View Poll Results: What name should Toyota use for the production Toyota FT-1?
Supra gets my vote! 367 74.59%
I don't know, but its time for a new name. 125 25.41%
Voters: 492. You may not vote on this poll
Old 07-25-2018, 08:50 PM   #3207
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by Summerwolf View Post
What? Adding power and keeping it with the MSM is pretty easy. Flying miata makes multiple kits. I thought the couple msm I drove were really decent.
Adding power is pretty easy, agreed. But the stock setup leaves a lot to be desired IMO.
Yoshoobaroo is offline
Old 07-25-2018, 09:03 PM   #3208
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Stock they're peaky, but I felt it was just expanding on the normal miatas powerband. Idk, probably the miata I would want.
Wouldn't mind a sky redline either.
Summerwolf is offline
The Following User Says Thank You to Summerwolf For This Useful Post:
Yoshoobaroo (07-25-2018)
Old 07-25-2018, 09:04 PM   #3209
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
If the marketing people really thought more hp would sell a lot more cars, you'd have more compromise. If they could sell the car for a lot more profit, you'd have more compromise. With the MX5, we'll see if more hp sells a lot more cars. I doubt it will in the longer term even with a very short term bump. They have to pay for any major redesign so you need either significantly more volume and/or profits (i.e., higher prices). It's easy to say compromise on what you or I might like, but doing it for the masses is far different. I would have paid a lot more for a GT version with more insulation, more comfortable and adjustable seats, and a modern, 8-10 speed DCT transmission. I doubt that most people here want that. I'll bet the Supra will have most of that, however.
rvoll is offline
Old 07-25-2018, 09:17 PM   #3210
I was really just referring to your case where you had to compromise handling for power.
Tcoat is offline
Old 07-25-2018, 11:26 PM   #3211
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
If you look at sports cars that have a base model and higher levels, like Porsche and Corvette, you'll see the base model is configured as the best daily driver with very few compromises. As you move up the ladder, you get performance upgrades which makes the car faster, but not a better daily driver. The very high end cars are basically track machines. From everything I've read, the base 6 cylinder Supra will come with an automatic transmission and be the base daily driver. There may also be some high end track oriented variants as well selling for over $100k. From a marketing perspective, having a low cost, 4 cyl, stripped down version will hurt the Supra brand in terms of being able to charge a premium for a low volume car. That doesn't mean that from a manufacturing perspective there may be another sports car produced on the Supra line that has a 4 cyl and a manual transmission. In order for there to be a base model 4 cyl Supra brand, the car still has to be able to produce as good as a daily driving experience, in terms of comfort and handling, and thus the price of that car will not be significantly less than the 6 cyl version. Otherwise, advertising will be very difficult from a brand perspective because you don't have a common driving experience. That said, this is a complex decision based upon the specific products, pricing, concept/product fit, and consumer testing. Without seeing the final products and pricing, there is no way for any of us to determine how this will enter the market.
The 4 cyl version is aimed at people who can't afford to finance the 6 cyl version. Even the MK4 had a non turbo and base model SE models to accommodate a lower price bracket. The GT86 outside of the US also had a stripped down RC model intended for tracking/modifications.
If a race team or privateer decides they want to utilize the platform for motorsports and want to drop a different motor in or exchange paint with other cars, it'd be a no-brainer to start with the cheaper of the 2 options. Right?
m.box.design is offline
Old 07-25-2018, 11:30 PM   #3212
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
FA20: 102.5 HP/liter
MX-5: 90 HP/liter
The higher this number, the more NOx gasses the engine will produce, making it tougher to pass emissions.
Some reason I was thinking about the compression ratio as opposed to the amount of NOx the engine outputs.
SuperDave is offline
Old 07-25-2018, 11:32 PM   #3213
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by Wise View Post
We don’t really know what Tada meant by “needing a different chassis”, the key word being different, if that is truly what he said. A different chassis might not be necessary to go get the groceries, but it may be needed to justify the price of a more expensive car and to hit the track with more power. Unlike the Miata that was mentioned previously, they probably would prefer to not just add parts to a platform that wasn’t designed for such things. They probably want to build a better complete car. So what needs to be changed on the 86 platform for more power?
Lots right?
-The transmission isn’t that strong so that might need to go and a bigger one might require a chassis change to widen the tunnel.
-A larger engine or FI system would add more weight to the front for a chassis that is already front heavy, so rebalancing the chassis and engine configuration would be ideal.
There are two issues. There are probably lots more issues that arise when building a car for longevity with more power.
Irace86.2.0 is offline
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
rvoll (07-26-2018)
Old 07-26-2018, 01:34 AM   #3214
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
Originally Posted by Rampage View Post
I just read somewhere in the last week that only 2% of cars sold in NA have manual transmissions. Most people do not want them. You get better gas mileage and performance from the new automatics and dual clutch cars. It just does not make sense for the auto makers to continue to manufacture cars with manual from an economic stand point.
