Old 07-03-2018, 09:03 PM   #127
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Awesome!
Any new info on the ECU options?
Old 07-05-2018, 02:27 PM   #128
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by Yoshoobaroo View Post
Awesome!
We have all but started our 2JZ test car with the new stuff but ran into some issues with the start sequence, it's all fixable back end stuff, just a slow process working with the developer.
Pure Automotive is offline   Reply With Quote
The Following User Says Thank You to Pure Automotive For This Useful Post:
Yoshoobaroo (07-05-2018)
Old 07-05-2018, 03:39 PM   #129
Yoshoobaroo
TRACKBREAD
Good to hear progress is being made. We're lucky someone is willing to put the development time in for a solution that'll benefit swaps on this platform!
Old 07-05-2018, 04:36 PM   #130
Pure Automotive
Prototype mount placement is pretty on point! Just need to change a few things on the tranny side, the S2K trans is tricky because its essentially mounted diagonally to line up with the slant of the K/F motor.
IMG_6155 by Brady Johnson, on Flickr
IMG_6154 by Brady Johnson, on Flickr
The Following 8 Users Say Thank You to Pure Automotive For This Useful Post:
Alltezza (07-06-2018), Draco_PR23 (07-06-2018), Joesurf79 (07-05-2018), PR138 (07-16-2018), RallySTI (07-06-2018), Sportsguy83 (07-06-2018), wparsons (07-16-2018), Yoshoobaroo (07-05-2018)
Old 07-16-2018, 04:55 PM   #131
laextreme5
laextreme5's Avatar
Drives: 2014 BRZ
I. Need. Updates.
laextreme5 is offline   Reply With Quote
The Following 2 Users Say Thank You to laextreme5 For This Useful Post:
Pure Automotive (07-17-2018), wparsons (07-16-2018)
Old 07-17-2018, 10:08 AM   #132
Pure Automotive
Originally Posted by laextreme5 View Post
I. Need. Updates.
Update, new set of test mounts coming this week to make sure it's 100% right. I'd rather everyone be anxious because it's taking too long than to put out parts that don't fit, we're in way too deep to not finish, so don't worry lol
Once mounts are done, they will go into production and presale, followed by a swap oil pan which is absolutely required, followed by a swap header, followed by a shifter solution, followed by a wiring solution, followed by some of the fastest twins on the road and track
The Following 13 Users Say Thank You to Pure Automotive For This Useful Post:
Alltezza (07-19-2018), Clipdat (07-17-2018), Draco_PR23 (07-26-2018), Joesurf79 (07-17-2018), laextreme5 (07-17-2018), Lakitu (07-23-2018), Leonardo (07-17-2018), pgranberg11 (07-17-2018), PR138 (07-17-2018), Sportsguy83 (07-17-2018), Takumi788 (07-18-2018), wparsons (08-03-2018), Yoshoobaroo (07-20-2018)
Old 07-17-2018, 05:40 PM   #133
laextreme5
laextreme5's Avatar
Drives: 2014 BRZ
Old 07-23-2018, 12:51 PM   #134
Yoshoobaroo
TRACKBREAD
Is the header in the pictures the leading candidate design or do you plan on some experimenting when the time comes?
Old 07-23-2018, 02:03 PM   #135
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
What is happening in this thread....!? why go from 2.0L to 2.4L swap? unless it didn't have an engine to begin with and the honda engine was super cheap. I've never heard of this. subbed
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 07-23-2018, 03:14 PM   #136
gtengr
Drives: 2017 BRZ
If the goal is ~350 rwhp or less, you can do it all motor with a built K24, plus save some weight off the front and rev to 9000 rpm. It's a bit of a niche swap, and not the best if you just want dyno queen numbers, but it's not that expensive when you consider that 350 rwhp is into rod and transmission damage range on an FA20.
gtengr is offline   Reply With Quote
The Following 2 Users Say Thank You to gtengr For This Useful Post:
Draco_PR23 (07-26-2018), wparsons (08-03-2018)
Old 07-25-2018, 08:53 PM   #137
laextreme5
laextreme5's Avatar
Drives: 2014 BRZ
Are there plans to use the stock trans as an alternative as well?
Old 07-26-2018, 08:37 AM   #138
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Stock trans is basically made of glass when compared to typically robust transmissions don't bother with it.
Old 07-26-2018, 08:57 AM   #139
Yoshoobaroo
TRACKBREAD
Ehmmm. It's based on the same Aisin transmission as the S2000, so it won't be that far off. There's people putting down 400 lb*ft at the wheels on it. For an NA K24 it should be just fine.
The biggest problem I see with the stock tranny is that the motor would have to sit further forward.
Old 07-26-2018, 09:20 AM   #140
Sportsguy83
Drives: Limited BRZ
Oh but it is not similar in holding power to the S2K (this is not news, it's widely known).
I pushed 481 WTQ on the stock trans, but that does not mean its stout. I treated it pretty lightly to prevent grenading it. No hard launches, took time shifting, etc.. Many many people making power have exploded 4th just engaging it while pushing boost (not a misshift, not a hard launch, just shifting).
One of the main reasons to swap is because it altogether deals in one shot with the weak transmission. I agree, for an NA K swap it should be mostly fine, but generally people swap to go for bigger power than that. The cost of developing a swap kit needs to be justified by the market and the market for keeping the stock trans is pretty low.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
Draco_PR23 (07-26-2018), wparsons (08-03-2018), Yoshoobaroo (07-26-2018)
FS: Avant Garde M310 Matte Black 18" x 9" and 18" x 8" w/ Michelin Pilot Super Sports NvSnickers Wheels and Tires 2 04-04-2017 10:30 PM
Obnoxious "Blank" banner ad breaking quick reply Clipdat Site Announcements / Questions / Issues 16 03-09-2017 11:44 AM
Stock pistons "rate ore hate" ? Fricke Forced Induction 35 02-25-2016 10:59 AM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
My Adventures Aboard "Our Girl" Wes B. Other Vehicles & General Automotive Discussions 3 02-04-2013 11:44 PM
