View Poll Results: What name should Toyota use for the production Toyota FT-1?
Supra gets my vote! 367 74.59%
I don't know, but its time for a new name. 125 25.41%
Voters: 492. You may not vote on this poll
Old 07-26-2018, 10:28 AM   #3221
Originally Posted by rvoll View Post
When I stroked the motor on one of my Porsches, the car was no longer balanced and as forgiving. It took me a year to bring it back with suspension changes, bigger wheels and tires and specially constructed transaxle mounts. I could out drag people better, but it was not as much fun at the track.
Should have just followed this blueprint....
Dadhawk is offline
TofuJoe (07-31-2018), WolfpackS2k (07-26-2018)
Old 07-26-2018, 10:32 AM   #3222
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I'm not totally sure about this depending on context. If you just add 80hp without also changing suspension, tires, etc., then aren't you compromising handling for power? Don't you need something to handle the greater power? Might you need a better clutch? If you're just adding 20 hp as in the MX5, then your compromise statement may be more accurate IMO.
This brings up a suspicion I've had for a while, that the ND was always supposed to have the 180hp motor, but they couldn't get it ready/pass emissions/whatever in time. So they released it with a detuned motor that did pass, while the car itself was engineered with the 180hp motor in mind. This could explain why Mazda didn't change much to beef the chassis up.
Yoshoobaroo is offline
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
rvoll (07-26-2018)
Old 07-26-2018, 10:35 AM   #3223
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
Originally Posted by m.box.design View Post
The 4 cyl version is aimed at people who can't afford to finance the 6 cyl version. Even the MK4 had a non turbo and base model SE models to accommodate a lower price bracket. The GT86 outside of the US also had a stripped down RC model intended for tracking/modifications.
If a race team or privateer decides they want to utilize the platform for motorsports and want to drop a different motor in or exchange paint with other cars, it'd be a no-brainer to start with the cheaper of the 2 options. Right?
There are two ways to look at this -- from a manufacturing perspective and a marketing perspective. You can make a 4 cyl car on the Supra line and market it as a different car. It would be possible that the next gen 86 is built on the Supra chassis but with different body panels, less insulation, etc. Marketing a 4 cyl version of the same car at a much lower price is problematic from a marketing perspective. How do you advertise both cars at once? From everything I've read, I think there will be a race version of the Supra, but it will cost a lot more -- like Porsches and Vettes. I also think the newer Supra will be much harder to mod than the current 86 as everything will be tighter with less space. Only time will tell.
rvoll is offline
The Following User Says Thank You to rvoll For This Useful Post:
SuperTom (07-26-2018)
Old 07-26-2018, 10:37 AM   #3224
rvoll
I couldn't. I owned 928's.... I never liked the 911's.....
rvoll is offline
Dadhawk (07-26-2018)
Old 07-26-2018, 10:59 AM   #3225
rvoll
So it looks like Tada agrees with Porsche that you just can't bolt on a turbo and make the car right..... What do those guys know about sports cars??????
rvoll is offline
The Following 3 Users Say Thank You to rvoll For This Useful Post:
Dadhawk (07-26-2018), dtbdan (07-26-2018), Yoshoobaroo (07-26-2018)
Old 07-26-2018, 12:00 PM   #3226
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
You guys looking for this ad again for like the n-th time?
krayzie is offline
Old 07-26-2018, 12:08 PM   #3227
Leonardo
Country Boy 4 Life
Leonardo's Avatar
via Imgflip Meme Generator
I LIKE TIRES!
Leonardo is offline
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Dadhawk (07-26-2018), Overdrive (07-26-2018)
Old 07-26-2018, 12:31 PM   #3228
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
FWIW, the Supra acts like a much heavier, less nimble car around the track, where the 86's low COG makes it a better performer. Now, if they could just give it some guts...
[ame]https://www.youtube.com/watch?v=j3YPhsTtPhs[/ame]
MJones_RB is offline
Old 07-26-2018, 01:02 PM   #3229
gymratter
Drives: BMW
[ame]https://www.youtube.com/watch?v=TM8EL2Otu1E[/ame]
gymratter is offline
The Following User Says Thank You to gymratter For This Useful Post:
stevesnj (07-26-2018)
Old 07-26-2018, 01:02 PM   #3230
krayzie
Drive From Home
krayzie's Avatar
A90 has lower CoG no?
krayzie is offline
The Following User Says Thank You to krayzie For This Useful Post:
MJones_RB (07-27-2018)
Old 07-26-2018, 01:14 PM   #3231
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by vh_supra26 View Post
The more I look at the swirls the more I'm seeing '86'... I hope that's only just me!!
JD001 is offline
Old 07-26-2018, 01:15 PM   #3232
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
“Porsche pioneered this technology for production cars back in 1975.” Oh really???? Maybe for their “production” cars but Turbos were around long before that. The Chevrolet Corvair Monza and the Oldsmobile Jetfire were the first turbo-powered passenger cars, and they debut in 1962/63.
Stephen W. is offline
Old 07-26-2018, 03:10 PM   #3233
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
You can still pioneer technology without being first.
ineedyourdiddly
strat61caster is offline
Old 07-26-2018, 04:32 PM   #3234
Yea turbos themselves are well over a 100 years old. They go back to aircraft engines for high altitudes. In fact, it was a GM engineer (Sandford Moss) who pioneered it, testing them on Pike's Peak back in the early 1900s. They were used in aircraft engines as early as 1920 I believe.
Not 100% sure about cars, but I think it was the Oldsmobile Jetfire in the early 60s that was the first production car with a turbo.
Dadhawk is offline
bmwforsuckers, boring-zzzzzzzzzzzzz, brz, celica supra confirmed, frs, ft-1, hatch-y +1, morethanucanaffordpal, nomanualnogo, supra, toyota, twins, watstheretailon1ofthose
Toyota FR-S : Official Name for the FT-86 Concept? Dark Scion FR-S / Toyota 86 GT86 General Forum 155 08-04-2010 11:05 PM