Even most modern race cars no longer have a third pedal. I was a diehard manual driver for 50 years and taught all 4 of my kids to drive a standard shift but even I have to accept that the manual is a dinosaur and will soon become extinct.
2010 - 6.7% of cars sold in US with manual
2017 - 3% of cars sold in US with manual
2018 - first half of model year only 2% of cars sold in US with manual.
Soon, in order to get manual shift you will have to buy used.
I still see plenty of folks in the US who continue to cling onto the past by riding horse & buggy, I doubt manuals will become "extinct" very limited, sure, but there are still enough enthusiasts to cry loud enough
HKz is offline
Old 07-26-2018, 02:49 AM   #3215
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Good read.
"the car will shape itself, as we put in the equipment where it needs to go." - This quote here; this is the reason why German cars such as BMW and Mercedes are such a pain in the a** to work on. They just throw parts together to make it all work, not thinking about how it would be a nightmare to work on. Lol
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline
The Following User Says Thank You to DaJo For This Useful Post:
ermax (07-26-2018)
Old 07-26-2018, 05:42 AM   #3216
ermax
ermax's Avatar
He posted all those stats but forgot to post the stats for all the cars that were being discussed. The Twins are sold in manuals at 75%. The S2000 was only in a manual. The Civic Type-R is manual only. Focus ST/RS are manual only. The Mustang and Cameron sell more in manual than auto. All these kids clinging on to those older platform like the 240SX and RX7 is good for the future of the MT because they are learning to drive manuals (without the help of their parents) and will probably continue to drive MT as long as possible.
It isn’t about technical superiority. It’s about personal preference and typically people buying cars in this segment prefer a manual. Hence my statement above that we need to keep cars like these around for the survival of the MT. This segment as a whole probably doesn’t make a lot of sense statistically yet we still have it.
ermax is offline
The Following 2 Users Say Thank You to ermax For This Useful Post:
HKz (07-26-2018), WolfpackS2k (07-26-2018)
Old 07-26-2018, 09:30 AM   #3217
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Question
MX-5: 90 HP/liter
Once you get beyond basic fuel efficiency requirements, how EPA and CAFE ratings/regulations work in this country confounds me. I think partially because I have a difficult time locating the proper information online. So this question might seem naive, or dripping with ignorance.
But how is now that, from basically 2010 onward, low displacement engines no longer rev high (above 7500) with reason given as emissions. But, at the same time high performance (larger displacement) engines from Ford, Porsche, Ferrari, Lambo, etc are more prolific than ever, and are revving higher than ever.
This is something I don't understand.
WolfpackS2k is offline
The Following User Says Thank You to WolfpackS2k For This Useful Post:
daiheadjai (07-27-2018)
Old 07-26-2018, 10:03 AM   #3218
Yoshoobaroo
TRACKBREAD
Lots of low production run cars get exemptions, that's one way. The other reason is that low disp engines make more power than ever, and burn much hotter, which is good for fuel efficiency but bad for NOx emissions. So even if they don't rev as high they will make the power and thus produce the pollutants. There's no free lunch basically.
Old 07-26-2018, 10:17 AM   #3219
WolfpackS2k
Thumbs up
Hmm, I see. I would agree that low displacement engines make more power than ever, but only for FI engines. For NA 4 cylinder engines basically only the FA20 is hitting 100hp/liter (unless I'm mistaken). Also can't you eliminate a lot of the NOx emissions by forgoing direct injection altogether? I know DI by itself isn't responsible for NOx, but that DI's advantage is being able to run leaner and higher CR's - conditions that lead to higher NOx.
Exemption doesn't really explain the Ford Coyote engine. Mass produced and taps out at 7400 or 7500 rpm. Voodoo goes up to 8250, but that might fall under the low production run category?
Yoshoobaroo (07-26-2018)
Old 07-26-2018, 10:23 AM   #3220
rvoll
I'm not totally sure about this depending on context. If you just add 80hp without also changing suspension, tires, etc., then aren't you compromising handling for power? Don't you need something to handle the greater power? Might you need a better clutch? If you're just adding 20 hp as in the MX5, then your compromise statement may be more accurate IMO.
rvoll is offline
bmwforsuckers, boring-zzzzzzzzzzzzz, brz, celica supra confirmed, frs, ft-1, hatch-y +1, morethanucanaffordpal, nomanualnogo, supra, toyota, twins, watstheretailon1ofthose
Toyota FR-S : Official Name for the FT-86 Concept? Dark Scion FR-S / Toyota 86 GT86 General Forum 155 08-04-2010 11:05 PM
