Old 07-21-2018, 12:11 PM   #1
twag4
Drives: frs
Pinion angle
I have a drivetrain vibration with my cd009 vq transmission swapped 2013. I have 600hp driveshaft shop axles, and the PST carbon fiber driveshaft that came with the transmission kit. One of the axles has issues, it is slinging a lot of grease out of the outer cv boot. The vibration only reveals itself above 70mph. I am swapping back stock ads for now, to try and eliminate that as a possibility and to get DS shop to deal with the grease issue. (Still awaiting their reply as I just messaged them). My question is about pinion angle. It is very difficult to compare the transmission output angle to differential pinion angle, but that could cause my vibration. Is there a way to adjust pinion angle on our cars? Please advise!
twag4 is offline   Reply With Quote
Old 07-21-2018, 02:21 PM   #2
Both ring and pinion gears are shimmed to position axially but they are fixed in angle perpendicular to each other.
You should be able to identify the source of the vibration by its frequency. Does it follow wheel speed, or driveshaft speed?
https://demos.starbase7.net/t3Portal...00O5A01DX.html
Old 07-21-2018, 11:22 PM   #3
twag4
Drives: frs
Pinion angle is the angle in relation to the driveshaft. If the driveshaft is 3 degrees offset from the transmission output shaft, the pinion shaft needs to be -3 degrees offset from the driveshaft.
Old 07-21-2018, 11:23 PM   #4
twag4
Drives: frs
So I put the stock axles back on, no difference. I suspect that my pinion angle does not mirror the transmission output shaft angle. Gotta figure out how to address that now.
Old 07-21-2018, 11:54 PM   #5
Ok, that's a new term for me. Do you have any reason to believe your pinion gear is no longer coaxial with your output shaft?
Old 07-22-2018, 02:08 AM   #6
I'll guess that the vibration is caused by your car's driveshaft being out of balance ..
Is your new CF driveshaft a single piece or two piece?
Old 07-22-2018, 04:05 AM   #7
toyubie
Drives: none
IIRC, the Mazworks kit is a single-piece but OP did not specify which kit he used. The other kits I found are steel shafts.
toyubie is offline   Reply With Quote
The Following User Says Thank You to toyubie For This Useful Post:
humfrz (07-22-2018)
Old 07-22-2018, 04:52 AM   #8
I found this educational (for me at least) ..
https://www.quickperformance.com/Pin...ent_ep_45.html
The Following 3 Users Say Thank You to humfrz For This Useful Post:
BirdTRD (07-22-2018), twag4 (07-22-2018), Ultramaroon (07-22-2018)
Old 07-22-2018, 10:14 AM   #9
sid94
Drives: 2013 frs
Maybe you got the height wrong when you got the trans mount welded in?
sid94 is offline   Reply With Quote
Old 07-22-2018, 10:18 AM   #10
twag4
Drives: frs
Yes MazWerks kit. There is really not enough room to manipulate the transmission much. The overpipe will hit either the body of th car or the sway bar. I tried to just match the original engine angle. Trying to measure the transmission output angle is difficult due to lack of room. I will pull the driveshaft soon and use the end of the transmission shaft to measure.
The Following User Says Thank You to twag4 For This Useful Post:
Old 07-22-2018, 10:18 AM   #11
twag4
Drives: frs
And it is a one piece carbon fiber driveshaft
humfrz (07-22-2018)
Old 07-22-2018, 11:07 AM   #12
gtengr
Drives: 2017 BRZ
Have you tried clocking the driveshaft 180 degrees?
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
Old 07-22-2018, 12:43 PM   #13
Interesting idea. For the sake of description, if the driveshaft's axis of rotation is lined up with an imaginary z-axis, it is symmetrical about the x and y planes. In my head, that means clocking angle would have no effect. Am I missing something?
Old 07-22-2018, 01:02 PM   #14
Is there room to line a straight edge up with one of the side ribs in the transmission housing?
Also, do you have a local shop that can verify the integrity of your new driveshaft?
humfrz (07-22-2018)
WTB: 3.7 or 3.9:1 ring and pinion Salemate Canada Classifieds 0 01-25-2018 09:52 AM
WTB ring and pinion Salemate Canada Classifieds 0 03-13-2016 02:07 PM
Considering going to 3.727 gear/pinion in 6MT HotLavaMann Engine, Exhaust, Transmission 83 01-10-2015 10:34 AM
Change FD ratio to 4.56 by changing only pinion peachch Engine, Exhaust, Transmission 1 08-31-2013 01:25 PM
MFactory Ring and Pinion Sets JMPoole Engine, Exhaust, Bolt-Ons 14 07-31-2013 12:09 PM
