Old 07-05-2018, 07:10 AM   #267
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Is that true for manuals?
Two different animals. Go back and look at OP #1.
BirdTRD is offline   Reply With Quote
Old 07-05-2018, 12:20 PM   #268
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
If the drip method doesn’t work then what I said holds true, that being level doesn’t matter.
Old 07-19-2018, 10:09 AM   #269
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
procedure would be to tilt the car towards the drain plug to maximize emptying then to tilt the car away from the fill plug to maximize fluid retention.
Am I missing something?
Any harm in doing it this way? This is what made the most logical sense to me and is what I did. Maybe risking overfilling, I guess?
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 07-19-2018, 07:06 PM   #270
Irace86.2.0
I actually did this to empty the case but then used the flat method to fill the case, which did fill it to the requirement levels plus a few extra CCs. Reasonably, there should be a difference in how much fluid the case can take based on it being a bone stock dry case, a case that was removed and drained completely, and a case that was drained on a flat surface for just quick change. This is probably why the plug is designed to allow for a drip/fill method. With that said, small variances shouldn’t be a huge worry if you put a specific amount in the case that the manual says it needs.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Lakitu (07-20-2018)
Old 08-13-2018, 12:18 PM   #271
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
Thanks for the guide, did the Rear Diff this weekend and everything went as expected.
slizoth is offline   Reply With Quote
Old 10-01-2018, 08:43 AM   #272
Christopher1977
Drives: 2015 FR-S, Halo
Did mine this weekend. Everything went as expected. Only issue is I couldn't find a way to fit a torque wrench alongside the transmission to torque the fill plug, so I tightened it down by hand.
I did notice a difference when shifting into 2nd. Doesn't feel as buttery smooth as a Honda, but it does feel way better than before.
Christopher1977 is offline   Reply With Quote
Old 10-01-2018, 11:21 AM   #273
Tristor
Tristor's Avatar
These plugs I usually just German torque (goodentight) with a ratchet and use the length of the ratchet based on expected torque value to help prevent me from overtorquing too much. The only way to get a torque wrench on some of these hard to find places is to either use a crow's foot wrench or to use a combination wrench torque adapter like the one from Motion Pro.
If you used new plug o-ring/gasket and it's not leaking you're probably fine
Tristor is offline   Reply With Quote
Old 10-01-2018, 08:54 PM   #274
Christopher1977
I didn't, not for the fill plug. The 2 that came with the Motul oil said 'drain plug gasket' on the package so I used them for the drain plugs in the trans and diff, and recycled the washers that were on the fill plugs already. Bad?
Old 10-01-2018, 10:11 PM   #275
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Not too bad as long as it isn't leaking, it's just good practice to replace all of them next time anyway as they are supposed to "crush" with the torque to the seal the bolts
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Christopher1977 (10-01-2018)
Old 12-22-2018, 02:01 AM   #276
Moletheus
Moletheus's Avatar
Drives: Raven 2014 FR-S
Changed my diff and trans fluid with the recommended Motul fluid. I have noticed absolutely no change in changing gears. If anything it has gotten worse. It is still hard to shift into 2nd. Sometimes its smooth as can be. Sometimes it grinds like crazy putting it into 2nd. Intermittent annoying problem for sure. It seems to have more problems when shifting at lower RPM's. Maybe I should drive it harder... Also, I changed the fluid after the dealership replaced the clutch throw out bearing and clutch plate itself. This is just a disclaimer to all that may think this is a fix for a "notchy" shifter. Didn't work for me.
Moletheus is offline   Reply With Quote
The Following User Says Thank You to Moletheus For This Useful Post:
pushrod (08-30-2019)
Old 02-19-2019, 04:14 PM   #277
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Can Red Line MT-90 be used in the rear differential? I really like how it feels in the transmission and thought I'd use it in the differential next time I change fluids.
smg1138 is offline   Reply With Quote
Old 02-25-2019, 08:00 PM   #278
m86
Drives: FRS
Had the same problem. A U-joint socket adapter solved it.
m86 is offline   Reply With Quote
Old 10-26-2019, 12:06 PM   #279
ldooks
Drives: 2017 GT86, 2014 Honda CBR650F
just an FYI, I did my trans/diff yesterday and used this kit. It has enough washers/gaskets to do the job twice, and it costs as much as one OEM transmission drain washer https://www.amazon.com/gp/product/B07CJHTDVV/
ldooks is offline   Reply With Quote
Old 10-29-2019, 12:45 PM   #280
xerosagas
Drives: 2014 Subaru BRZ Limited, CWP
I can't find any mention across the internet. Do you also need to change the transmission filter and if so, how?
xerosagas is offline   Reply With Quote
differential, diy, fluid, transmission
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 08:57 PM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 05:47 AM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-20-2012 11:33 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
