Old 04-05-2017, 05:25 PM   #267
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by norcalpb View Post
Probably the same model of caliper, it's probably just more expensive because it says STI on them.
You did not bother to read the context to this at all did you...
Old 04-05-2017, 06:31 PM   #268
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Yeah the pistons are slightly larger since they were originally for the WRX (and certainly more expensive cuz STi lol). The problem with them is that they move brake bias more toward the front of the car, whereas the OEM brembos on the sport package 2017 models have smaller pistons and keep some of the bias down (still shifts more to the front tho). Oddly enough having the rear brembo set up is worse than the OEM sliding calipers!
Originally Posted by krayzie View Post
Interesting never knew that. If I would take a guess the STI ones have slightly larger pistons (I mean the MSRP is ridiculously high)?
kuczynskika is offline   Reply With Quote
Old 04-05-2017, 06:45 PM   #269
SPCorBUST
SPCorBUST's Avatar
Well, I'll just add that I don't think that moving the brake bias to the front is really a problem. It's still OEM. If anything, the current bias in stock vehicles may be an issue that they rectify with the OEM update and upgrade.
Sent from my SM-G925T using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 04-05-2017, 06:47 PM   #270
kuczynskika
Yeah and I mean for normal street driving you'll have to be at the limits to feel a difference anyway. The way I look at it is this set up allows for bigger rotors which means more heat soak. Thats where you really pick up the gains. And the ease of pad changes too....
The Following 2 Users Say Thank You to kuczynskika For This Useful Post:
krayzie (04-05-2017), SPCorBUST (04-05-2017)
Old 07-27-2017, 01:34 PM   #271
SPCorBUST
SPCorBUST's Avatar
New red skirt lip available, according to fitment:
Car category
Subaru
Legacy 2015-up BN/BS A- Liberty
Legacy 2012-14 BM/BR D-E Liberty
Impreza WRX/STi 2006-07 GD/GG F-G Hawk Eye
BRZ 2016- ZC6
WRX S4/ STI
LEVORG
XV/ G4/ SPORT/ CROSSTREK
Impreza WRX/STi 2010-14 GR/GH/GV C-E
Impreza WRX/STi 2008-09 GR/GH A-B
BRZ 2012-15 ZC6
Compatible with:
BM/BR/VA/GP/GJ/VM/GR/GV/ZC6/BN/BP/BL/GD
https://www.japanparts.com/parts/detail/49758
The Following User Says Thank You to SPCorBUST For This Useful Post:
spike021 (07-27-2017)
Old 07-25-2018, 05:22 PM   #272
gpvecchi
gpvecchi's Avatar
What's the difference of the rear subframe? Will it fit a 2018 model?
Old 07-25-2018, 05:30 PM   #273
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Different bushes.
The Following User Says Thank You to nikitopo For This Useful Post:
gpvecchi (07-26-2018)
Old 07-26-2018, 04:31 AM   #274
gpvecchi
gpvecchi's Avatar
So, it’s cheaper to buy the full rear subframe than the 4 subframe and the 2 subframe bushings, right?
Old 07-26-2018, 01:07 PM   #275
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I don't think it is cheaper, but it is difficult to remove them .
gpvecchi (07-27-2018)
Old 07-27-2018, 03:48 AM   #276
gpvecchi
gpvecchi's Avatar
What’s the diameter of the front sway bar for STi? Will the bushing fit a 2018 model?
Old 07-27-2018, 05:32 PM   #277
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The front sway bar of tS is stock. The sway bar bushings are much smaller and they offer a more immediate steering feel. Nothing more on the performance side.
Old 07-29-2018, 04:11 PM   #278
Turbowned
Turbowned's Avatar
Anyone happen to check to see if there's a US part number for the STi carbon fiber wing, and if it's still $2500 or possibly a bit more reasonable than buying from Japan? Just curious...
Old 10-16-2018, 04:18 PM   #279
gpvecchi
gpvecchi's Avatar
Regarding the rear sub-frame stopper, do I need 2 or 4 pieces?
For a 2018 model, do I need the upper or the lower version?
Thanks!
Old 10-16-2018, 04:47 PM   #280
Sergeb96
Sergeb96's Avatar
Drives: 2013 Subaru BRZ Premium MT
The U.S ts wing costs even more. Retail is over 3.8k
https://parts.bestbuysubaru.com/a/Su...10-921-06.html
Sergeb96 is offline   Reply With Quote
** TRD JAPAN GT-86 PARTS LIST ** Carson Toyota Exterior Parts - The Rest 222 08-28-2014 01:43 PM
I wish list of parts for my FRS jflogerzi Scion FR-S / Toyota 86 GT86 General Forum 19 04-28-2013 10:55 PM
R Magic Parts List quik1987 Engine, Exhaust, Transmission 9 07-30-2012 01:55 PM
List of all parts you want on your BRZ/86 StarsGarrador BRZ First-Gen (2012+) — General Topics 72 05-22-2012 05:20 PM
Lexus IS-F parts wish list aspera Engine, Exhaust, Transmission 21 08-18-2011 01:59 PM
