Old 07-17-2018, 09:59 PM   #1
Rob37072
Drives: Silver FR-S
No start after pulling the mir relay.
Car won't start after I accidentally pulled the mirror heater relay. It shut off as soon as I pulled it. I was trying to diagnose a cooling fan issue and I pulled the wrong relay. All the electronics work except the starter doesn't even click and there dash doesn't illuminate other than the door open light. The supercharger coolant pump also won't come on. Fuses all show continuity (except one of the fan fuses but I replaced that one)
No fuel pump noise
No CEL
No Link on an OBDII scanner
Dash doesn't "Wake Up" when turning the car on.
Rob37072 is offline   Reply With Quote
Old 07-17-2018, 10:23 PM   #2
Did you check that big fuse that's up on the battery?
Old 07-18-2018, 12:16 AM   #3
Rob37072
Drives: Silver FR-S
I did. Looks ok. Both bolts off the post have continuity. Also the headlights and radio are fine...
The Following User Says Thank You to Rob37072 For This Useful Post:
humfrz (07-18-2018)
Old 07-18-2018, 05:09 AM   #4
Does the starter have a relay? (I don't know)
If it does, did you check it?
humfrz - ain't much help -
Old 07-18-2018, 10:25 AM   #5
steve99
Drives: FT86
link to wiring diagram
check the 10A ECU IG1 7.5A MPX-B 15A HAZ 10a ECU ACC fuses they common to mirror heater and dash imobilisier
Old 07-18-2018, 01:54 PM   #6
Rob37072
Drives: Silver FR-S
Thanks for the reply. Just went out and rechecked. All of those fuses look fine, have continuity across them and have 12v on the volt meter against a ground. (Battery ground or bolt in the door jamb)
Old 07-18-2018, 01:57 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I am old school, so I would disconnect the battery for a minute. This could reset the car.
When I unplugged the ABS fuse; I had to disconnect the battery cable to have it recognize that I had plugged the ABS fuse back in.
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
humfrz (07-18-2018), ls1ac (07-18-2018)
Old 07-18-2018, 01:58 PM   #8
Brz_racer
Drives: Subaru BRZ
You need another person to start the car and while they are doing that check to see if you even have power going to the starter wires...
Brz_racer is offline   Reply With Quote
The Following User Says Thank You to Brz_racer For This Useful Post:
humfrz (07-18-2018)
Old 07-18-2018, 02:06 PM   #9
Rob37072
Drives: Silver FR-S
OBDII scanner says "No Link"
did I brick the ECU?
Old 07-18-2018, 02:06 PM   #10
Rob37072
Drives: Silver FR-S
Ya, i left the negative side off overnight hoping... no dice.
Leonardo (07-18-2018)
Old 07-18-2018, 02:07 PM   #11
Rob37072
Drives: Silver FR-S
I'm sure it's not just power to the starter. Too many other things don't work. With the key "on" but not turned to crank it doesn't even wake the dash up with the engine light and all that.
Old 07-18-2018, 02:12 PM   #12
Brz_racer
Drives: Subaru BRZ
It kinda sounds like an ECU problem although I'd be rather surprised if pulling a relay would brick the ECU completely. You said the ECU fuse(s) are all good? Did you put a meter on them or just visually look? Sometimes fuses are bad even if they dont look it.
Old 07-18-2018, 02:13 PM   #13
Razorlor
Drives: 2017 BRZ Limited, Perf Package
There is a fusible link in that circuit for the alternator.
The issue I have is that removing a relay shouldn't blow any fuses whatsoever.
I'm assuming you have a multimeter, so do this. Put one lead on the battery positive terminal and the other on the power wire of the alternator and let me know what it reads. (Have it set to DC volts)
Razorlor is offline   Reply With Quote
Old 07-18-2018, 02:13 PM   #14
Rob37072
Drives: Silver FR-S
I put a meter on them, visually inspected them and checked both sides of the fuses for 12v... all checked out ok.
Car pulling under acceleration Midjetv8 Issues | Warranty | Recalls / TSB 37 11-15-2016 10:53 AM
Pulling up floor rug? ndsleep612 Cosmetic Modification (Interior/Exterior/Lighting) 1 12-11-2013 02:23 AM
Brz pulling trailer? subiesteve Southwest 7 11-20-2013 10:04 PM
94 octane not pulling Scalzo Forced Induction 44 10-08-2013 11:15 PM
Pulling your FRS off of the lot, what are you bumpin'?? poormans_LFA BRZ First-Gen (2012+) — General Topics 201 06-09-2012 10:52 PM
