#15 |
Drives: Subaru BRZ
Is it a pushbutton or key start?
#16 |
Drives: Silver FR-S
Found my better "beeping" multi-meter. Just went through all the fuses under the hood and in the foot well again, all have continuity.
I don't follow wiring diagrams well... if the mirror heater relay broke when i pulled it would that kill the power to the ECU? I have an FRS, the red "car and lock" is flashing and the door ajar is on. When I insert the key the car and lock light goes out. Door ajar works as you would expect. Nothing else on the dash works. Radio works, headlights work. Betting on a trip to the dealer... |
#17 |
Drives: Silver FR-S
#18 |
Drives: Subaru BRZ
This might be a stupid thing to ask but I'll ask it anyway, if you have an Auto Trans are you in Park or Neutral. Just remembered a similar thing happened to my brother awhile back
#19 | |
Drives: Silver FR-S
#20 |
Drives: Silver FR-S
Nothing is stupid. It's a stick. Problems are obvious before I ever trey too crank it.
#21 |
What is the exact volt reading on your battery??
Is the battery the original battery? Sometimes a weak battery will cause problems. Before I'd take the car to a dealer, I would take out the battery and take it up to a shop and have it "load tested". humfrz |
#22 |
Drives: 2017 BRZ Limited, Perf Package
#23 | |
Drives: Silver FR-S
Normally I would agree but the car was running, i pulled the relay and it died. I think something is broken... |
| The Following User Says Thank You to Rob37072 For This Useful Post: | humfrz (07-18-2018) |
#24 |
If you did your testing right, I know what the issue is.
Just need you to confirm. I have to get back to work, but if you did what i asked for testing, you have blown the fusible link (pic below). Remove the cover for the positive battery terminal and look in the glass and see if the elements are separated, if so, you have found your issue. Worth adding that if you blew this fusible link, you would no longer have ignition power, etc. So it sounds like that is probably what happened here. |
#25 |
Drives: Subaru BRZ
Looking in the wiring diagram the only thing tied into the mirror heater is that big fuse on top of the battery.
#26 |
Drives: FT86
You should be able to talk to ecu via obd port (ie can buss) with just earth 12v and ignition 12v supplied to ecu.
Check all ecu fuses |
#27 | |
Drives: Silver FR-S
I checked that and they look ok. I also have continuity between the battery post and both of the big nuts that have blue lines in your image. I put the meter leads on the big bare starter bolt and the positive terminal on the battery. I didn't really expect 12v, i assumed it was + to +. Maybe i hit the wrong part of the starter. |
#28 | |
A meter tells you the different between the two leads. If you go positive to positive and show a difference of 12 volts, it isn't making it to where it should be. |
| Car pulling under acceleration | Midjetv8 | Issues | Warranty | Recalls / TSB | 37 | 11-15-2016 09:53 AM |
| Pulling up floor rug? | ndsleep612 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 12-11-2013 01:23 AM |
| Brz pulling trailer? | subiesteve | Southwest | 7 | 11-20-2013 09:04 PM |
| 94 octane not pulling | Scalzo | Forced Induction | 44 | 10-08-2013 10:15 PM |
| Pulling your FRS off of the lot, what are you bumpin'?? | poormans_LFA | BRZ First-Gen (2012+) — General Topics | 201 | 06-09-2012 09:52 PM |
