Old 07-25-2018, 07:42 PM   #3445
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
So with my 255/40, approximately 1.1 to 1.25" lower than stock in the rear, and a 9k spring, should I rub? Wheels are 17x9 +35 RPF1.
saw some rubbing marks, but they may have been from before when the car was slightly lower. Given my setup I didn't think i would have to worry about rubbing but maybe I'm wrong?
Could this level of rubbing (see pic) cause significant damage to the tire in an autocross? Or is it just the fender lining that will wear down over time?
BR-ZED is offline   Reply With Quote
Old 07-25-2018, 08:14 PM   #3446
cjd
cjd's Avatar
Drives: 2017 BRZ
Any rubbing on the fender is not a good thing and might fail tech. It may be worth taking the time to verify exactly where it's rubbing and be sure it's never on metal.
I did not have issues on a 255/40 and 17x9+35 - I was on 10/12k, a bit lower, and -3.5°/-2.8° camber. You'll almost surely be fully compressed under the highest cornering load - how low you are won't play a role in this I think. I haven't run 255's on the new suspension yet, just 245's.
The only rubbing I've ever noticed is on the fender liner, and happened at full lock. I don't think it's any of my race tires doing this.
The Following User Says Thank You to cjd For This Useful Post:
BR-ZED (07-25-2018)
Old 07-25-2018, 08:21 PM   #3447
BR-ZED
BR-ZED's Avatar
Does anyone here roll their rear fenders? I searched the whole thread but couldn't find anyone mentioning it.
I probably will have to bring it back to the shop to see if its the same marks he noticed before aligning the car. He raised that corner about 3/8" of an inch during corner balance, so I'm really hoping the marks are just from before. I didn't really pay attention to the tire when I picked it up at the shop so the guy at the shop is the only one who can say if it was before or after the alignment :-/
I guess worst case I have them roll the fenders, didn't really want to do that but I guess better to be safe than sorry.
Old 07-25-2018, 08:26 PM   #3448
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
There is not really much to roll on the fenders. Clearance should be fine with your wheels/tires. Most people that I know with similar setups are not rolling the fenders. I didn't roll fenders on my FRS or my BRZ and it's a non issue.
justinco is offline   Reply With Quote
The Following User Says Thank You to justinco For This Useful Post:
BR-ZED (07-25-2018)
Old 07-25-2018, 08:41 PM   #3449
BR-ZED
BR-ZED's Avatar
Hey Justin, good to see you on here (I met you briefly in CO but I moved back to MD shortly after that).
Yeah. It seems like a small lip... but where else would those marks be coming from?
The Following User Says Thank You to BR-ZED For This Useful Post:
justinco (07-25-2018)
Old 07-25-2018, 09:06 PM   #3450
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Ah nice.
The tire mark does look like it is from the lip or outer part of the liner. I've seen that on my tires but usually only when the car was really low or bottomed on something. I have the same rear camber and have had the same sized wheels/tires and never had any catastrophic issues. I wouldn't worry about it too much.
BR-ZED (07-25-2018)
Old 07-27-2018, 08:11 AM   #3451
BR-ZED
BR-ZED's Avatar
Thanks again. Guy from the shop said the rubbing looked the same as before the alignment which is why he raised it for me. Looks like I'm ready to go.
Old 07-27-2018, 08:11 AM   #3452
BR-ZED
BR-ZED's Avatar
And on another note - what is a good starting point for hankook rs4 in 255/40? I was reading 38, but that seemed high (especially because I ran 32/30 on my 225/45/17 RE71Rs in CS/DS).
Old 07-27-2018, 12:48 PM   #3453
NJ10
Stiggasaurus Rex
NJ10's Avatar
Drives: '14 WRB Subaru BRZ 6MT
I ran 30/28(same as RE71), car felt compliant. ymmv
Sent from my ZTE A2017U using Tapatalk
meh.
NJ10 is offline   Reply With Quote
Old 07-27-2018, 12:59 PM   #3454
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
Use a pryometer! That is the only way to really know the right tire pressure.
Lincoln Logs is offline   Reply With Quote
Old 07-27-2018, 07:02 PM   #3455
BR-ZED
BR-ZED's Avatar
How? I can see why you would use a pyrometer to determine if you have too much or too little camber, but how can you use it to determine tire pressure?
Edit: Ah, found this informative article.
https://949racing.com/using-a-tire-p...49-Racing.aspx
Too bad I bought a laser pyrometer already to monitor camber. Oh well, better than nothing i guess?
Old 07-29-2018, 11:17 AM   #3456
Lincoln Logs
That is the exact guide I was going to link you, but you found it already. The laser pyrometer won't work for this because the surface temp changes too fast. The probe types tell you the actual temp of the rubber.
I use an inexpensive economy pyrometer, the Joe's Racing brand.
The Following 2 Users Say Thank You to Lincoln Logs For This Useful Post:
BR-ZED (07-29-2018), ryejeff (07-30-2018)
Old 08-03-2018, 12:50 PM   #3457
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Does the brz ts fit in stx, with all the plastic body kit gurney flap, under trays side kirts and front lip. If not where does it fall?
Sent from my Pixel using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 08-03-2018, 03:24 PM   #3458
tony_r
tony_r's Avatar
Drives: '15 STX
It's not classed at the moment. I dont see a problem with classing it in STX but others might due to the aero bits. If it doesnt fall in STX then I don't see a reason to class it.
tony_r is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
