, dpfarr
Old 07-18-2018, 12:57 PM   #2843
CSG Mike
CSG Mike's Avatar
Originally Posted by Carlos_M View Post
Apologies for any confusion, car is already supercharged.
-Carlos
How much output? Gains are minimal. It's not like a turbo where maximum flow has a very noticeable effect on spool.
Old 07-18-2018, 01:40 PM   #2844
Carlos_M
Carlos_M's Avatar
Drives: 2014 BRZ Limited
I guess the output number is less of a concern than efficiency.
Unfortunately, E-85 isn't readily available where I reside so fueling is limited to 93 octane. I'm also not looking to break any records.
So if the general consensus is that 3" will net minimal gains unless I'm trying to extract the absolute last drop then I think I should be set with my path forward!
Appreciate your input!
-Carlos
Carlos_M is offline   Reply With Quote
Old 07-18-2018, 02:16 PM   #2845
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I haven't had any experience with other headers, but I have the coated ACE A350 header and touring 86 exhaust, some people don't like it, but its perfect for me. It's fairly quiet during cruise and sounds sooo sexy at WOT. I even had a modified M2 owner come up and comment on how much he loved it.
B T is offline   Reply With Quote
The Following 2 Users Say Thank You to B T For This Useful Post:
Carlos_M (07-18-2018), HachiRokuX (12-02-2018)
Old 07-18-2018, 02:21 PM   #2846
CSG Mike
CSG Mike's Avatar
-Carlos
Your largest limitation will be at your header, and then front pipe.
If your header's outlet is 63mm (as are most headers'), then going larger that doesn't do anything; the tightest point is still 63mm.
Carlos_M (07-18-2018), Sarang (07-19-2018)
Old 07-19-2018, 06:58 PM   #2847
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Colin86 View Post
Posted this in the dyno thread but figured I'd share here as well.
Edelbrock w/ stock pulley
DW300c fuel pump and DW 700cc injectors
Delicious D box, flex fuel kit, and Edelbrock tune
Gruppe-S UEL header and over pipe (both coated)
E85
Stock front pipe, cat back, and clutch
327whp and 243wtq
Sorry for potato quality. Note Delicious performed their V25 revision on the car following this dyno (same one Zach is mentioning above) and it feels even better than it did when it put down these numbers -really a nice upgrade and I highly recommend it.
Huge shout out to Nik and Hal at Dynosty for being super chill and helpful, and to Zach at Delicious for all of his help with dialing the tune in!
What boost level are you seeing in your logs?
Old 07-21-2018, 10:35 AM   #2848
Colin86
Drives: 86
Logs are showing manifold absolute pressure around 1.75 bar right at my redline of 7500, so a peak of 10-11 psi. Note Delicious and most tuners recommend safely extending redline slightly and I would net more power doing so -but I've requested my redline remain at 7500.
Here's a graph of the MAP and RPM from a WOT log on my car with the tune it ran on the dyno.
Hope this helps!
Colin86 is offline   Reply With Quote
The Following User Says Thank You to Colin86 For This Useful Post:
gtengr (07-21-2018)
Old 07-22-2018, 07:55 PM   #2849
jordanthebass
Judson
jordanthebass's Avatar
Drives: 15 FRS 6spd Edelbrock SC
The stock fuel system is beefier than you think...
First off, I'll say again this kit has blown my expectations out of the water. I've been driving around on a Delicious tune, but recently took her in to get a nice dyno tune. I'm still running the STOCK fuel system and standard 3.25 inch pulley that comes with the kit, and Forged performance reached in and pulled 311whp out of her! Not only that, she makes close to peak torque from 3.5k all the way to redline, on 93 pump gas! If only there were an e85 station closer than 12.7 miles from me.....
jordanthebass is offline   Reply With Quote
The Following User Says Thank You to jordanthebass For This Useful Post:
gtengr (07-22-2018)
Old 07-22-2018, 08:46 PM   #2850
HaloKouki86
Drives: '17 Toyota 86
Is it just me or the picture is broken? Anyway, those are great numbers. Everything is stock right?
Sent from my SM-N950U using Tapatalk
HaloKouki86 is offline   Reply With Quote
Old 07-22-2018, 09:06 PM   #2851
BertoFT
Drives: 13 FRS Firestorm
Pictures often show up broken on mobile. Try desktop mode.
I'm also interested on what mods Jordanthebass has. Forged performance is might be the nearest tuner to me.
BertoFT is offline   Reply With Quote
Old 07-22-2018, 09:10 PM   #2852
HaloKouki86
Okay will do. Thanks!
Old 07-24-2018, 09:37 PM   #2853
jordanthebass
Judson
Well I am running a pair of catless uel headers and a full 2.5 inch exhaust, an oil cooler which keeps the oil temp perfect at all times. (Probably not necessary but Atlanta can get dangerously hot in July). Other than that I haven't touched the anything regarding fueling and/or electrical. If you'd like the details I'd love to share perhaps outside this thread so I don't clog it up
BertoFT (07-25-2018)
Old 07-24-2018, 09:39 PM   #2854
jordanthebass
Judson
Yes, stock fueling system but I've got catless headers and full exhaust.
Old 07-25-2018, 05:06 PM   #2855
miguex
Drives: 2017 BRZ Special Edition
OFT for the supercharger? for non-ecutek users
Is possible to write the tuned SC file as OFT with openflash?
miguex is offline   Reply With Quote
Old 07-27-2018, 03:45 PM   #2856
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Originally Posted by paiceyfan View Post
So, more information on the throttle issue...
Returning home from traveling at the weekend, I got stuck in Portland traffic for a good 90 minutes or so, so it gave me the chance to explore.
For the first ten minutes, everything was fine with no issues and then it started happening again.
It's stop-and-go traffic, so I bring up the clutch pedal with minimal revs and pull forward. As I dip the clutch pedal, the revs fly up to 3,000 revs and bounce between that and around 900 constantly. I bring up the clutch pedal again and pull forward and the process starts all over. Here's the interesting part that I learned this time...as I stop, I put the car into neutral and the issue goes away completely. If I leave it in 1st, it revs a couple of times and eventually settles down. As an experiment, I put it in 1st and crept forward after bringing the clutch pedal up again, but this time, I coast slightly downhill (clutch pedal depressed fully) and leave the gear in 1st and the revs continue to swing. While still continuing to coast, I take it out of gear into neutral and the revs calm down and are stable at 950rpm.
So, this only seems to happen in gear...I don't know why, but it sure is strange.
I have some good news with regard to this particular issue. Neal at The Racer's Line cleaned the throttle body and checked the pins on the harness to the MAF. The pins looked a little loose, so he tightened them up and added some hot glue to make sure they were secure. Since then, going on three days now, I have had no issues with the idle. Keeping my fingers crossed...
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
