31 AM
Missing Key Hole Cover? Mrpolarbear Issues | Warranty | Recalls / TSB 12 08-10-2014 07:24 PM
